Thread started 05 Jun 2015 (Friday) 12:37
nik silver efex pro 2 question
mantra
Jun 05, 2015 12:37 |  #1
hi
i use often nik silver efex pro 2 for my black and white
what i can 't do is isolate a part of the image with control points from the global adjustament
for example i want to add contrast to the all image but not on a part of the image
for example i took a shot , female body and sand and sea
i want to add contrast to all image but preserving the female body (i don't want to add contrast on her)
can i do it?
can i use global adjustament and control points (to protect some part of the image) ?
thanks
canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
3 analogic Hasselblad and 2 anologic Mamiya
olafs ­ osh
I am a nice and fluffy dude
Gallery: 146 photos
Best ofs: 5
Joined Apr 2012
Jun 08, 2015 04:52 |  #2
you can always make a dublicate with alternate adjustments and then combine the two using mask in PS.
- Olafs Osh
fb (external link) | instagram (external link) | YT (external link)|OLAFSOSH.COM (external link)|
Give us "Street Photography" sub-forum in P.O.T.N. !
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
Post edited over 8 years ago by Picture North Carolina.
Jun 08, 2015 10:36 |  #3
layers and masks
Website (external link) |
mantra
Jun 10, 2015 02:14 |  #4
osh_sekta wrote in post #17588445 (external link)
Picture North Carolina wrote in post #17588819 (external link)
layers and masks
ok , thanks
some nik plugin let to exclude the efect using control points like color efex pro 4 , sadly seems that silver efex 2 can't do it
thanks
BarrySpug
Joined Oct 2011
Post edited over 8 years ago by BarrySpug. (2 edits in all)
Jul 22, 2015 20:52 as a reply to  @ mantra's post |  #5
You could try doing the global adjustment first and then adding a separate control point just on the girl and dial down the contrast you did on the global adjustment?
Wouldn't that effectively isolate the girls contrast from the overall image? You could also use the nik selective brush option to just brush the contrast everywhere except on the girl. Or vice versa, use the brush option and select the erase option from the nik tools area to remove the contrast from the girl.
Canon 7D gripped | EF-S 18-135mm | EF 50mm 1.8 | EF 70-200mm F2.8 L IS II | Steady hand | Fingers Crossed
DagoImaging
Gallery: 20 photos
Joined Nov 2012
Jul 22, 2015 21:30 |  #6
Or don't do a global adjustment, use control points for the contrast you want and then put neutral control points on the girl to block the mask.
Sony a7R3a/a6300/ 16-70/4 / 70-200/4 G / 12-24/4 G/ 24-105/4 G /Sony HVL-60M
elrey2375
Thinks it's irresponsible
Joined Nov 2011
Jul 23, 2015 02:15 as a reply to  @ BarrySpug's post |  #7
You add the adjustment you want, then you hit minus instead of plus on the adjustment and place a point where you don't want the effect and it will negate the effect in that area. You can change the size, etc.
http://emjfotografi.co​m/ (external link)
http://500px.com/EMJFo​tografi (external link)
elrey2375
Joined Nov 2011
Jul 23, 2015 02:16 as a reply to  @ DagoImaging's post |  #8
this. it negates the adjustment you've made in that area only.
olafs ­ osh
Gallery: 146 photos
Best ofs: 5
Joined Apr 2012
Jul 23, 2015 03:12 |  #9
Never got that control points idea, as they are not so precise, as PS masks can be.
- Olafs Osh
DagoImaging
Gallery: 20 photos
Joined Nov 2012
Jul 23, 2015 19:31 |  #10
They affect a color range, you an show the mask they're affecting and it's quite ease to make them precise. Like anything it takes some learning to understand them and how they work.
3,317 views & 1 like for this thread, 6 members have posted to it and it is followed by 2 members.
1053 guests, 103 members online
