Thread started 25 Jun 2015 (Thursday) 02:16
Telephoto confusion
davholla2
Joined Jun 2015
Jun 25, 2015 02:16 |  #1
I have a Canon EF 70-300mm f/4.0-5.6 IS USM Lens and I would like to a bit more reach.
I am torn between
Sigma 150-600 C
Tamron 150-6000
or may be a second hand Canon 100-400 like this as some reviews imply that this could be almost as good
EXCELLENT Canon 100-400mm USM Telephoto Lens eBay
or maybe my existing lens with a teleconverter
This will be used mainly with a Canon 350 D or Canon 550D for birds/mammals any ideas?
The more I read the more confused I get
hania
Post edited over 8 years ago by hania. (2 edits in all)
Jun 25, 2015 02:24 |  #2
Why not get a canon 400 5.6 ? It hasn't got IS , but at shutter speeds of 1600-2000+, not necessary.
I have the canon 28-300 and the prime matches brilliantly.
Be very careful when getting a used 100-400, (I assume the ebay one is the old version- they seem to range from excellent to awful.) The new one has great reviews.
If you are keeping the 70-300, you have a tremendous amount of overlap - I had the 100-400, and hardly ever used the 28-300.
Never regretted selling it & getting the 400.
I have the 7d2 and 5D3 and often carry the 28-300 on the 5d2 and the 400 on the 7D2, so quite a lot of range covered.
Also, make sure that your camera can AF with a teleconverter - I found my 100-400 would not AF on a 7D , as the minimum aperture was then f8.
davholla2
Joined Jun 2015
Jun 25, 2015 06:20 as a reply to  @ hania's post |  #3
The canon 400 5.6 is a more expensive option from http://www.valuebasket​.com/ (external link) the Sigma is £ 624.99 the cheapest fro the canon 400 5.6 £ 859.00. Also it was the worst performer when Tony Northrup tested them.
When/if I decide what to do then I will decide what to do with my other lens.
johnf3f
Jun 25, 2015 17:52 |  #4
davholla2 wrote in post #17609991 (external link)
That will teach you not to read too much on the web!
Much of what Tony says makes sense but, I am afraid, much of it does not!
I have not, personally, tried the Sigma 150-600 C version but I have tried the other two and would take the Canon 400 F5.6 L in a heartbeat! From my experience it is simply a better lens, quicker (much) AF and better IQ as well as being lighter and having a larger aperture. The larger aperture is important as the Canon 400 F5.6 produces great results wide open, the Tamron needs to be stopped down a bit to get the best from it - I believe it is the same with the Sigma.
You do loose out on the zoom function and the compromises that that brings, but you do have a small, light, slim lens that is one of the best going for the price.
Just my 2p!
Life is for living, cameras are to capture it (one day I will learn how!).
Sgt.
Gallery: 56 photos
Jun 25, 2015 20:23 |  #5
https://m.flickr.com …randsheasdad/18​069300993/ (external link)
Love my 400 F 5.6!
Iain
7D MKII
Another minion in the Pondrader fan club
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Jun 25, 2015 20:26 |  #6
No teleconverters, the math is the only part thst works, otherwise its not satisfying. You would lose autofocus and youf quality would suffer.
hania
Jun 26, 2015 05:43 |  #7
Agreed!
Roy ­ C
Jun 26, 2015 14:19 |  #8
I have owned the Tammy 150-600, the Sigma C 150-600 as well as the Canon 400/5.6 (must have taken 100k of shots with the Canon over more than 8 years).
The Sigma C is better than the Tamron IMO - I sold the Tammy and later bought a Sigma C which I still have.
Until recently I had both the Sigma C and Canon 400/5.6 and tested both combos extensively. At 400mm the Canon 400/5.6 is a little better than the Sigma but not by much. The Sigma at 600mm is certainly better than the 400/5.6 + 1.4x tc (I tested on both the 5D3 and 7D2). I also tested the two many times by cropping 400/5.6 images to the same FOV as the Sigma at 600mm and the Sigma yields better detail for sure.
Both have their pros and cons:-
For the 400/5.6 is AF speed, lighter weight, slightly better IQ at 400mm and pin sharp wide open.
For the Sigma is 600mm focal length, zoom range, better MFD, a good OS system and some very useful customizations via the option USB dock. Also the Sigma takes a 1.4x tc remarkable well giving 840mm when you are range limited - although the sigma is at f9 with a 1.4x tc it still AF's OK on both my 5D3 and 7D2, AF speed with the Sigma at 840mm is similar to the 400/5.6 at 560mm.
If your main interest is BIF then the Canon is still a very good buy but if you are often finding yourself range limited then the Sigma is great value for money and the better lens IMO. I have since sold my much loved 400/5.6.
A few years ago I tried a Sigma 150-500 and was very disappointing to say the least - this new generation of 150-600 lenses are in a different league to those older lenses from the likes of Sigma and Tamron.
