I purchased a Canon EF 24-70mm 2.8L Mark 1 lens from B&H around 2010 / 2011. This lens is certainly a problem lens when compared to my other Canon L lenses. Sometimes it works great, and other times the focusing just does not match up to my other Canon L lenses. I have found that it sometimes works better on my 5dmk2 than my 1dmk4, while still shooting at F2.8 on both bodies. On the whole it is just plainly unreliable.
I have done several tests (on both bodies mentioned) and tried micro-adjustments, but that only solves the problem to a certain extent. In my bodies (1dmk4 and 5dmk2) micro-adjustment can only be set for the full range of focal length of the particular lens. With the new 5dmk3 you can set different adjustments at different focal lengths. On my problem lens I can get it to focus properly (after making a micro-adjustment of only 1 increment) from 70mm down to about 40mm. In the range from 24mm to about 40mm, the micro-adjustment made for 40-70mm does not work at all.
I have no idea to what extent this lens needs technical attention.
Does anyone know if the latest firmware for the 1dmk4 and 5dmk2 might have a greater range in micro-adjustment, like the 5dmk3 has?
Any suggestions are very welcome.
