Can somebody explain this concept to me because I've never understood it. I read all the time that increasing the ISO also increases the range/length that the light from the flash can reach? How is that possible?
Jun 14, 2015 09:41 | #1 Can somebody explain this concept to me because I've never understood it. I read all the time that increasing the ISO also increases the range/length that the light from the flash can reach? How is that possible? Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
malow Member 169 posts Likes: 2 Joined May 2009 Location: Brazil More info | Jun 14, 2015 09:53 | #2 at certain distance, the flash at full power don't have enough power to proper light a subject. but if you rise the ISO, the camera became more "sensitive" to light, so now the flash can "reach" a longer distance. (as the light became more "weak" with the increase distance from flash > subject) mods: http://www.flickr.com/photos/malow/
JohnSheehy Goldmember 4,542 posts Likes: 1215 Joined Jan 2010 More info | Jun 14, 2015 10:03 | #3 RandMan wrote in post #17596515 Can somebody explain this concept to me because I've never understood it. I read all the time that increasing the ISO also increases the range/length that the light from the flash can reach? How is that possible? What makes you think that photons from flash you used ten years ago aren't 10 light years away in space, heading away from planet earth?
Jun 14, 2015 10:37 | #4 John Sheehy wrote in post #17596543 What makes you think that photons from flash you used ten years ago aren't 10 light years away in space, heading away from planet earth? Light does not run out at a certain distance; it just spreads out and occasionally gets converted to heat or some other form of energy. The further away from your flash, the weaker the light, but it never has a limit to how far it goes at all. I understand physics (to a certain extent), but this does not help explain the relationship between ISO and flash range that I was inquiring about. Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
JohnSheehy Goldmember 4,542 posts Likes: 1215 Joined Jan 2010 More info | Jun 14, 2015 11:02 | #5 RandMan wrote in post #17596589 I understand physics (to a certain extent), but this does not help explain the relationship between ISO and flash range that I was inquiring about. There is a minimum amount and a maximum amount of light that a flash can give out. For ISO 100, this means a minimum and maximum distance for a "normal" ISO 100 exposure. For ISO 400, the minimum and maximum distances double. For ISO 1600, the distances are 4x what they are at ISO 100. Every doubling of distance causes a quartering of light.
mmmfotografie hanging up-side-down in a cave 2,114 posts Likes: 492 Joined Jul 2013 Location: Helsinki Airport More info Post edited over 8 years ago by mmmfotografie. | Jun 14, 2015 11:06 | #6 The light you see is direct light if you stand in front of the flash or in direct light if you stand behind of the flash (reflected).
oldvultureface Goldmember More info | Jun 14, 2015 12:29 | #7 Your subject is two feet from your flash and it's properly exposed. Move your subject four feet away and it will receive one-quarter of the flash's light; it will be two stops underexposed. Change your ISO from 100 to 400 (two stops) and, with the same flash intensity, your subject will be properly exposed.
dmward Cream of the Crop More info | Jun 14, 2015 22:12 | #8 Light from a point source spreads based on the inverse square law. i.e. if light is quantity X at 1 unit it is 1/4 the quantity at 2 units (2x2=4) David | Sharing my Insights, Knowledge & Experience
Jun 15, 2015 00:12 | #9 |
| Latest registered member is semonsters 1061 guests, 103 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