TOP BIRD SHOTS (external link)
MY PHOTOSTREAM (external link)
500px gallery (external link)
don1163
Gallery: 27 photos
Joined May 2015
Jun 26, 2015 15:16 |  #9
Canon 400 5.6 all day long....fast AF and excellent IQ. I use a 1.4x converter on mine and get very good results...manual focus is the only downside..but then everything was manual focus before we had AF...ߘ
1DX, 500L f4, 70-200L f2.8II, 100L f2.8 macro ,16-35 f4, 1.4xIII, Metz 64-AF1
johnf3f
Jun 26, 2015 16:10 |  #10
Roy C wrote in post #17611553 (external link)
Interested in your observations on the Sigma Roy.
I have tried a few Sigma long zooms and been disappointed, but (as per my post) I haven't tried the 150-600 C. Sounds like it is a pretty good lens in your experience. Probably well worth the OP considering one.
oscardog
Joined Dec 2011
Jun 26, 2015 18:43 |  #11
Havent owned the Sigma or Tamron but I had the 400 5.6 for awhile. Fast AF, very sharp, light weight and relatively small size. Works great with a 1.4 tc as well. I would be looking at getting one of those over the zoom lenses.
Gear: 6D, 7d Mark II, Rokinon 14mm 2.8, Canon 16-35 f4 IS, Sigma 24mm 1.8, Canon 70-200 f4 (non IS), Sigma 500 4.5 DG, Kenko 1.4x & 2x converters
Roy ­ C
Jun 27, 2015 02:50 |  #12
Here is a sample of the Sigma 150-600 C for BIF taken at the full 600mm, I would not have gotten this shot with a 1.4x tc on my 400/5.6 that's for sure.
IMAGE: http://i130.photobucket.com/albums/p267/RoyC_photo/Sigma%20150-600%20C/swallow%20in%20flight1_zpsjxbnzmye.jpg
IMAGE LINK: http://i130.photobucke​t.com …20flight1_zpsjx​bnzmye.jpg  (external link) on photobucket
Roy ­ C
Post edited over 8 years ago by Roy C. (2 edits in all)
Jun 27, 2015 03:02 |  #13
Here are just a few typical samples from the 150-600 C all taken at the full 600mm. Not up to the big white primes but not bad for the money. AF is a lot quicker than the 400/5.6 + 1.4x tc (and I am the biggest fan of the 400/5.6).
IMAGE: http://i130.photobucket.com/albums/p267/RoyC_photo/Sigma%20150-600%20C/stone05_zpstz7pg7ve.jpg
IMAGE LINK: http://i130.photobucke​t.com …C/stone05_zpstz​7pg7ve.jpg  (external link) on photobucket
IMAGE: http://i130.photobucket.com/albums/p267/RoyC_photo/Sigma%20150-600%20C/young%20robin2_zpstfsi3tb4.jpg
IMAGE LINK: http://i130.photobucke​t.com …%20robin2_zpstf​si3tb4.jpg  (external link) on photobucket
IMAGE: http://i130.photobucket.com/albums/p267/RoyC_photo/Sigma%20150-600%20C/dunny1_zpswph8zvfu.jpg
IMAGE LINK: http://i130.photobucke​t.com …0C/dunny1_zpswp​h8zvfu.jpg  (external link) on photobucket
IMAGE: http://i130.photobucket.com/albums/p267/RoyC_photo/Sigma%20150-600%20C/swallow1_zps7l7282gr.jpg
IMAGE LINK: http://i130.photobucke​t.com …/swallow1_zps7l​7282gr.jpg  (external link) on photobucket
IMAGE: http://i130.photobucket.com/albums/p267/RoyC_photo/Sigma%20150-600%20C/great%20tit1_zpsyvhxzv6p.jpg
IMAGE LINK: http://i130.photobucke​t.com …at%20tit1_zpsyv​hxzv6p.jpg  (external link) on photobucket
Roy ­ C
Jun 27, 2015 03:17 |  #14
Just to finish off here for anyone that is interested here is a sample of the Sigma 150-600 C taken with a 1.4x tc at the full 840mm (AF on both my 7D2 and 5D3 is just as quick as the 400/5.6 + 1.4x tc). For those that want more reach and do not want the weight or expenditure of big white primes this little lens is excellent value for money IMHO.
IMAGE: http://i130.photobucket.com/albums/p267/RoyC_photo/Sigma%20150-600%20C/gold1%20at%20840mm%20x%201200px_zpsliiloa65.jpg
IMAGE LINK: http://i130.photobucke​t.com …%201200px_zpsli​iloa65.jpg  (external link) on photobucket
johnf3f
Jun 27, 2015 17:47 |  #15
Nice shots Roy!
7,043 views & 2 likes for this thread, 9 members have posted to it and it is followed by 7 members.
Telephoto confusion
1173 guests, 122 members online
