Thread started 03 Jun 2015 (Wednesday) 22:21
135mm f2 canon vs 100f2 canon vs 70mm sigma 2.8
burb1972
Joined Aug 2013
Jun 03, 2015 22:21 |  #1
just comparing the 3 lenses, can you tell which are which
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/06/1/LQ_730959.jpg
Image hosted by forum (730959) © burb1972 [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/06/1/LQ_730960.jpg
Image hosted by forum (730960) © burb1972 [SHARE LINK]
mike parker
gear list 5dc, tamron 19-35, tamron 28-75, 50mm 1.8 mark 1, 28-70 3.5 canon(x2), 100 f/2 canon, 70-300 usm is, helios 44-2, vpk lens put into a m42 cap attached to a bellows, 430 ex
burb1972
Joined Aug 2013
Jun 03, 2015 22:29 |  #2
also no pp at all, some reason red on the camera is set to a bit high. from hundreds of images, the 135f2 definitely focuses faster, generally has better image quality, but often the sigma is sharper and sometimes cant tell the 100f2 from the 135, but initially the 100f2 had a hoya filter on it.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/06/1/LQ_730961.jpg
Image hosted by forum (730961) © burb1972 [SHARE LINK]
mike parker
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Post edited over 8 years ago by MalVeauX. (3 edits in all)
Jun 03, 2015 22:37 |  #3
Heya,
Just guessing, the way the background to subject relation changes with telephoto focal length increase (ie, flatter background as focal length increases):
First: 100 F2
Second: 135 F2
Third: 70 F2.8
Very best,
burb1972
Joined Aug 2013
Jun 03, 2015 22:56 |  #4
these 2 are cropped for content, these 2 are at 2.8, one is the 135f2 and other is the 70mm sigma macro 2.8, no pp, but i cant really tell which is which
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/06/1/LQ_730970.jpg
Image hosted by forum (730970) © burb1972 [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/06/1/LQ_730971.jpg
Image hosted by forum (730971) © burb1972 [SHARE LINK]
mike parker
burb1972
Joined Aug 2013
Post edited over 8 years ago by burb1972.
Jun 03, 2015 23:09 |  #5
pouring thru the pictures, i had my kids label them so i didnt know which was which, ive found that its really hard to make a 135f2 take a bad picture. The 100f2 can look as good, but its not nearly as often, and the 70mm sigma is better than the 100f2 for standard portraits. 100f2 is better at sports, and focuses way quicker than the 70, but the 70 isnt bad. and the macro on the 70 is better than the 100(doesnt have one).
mike parker
Patrick ­ H
Joined Aug 2013
Jun 04, 2015 06:01 |  #6
70, 100, 135.
5D mkIV | 35Lii | 135L | + some zooms.
GeoKras1989
Joined Jun 2014
Jun 04, 2015 09:58 |  #7
I've had the 85 1.8, 100 2, and 135L. I still have the 100 f2. Of the three, I'd take the 135L in a second. Faster, more accurate focus and quite excellent wide open. The 135L and 18-55 II are two lenses I really regret selling. One is excellent, but expensive. The other is really good, and priced to be disposable.
WARNING: I often dispense advice in fields I know little about!
burb1972
Joined Aug 2013
Jun 04, 2015 19:52 |  #8
on the top of the ones at 2.8, the top one is the 70 and the bottom is the 135. The sigma 70 really holds its own against the 135.
mike parker
mickeyb105
Gallery: 397 photos
Joined Dec 2011
Jun 04, 2015 22:09 |  #9
Not sure what your shutter speed was with that last 135 L shot but it should be sharper IMO. The contrast is there, though. Up close that Macro really should be sharp and it is.
Sony A7RIII, Tamron 28mm 2.8 Di III OSD M1:2, Sonnar T* FE 55mm f/1.8 ZA, Canon 200mm 2.8L ii, Sigma MC-11, HVL-F43M
burb1972
Joined Aug 2013
Jun 04, 2015 23:18 as a reply to  @ mickeyb105's post |  #10
yea most from the 135 were better, camera is a 5d classic, cropped pretty heavy, 1/320 iso100, the boys were moving around alot.
The one i just added is more indicative of the 135.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/06/1/LQ_731152.jpg
Image hosted by forum (731152) © burb1972 [SHARE LINK]
mike parker
jimeuph1
Joined Jul 2014
Jun 05, 2015 00:41 |  #11
As far as the sharpness goes there is nothing in it at these file sizes.
You are changing the compression and the amount of focus falloff, do that test on a bride and ask which she prefers, I imagine the 135 followed by the 100 with her hating the 70 because she has seen the other two.
Each lens has its ideal use, sometimes you are in a small room and a 70mm is the only option to get the shot you want, other times you have the luxury of choice.
gqllc007
Joined Jan 2015
Jun 06, 2015 07:33 as a reply to  @ jimeuph1's post |  #12
The 135mm f/2 lens of mine seems to be very sensitive in regards to shutter speed and sharpness. I found I have to keep the shutter speed as high as I can to optimize the sharpness. IS would really benefit this lens. I have some 1/125 f2.8 with a flash that just arent sharp enough when zoomed in. They look fine at regular size. I love the bokeh and the compression but sometimes forget to get above 1/250 and even higher to maintain the sharpness
mclaren777
Joined May 2012
Jun 07, 2015 14:07 |  #13
I identified all three images correctly. :)
A simple comparison of sensor technology: Nikon vs. Canon (external link)
A technical comparison of sensor technology: Exposure Latitude (external link)
3,416 views & 0 likes for this thread, 8 members have posted to it and it is followed by 3 members.
1505 guests, 131 members online
