Poe wrote in post #17605026
What's the goal of this comparison under these settings?
I had a few goals / questions that I wanted answered:
- don't know until you do it so I wanted to do it and see what it looked like
- when you get the 5DSR 6400 is the high ISO with 12,800 turned off, labeled as H, and yet not so with the 7d2 that actually goes up to 16,000 with H labeled as 25,600
- this test proved to me that this is complete BS and in fact you could more than easily the opposite should be true if you take pixel density on subject into consideration - especially with modern NR software
- even though the sensors has very similar pixel density they are different sensors so I wanted to see if there actually was a difference - they appear basically similar
- modern NR software really is amazing and you can get usable images (absolutely not commercial quality) but software can take a pretty ugly 12,800 ISO image and make it useable - and if you have 50 megapixels like on the 5DSR, and you have enough practice with NR / sharpening / masking / etc, you can use this increased pixel information to your advantage and get a way better end result image than you would expect or deserve
Hockey and wedding photographer. Favourite camera / lens combos: a 1DX II with a Tamron 45 1.8 VC, an A7Rii with a Canon 24-70F2.8L II, and a 5DSR with a Tamron 85 1.8 VC. Every lens I own I strongly recommend [Canon (35Lii, 100L Macro, 24-70F2.8ii, 70-200F2.8ii, 100-400Lii), Tamron (45 1.8, 85 1.8), Sigma 24-105]. If there are better lenses out there let me know because I haven't found them.
