Thread started 05 Jun 2015 (Friday) 10:51
Dark Shadows?
Bracetty
Joined Dec 2012
Jun 05, 2015 10:51 |  #1
I just started shooting at some wide angles and noticed im getting dark shadows from my lens hood. After removing the hood I seem to still get shadows at 24mm? Is this just a result of the camera angle when focusing, or a possible issue? Im using my tamron 24-70 at 24mm
http://dopelahomacity.​tumblr.com/ (external link)
Canon 6D & 60D Gripped, Bower 85mm 1/4, Canon 50mm f1/4, 70-200 2.8 L IS V2, Canon 135mm 2.0 L, Tamron 24-70 2.8 VS, 2X Yongnuo 580
Trvlr323
Post edited over 8 years ago by Trvlr323.
Jun 05, 2015 11:20 |  #2
I think you may be referring to vignetting which is dark corners around the edges of the frame. This typically increases the wider you go. It can easily be removed in post processing.
http://en.wikipedia.or​g/wiki/Vignetting (external link)
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Post edited over 8 years ago by gonzogolf. (3 edits in all)
Jun 05, 2015 11:49 |  #3
It would help to show a sample, some vignetting is natural, but if its too strong it might be an indicator of a problem.
Kolor-Pikker
Jun 05, 2015 11:53 |  #4
nqjudo wrote in post #17585308 (external link)
I would say alleviated rather than removed, because you potentially get more noise in the affected areas, since they're less exposed.
Vignetting may be more or less visible depending on what you point the camera at, a flat sky or wall will really exaggerate the effect, even on lenses that don't have a lot of it.
Reviews of the Tamron 24-70 show that it has over 3 stops of vignetting at 24mm, which is quite a lot.
5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
I acquired an expensive camera so I can hang out in forums, annoy wedding photographers during formals and look down on P&S users... all the while telling people it's the photographer, not the camera.
Jon
Joined Jun 2004
Jun 05, 2015 11:55 |  #5
If you're getting vignetting on a crop body like the 60D in your sig., with a lens designed for a FF camera (the Tamron 24-70), there's something drastically wrong with the lens.
Jon
Cocker Spaniels
Bracetty
Joined Dec 2012
Jun 05, 2015 12:18 as a reply to  @ Jon's post |  #6
Would it still be vignetting the shadow shows on the bottom of the frame, not the corners? Let me snap a few, ive cropped it out of some other photos already
Bracetty
Joined Dec 2012
Jun 05, 2015 12:26 |  #7
Its a bit off center, had to crop out some personal stuff, but this is slightly tilted down with a very dark shadow right in the center of the image
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/06/1/LQ_731245.jpg
Image hosted by forum (731245) © Bracetty [SHARE LINK]
LonelyBoy
Gallery: 84 photos
Joined Oct 2014
Jun 05, 2015 12:32 |  #8
Bracetty wrote in post #17585382 (external link)
Hosted photo: posted by Bracetty in
./showthread.php?p=175​85382&i=i67408455
forum: Canon Lenses
That's... not vignetting. Hopefully someone can tell you what's actually wrong.
https://www.flickr.com​/photos/127590681@N03/ (external link)
I love a like, but feedback (including CC) is even better!
Craign
Gallery: 17 photos
Jun 05, 2015 12:41 as a reply to  @ LonelyBoy's post |  #9
I have seen that when using the built-in flash and a zoom lens extended.
Canon 7D Mark II w/Canon BG-E16 Battery Grip; Canon EOS 50D w/Canon Battery Grip; Canon SL1; Tokina 12mm - 24mm f/4 PRO DX II; Canon EF 24-105mm f/4L IS; Canon EF 70-200mm f/2.8L IS; Canon 70-300mm f/4-5.6L IS; Sigma 85mm f/1.4 EX DG HSM; Canon EF 300mm f/4L IS; Canon EF-S 18-135mm f/3.5-5.6 IS STM; Canon Extender EF 1.4x II; Canon Extender EF 2x II; Canon Speedlite 430EX II Flash
Image Editing Okay
Jon
Joined Jun 2004
Jun 05, 2015 12:45 as a reply to  @ Craign's post |  #10
Exactly! Your flash is too close to the camera, so the lens casts a shadow on your subject. With shorter lenses, it won't be a problem because they don't get in the way of the flash; with longer focal lengths, it won't be (as much of) a problem because they don't cover as wide an angle, so they don't "see" the shadow.
Jon
Cocker Spaniels
Kolor-Pikker
Jun 05, 2015 12:48 |  #11
Oh you have gotta be kidding me, that's obviously a shadow being cast from the lens. I haven't used camera flash, let alone built-in flash for many years, so I forget all about this.
Bracetty
Joined Dec 2012
Jun 05, 2015 12:49 as a reply to  @ Jon's post |  #12
Yes I forgot to mention, my built in flash was activated. So pretty much as long as theres a built in flash, this conflict will cause the shadow? Is this just a crop body problem+lens problem, like will this occur with all wide angles on this body if the built in flash is activated? Just wondering if the solution in this case is off camera flash, a different lens, etc. I will be going to FF soon and I don't want to buy the "wrong" gear leading up to the transition, just looking for the right deal on a 6D
DreDaze
Gallery: 49 photos
Post edited over 8 years ago by DreDaze.
Jun 05, 2015 12:51 as a reply to  @ Bracetty's post |  #13
it doesn't happen on FF, because they don't have a built in flash :)...if you're planning to go to FF, and you use a flash already, it's definitely a good idea to get an external flash now
but to totally answer your question, yes it will happen with just about every wide, big lens, and the built in flash
Andre or Dre
gear list
Instagram (external link)
Intheswamp
Endeavor to Persevere
Gallery: 89 photos
Joined Sep 2013
Jun 05, 2015 12:52 |  #14
Man, I thought somebody was doing a take-off of the old vampire series... :twisted:
Ed
The poorest of the poor. A country of children taking care of children: https://handsofloveusa​.org/ (external link)
My little weather page: www.beeweather.com (external link)
smythie
I wasn't even trying
Gallery: 31 photos
Jun 05, 2015 17:21 |  #15
DreDaze wrote in post #17585411 (external link)
Another factor in the circumstances is if you are really close to your subject. If your subject is a fair way from the camera that shadow would be out of the frame. In face even with a hot shoe mounted flash you could get that issue on a FF camera if you are close enough to the subject.
2,880 views & 0 likes for this thread, 12 members have posted to it and it is followed by 7 members.
Dark Shadows?
1050 guests, 111 members online
