GeoKras1989 wrote in post #17603340
You don't say what you are shooting with. That is invaluable information when requesting in-camera settings.
If you are shooting Canon, turn on Auto-Lighting Optimizer, and turn it all the way up. I don't use it, but what you are trying to accomplish is its stated goal. It doesn't work in Manual mode, for some reason.
I'm shooting RAW on 5D Mark III and more importantly film. When I say in-camera I'm not talking about settings, I'm talking about creating a certain light style before I push the shutter regardless of the camera. ALO is not necessary or possible for all my cameras.
Left Handed Brisket wrote in post #17603370
i would start with a large reflector on the opposite side of the bed sheet, even another bed sheet will work but something opaque would work better. What is your current v-flat made out of?
what kind of softboxes do you have?
also, have you tried using the Levels tools rather than contrast? I literally never use the contrast slider. Levels will allow more precise control of what values you are pushing around.
I can put another large reflector on the shadow side of the portrait, no problem. My current v-flats are foam-core. I'm not using softboxes for this, but I do have a 3x4' one and soft large softlighter umbrellas. In this setup, I'm creating my own giant softbox by bouncing the light inside some v-flats, the front of it is the bedsheet if that makes sense. Yes I can use anything in post to get my desired contrast but I'm asking about how to do this without post because I want my lighting to be closer to my final vision without editing. Also I shoot film so editing that is not as easy as a RAW file.
Alveric wrote in post #17603372
Pull the curtain farther away from the wall, then move the model closer to the curtain. Then add another curtain or some reflecting material like foamcore on the other side of the main light: you'll probably need to test with different distances and angles for this one till you achieve the desired effect.
What do you mean curtain, like the bedsheet front of the light source? What wall are you talking about that I should pull it away from? And wouldnt moving the model closer to the light boost the hotspots?
