for the 5D3? Anyone, got an unusually high file name with the prefix of _N6A7699 for a file name
RichSoansPhotos Cream of the Crop 5,981 posts Likes: 44 Joined Aug 2007 Location: London, UK More info | Jun 14, 2015 15:44 | #1 Permanent banfor the 5D3? Anyone, got an unusually high file name with the prefix of _N6A7699 for a file name
RichSoansPhotos THREAD STARTER Cream of the Crop 5,981 posts Likes: 44 Joined Aug 2007 Location: London, UK More info Post edited over 8 years ago by RichSoansPhotos. | Jun 14, 2015 16:39 | #2 Permanent banI see it's a lightroom problem coming up with all the rubbish file names, but it still says 100-7966 which is really strangely high for a new camera
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Jun 14, 2015 17:28 | #3 Rich, don't forget if you insert a card with a higher "numbered" file already on it, if you use continuous numbering, the camera will continue numbering from the next number of that card, if that number is higher than it's internally remembered number. I have my numbering set up this way on my camera. At a two day airshow that I shot recently I ended up screwing badly with my file names, as I was shooting multiple cards, and I rolled over during the day. As I was swapping cards about I popped a previously swapped card (I had changed it early so that I could get a single display item without a card change (and reset of ML settings) in the middle) to fill it up with the last few shots. This then reset the numbering, so I ended the day with about a 100 files with the same file name. Not something you would normally expect to happen.
RichSoansPhotos THREAD STARTER Cream of the Crop 5,981 posts Likes: 44 Joined Aug 2007 Location: London, UK More info | Jun 14, 2015 17:36 | #4 Permanent banBigAl007 wrote in post #17596971 Rich, don't forget if you insert a card with a higher "numbered" file already on it, if you use continuous numbering, the camera will continue numbering from the next number of that card, if that number is higher than it's internally remembered number. I have my numbering set up this way on my camera. At a two day airshow that I shot recently I ended up screwing badly with my file names, as I was shooting multiple cards, and I rolled over during the day. As I was swapping cards about I popped a previously swapped card (I had changed it early so that I could get a single display item without a card change (and reset of ML settings) in the middle) to fill it up with the last few shots. This then reset the numbering, so I ended the day with about a 100 files with the same file name. Not something you would normally expect to happen. Alan Ah, that probably explains it, thanks
RichSoansPhotos THREAD STARTER Cream of the Crop 5,981 posts Likes: 44 Joined Aug 2007 Location: London, UK More info | Jun 14, 2015 18:00 | #5 Permanent banAnd I've solved the file naming sequence..........Yes, you've got the option to change it to either 4Nxxx, IMG or IMG+File size (weird) also other additional options....boom boom bye
| Latest registered member is semonsters 1476 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
