I have an EF 50mm f/1.4 USM lens that I bought to use on my 60D. It works great on that camera. It is very good, straight from f/1.4 - on the 60D. When I mount it on the 6D, it is just as good at f/1.4, out to about 10-12 feet. After than it hit or miss. Some shots are good, more than half are OOF. Lighting does not appear to matter; it does the same in bright sunshine, or indoors at night with flash. It is not just missing focus, MFA could cure that. It is inconsistent. If I take 10 shots of the same subject from the same distance (de-focusing between shots), I will get one dead-on, 2 or 3 close, and the rest either front- or back-focused. It does behave better if I stop down, but I still get OOF shots at f/2.8 & f/4 - just on the 6D. Is this lens just worn out? If so, why does it work so well on the 60D? Any ideas?
