Thread started 30 May 2015 (Saturday) 13:01
Flash output level adjustment ...
iroctd
Joined Aug 2013
Post edited over 8 years ago by iroctd.
May 30, 2015 13:01 |  #1
I have a 7d mark 2 and I'm wondering if there is a faster way to get to the flash output level to adjust power?
Currently I have a My Menu item for Flash Control but I still have to go Menu button, Set button scroll 3 times, set button, set button - to then change it.
I'm fine if that is the way, just wondering if there is a faster way?
(i'm using the flash on Manual btw)
-Feedback-
MakisM1
Gallery: 50 photos
Joined Dec 2011
May 30, 2015 13:37 |  #2
iroctd wrote in post #17577096 (external link)
Have you tried the Q screen?
Gerry
mike_d
May 30, 2015 14:03 |  #3
Why not adjust it on the flash itself?
GeoKras1989
Joined Jun 2014
May 30, 2015 14:55 |  #4
If you are just adjusting FEC, the Q-screen is very quick. If adjusting manual output, doing it on flash is easier than menu-diving.
WARNING: I often dispense advice in fields I know little about!
iroctd
Joined Aug 2013
May 30, 2015 16:23 |  #5
I agree with the Q button but I wanted the actual power adjustments. I'm new at this and didn't want to do so much back and forth to the flash and where I'm shooting while I'm learning. I'll stick with the menu. Thanks everyone!
-Feedback-
110yd
Joined Jan 2005
May 30, 2015 20:15 as a reply to  @ iroctd's post |  #6
There is another way. I noticed from your gear list that you have YN-622 triggers. You could get the YN-622Tx. It would allow you to adjust the power from the YN-622Tx sitting in the hotshoe of the camera.
Hope this helps,
110yd
iroctd
Joined Aug 2013
May 31, 2015 06:20 |  #7
110yd wrote in post #17577519 (external link)
Hope this helps,
110yd
:-D:-D Thanks! That is just what I'm looking for.
-Feedback-
GeoKras1989
Joined Jun 2014
May 31, 2015 07:41 |  #8
iroctd wrote in post #17577902 (external link)
I don't get it. 622, menu, back of flash? It is all taking your eye away from the VF. How is one better? How do you beat one-button, and adjust on the flash itself?
apersson850
Obviously it's a good thing
Gallery: 35 photos
Post edited over 8 years ago by apersson850.
Jun 02, 2015 06:57 |  #9
As far as I understand, he wants to set the manual power output level on a flash that's remote controlled from the camera. To do it on the flash requires walking back and forth between camera and flash. A remote controller with display would allow this to be done on that remote controller, which in turn is on the camera itself.
But he didn't include the vital point of information in the first post, i.e. that the flash seems to be remote controlled from the camera.
Anders
MakisM1
Gallery: 50 photos
Joined Dec 2011
Jun 02, 2015 08:29 |  #10
The answer changes for OCF, if you use the onboard flash as the Flash Commander. I use the Flash Commander in my 60D. In order to have full control of the OCF from the camera, you set the OCF in ETTL II slave mode (A or B, depending how many flashes you are using and what is the desired contribution of the onboard flash...). ETTL is what allows communication with the camera so you can manually change the flash power from the camera.
Now, if you set:
The onboard flash to ETTL, then the flash power will be set by the camera, based on its algorithms. You can set the power ration between onboard flash and OCF. You can use Flash Exposure Compensation from the Q screen.
The onboard flash to Manual, you can set the flash output power manually for groups A and B. You lose the Q screen control.
Gerry
PaulSoebekti
Joined Dec 2002
Post edited over 8 years ago by PaulSoebekti.
Jun 02, 2015 09:02 |  #11
Flash output can be adjusted easily without taking your eye off of the viewfinder - use the <M Fn> AF area selection/ Multi-function button described on pages 92 and 258 in the manual. Quicker than fiddling through the Q button menu ...
Note: M Fn button is the tiny button between the shutter and the main dial.
Hope this helps.
Paul
wallstreetoneil
Gallery: 14 photos
Joined Nov 2014
Post edited over 8 years ago by wallstreetoneil.
Jun 02, 2015 13:24 |  #12
As far as I know, you can't adjust manual power using this button - just FEC.
And, if the flash is in Manual, lets say 1/4 power, and you take a picture, it doesn't matter if you set FEC to +/- 3 stops, you still get the same picture - so Manual is Manual using the M-fn button.
Hockey and wedding photographer. Favourite camera / lens combos: a 1DX II with a Tamron 45 1.8 VC, an A7Rii with a Canon 24-70F2.8L II, and a 5DSR with a Tamron 85 1.8 VC. Every lens I own I strongly recommend [Canon (35Lii, 100L Macro, 24-70F2.8ii, 70-200F2.8ii, 100-400Lii), Tamron (45 1.8, 85 1.8), Sigma 24-105]. If there are better lenses out there let me know because I haven't found them.
PaulSoebekti
Joined Dec 2002
Jun 02, 2015 13:30 as a reply to  @ wallstreetoneil's post |  #13
I concur. Button doesn't adjust flash output.
Just FEC.
Paul
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Jun 03, 2015 21:02 |  #14
Heya,
I'm fairly certain he's using the flash off-camera with YN622's.
The 622TX is the way to go for power level adjustment from the camera.
Very best,
Wilt
Post edited over 8 years ago by Wilt. (2 edits in all)
Jun 03, 2015 23:09 |  #15
MalVeauX wrote in post #17583226 (external link)
Heya,
Very best,
Yup, while the OP neglected to supply this detail, in a later post he says, "I'm new at this and didn't want to do so much back and forth to the flash and where I'm shooting while I'm learning." So the Canon ST-3 should work for this as well, to provide the wireless control although forcing use of the camera's flash power control.
3,912 views & 0 likes for this thread, 10 members have posted to it and it is followed by 5 members.
1106 guests, 111 members online
