Why is USM (Unsharp Mask) is applied as a last procedure in photo manipulation just before saving?
msvirick Senior Member 257 posts Joined Jul 2003 More info | Jul 27, 2003 07:14 | #1 Why is USM (Unsharp Mask) is applied as a last procedure in photo manipulation just before saving? Canon 5D
Sheri Member 215 posts Joined May 2003 More info | Jul 27, 2003 09:10 | #2 Maybe this will help --
Jul 27, 2003 12:19 | #3 Thank you Sheri, this is the first time I understood this concept. Canon 5D
Jul 28, 2003 21:53 | #4 Sheri wrote: Maybe this will help -- http://www.microsoft.com …more/fixit/sharpening.asp Actually it says there are two times sharpening should be done depending on the whether the sharpening is to compensate for a camera's low pass filter or to compensate for the softening effect of the output process. The first one should be done after all other editing (especially any noise reduction because noise gets amplified by sharpening), but before resizing/resampling. The second should done after resizing/resampling. Regards, Sheri I read somewher that the first pass USM could entirely be done outside the camera, if this compensation (sharpening) is disabled in the camera. Can the camera sharpening can be diaabled in the Canon 10D. I went thru the menus, but could not find this option. Canon 5D
GuillermoFreige Senior Member 704 posts Joined Jun 2003 Location: La Plata, Argentina More info | Jul 28, 2003 22:14 | #5 Usually the lower sharpening setting (-1 in my S50) disables in-camera sharpening. If you shoot in RAW, you can change it during conversion too. Guillermo
Jul 30, 2003 20:16 | #6 On a average shot that is well focused and in balance, what are the usual amonts of the slider settings for the 1st and 2nd pass USM Canon 5D
GuillermoFreige Senior Member 704 posts Joined Jun 2003 Location: La Plata, Argentina More info | Jul 30, 2003 20:40 | #7 I'm usually use 250-500% (depending the picture), 0.2, 0-3 (again, depending the noise) for well focusing pictures and 150-300%, 0.3-0.4, 0-3 for not so well focused ones for the first pass (for S50 low-sharpening RAW files). If rescaled, i'm aplying the first set of numbers again. I'm printing in a continuous tone dye-sublimation printer. As fas as I know, inkjet printers need more sharpening. Guillermo
ryuwulf Senior Member 369 posts Joined Jun 2003 More info | Jul 31, 2003 00:14 | #8 USM totally depends on the picture/situation and should be done as the very last step before exporting your image.
Aug 05, 2003 22:31 | #9 Could these settings be saved and applied as a macro? Canon 5D
ryuwulf Senior Member 369 posts Joined Jun 2003 More info | Aug 06, 2003 15:46 | #10 ummm what settings??
| Latest registered member is IoDaLi Photography 1741 guests, 134 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
