I plan to purchase a 6D this week as I upgrade to full-size sensor. My only Canon Speedlight is an E-TTL (380EX). Will this work with the 6D, or will I need to get a new E-TTL II flash unit?
doctordare Member 49 posts Joined Aug 2010 More info | Jun 25, 2015 19:43 | #1 I plan to purchase a 6D this week as I upgrade to full-size sensor. My only Canon Speedlight is an E-TTL (380EX). Will this work with the 6D, or will I need to get a new E-TTL II flash unit?
GeoKras1989 Goldmember More info Post edited over 8 years ago by GeoKras1989. | Jun 25, 2015 20:29 | #2 Permanent bandoctordare wrote in post #17610706 I plan to purchase a 6D this week as I upgrade to full-size sensor. My only Canon Speedlight is an E-TTL (380EX). Will this work with the 6D, or will I need to get a new E-TTL II flash unit? All EX models will work with the 6D. I think you may have to upgrade to at least the 430EX II to be able to use on-camera menus to manage the flash. If you just use FEC, and Manual mode, you really don't need the on-camera menus. That said, they are really convenient. You'll love the 6D. WARNING: I often dispense advice in fields I know little about!
Thanks for your help. I think I'll hold off on buying a new flash until I get to use the 6D for a while and try my existing flash. I don't use the built in flash on my current EOS very much, except for some occasional fill-in. I want to take advantage of the current $300 savings with the 24-105L (but there aren't any major deals right now on flashes).
zoom_zoom Senior Member 903 posts Likes: 67 Joined Dec 2008 Location: AB, Canada More info | Jun 25, 2015 20:40 | #4 You may find that the high ISO capabilities of the 6D are good enough that you don't need a flash
Jun 25, 2015 21:03 | #5 Permanent banzoom_zoom wrote in post #17610766 You may find that the high ISO capabilities of the 6D are good enough that you don't need a flash ![]() True. I use flash when/where I need it. But full frame and fast primes can change the way you shoot. WARNING: I often dispense advice in fields I know little about!
Good point! We recently travelled to Australia and my wife convinced me I "needed" a Sigma 150/2.8 macro. With the aperture and image stabilization, plus ISO 1600 (max on my current camera), I got incredible zoo shots - even in the indoor displays.
apersson850 Obviously it's a good thing More info | Jun 26, 2015 05:07 | #7 GeoKras1989 wrote in post #17610746 I think all of the EX units are ETTL-II. That depends on what you use them with. E-TTL vs. E-TTL II is a function of the camera, not the flash. If the flash supports E-TTL, then it automatically supports E-TTL II as well. Anders
Jun 26, 2015 06:30 | #8 Permanent banapersson850 wrote in post #17611057 That depends on what you use them with. E-TTL vs. E-TTL II is a function of the camera, not the flash. If the flash supports E-TTL, then it automatically supports E-TTL II as well. Flashes supporting in-camera menus are those from the 580 EX II and later. 430 EX II is included, but 380 EX is not. Correct, of course. Thanks. WARNING: I often dispense advice in fields I know little about!
Thanks for the info. I can manage without the in-camera menus; I just want the flash to synch with the camera on the periodic occasions I might want to use it. Camera (6D), 24-105L, and battery grip scheduled to arrive Tuesday!
BillEmmett Member 201 posts Likes: 10 Joined May 2012 Location: New Orleans, Louisiana More info | Jun 29, 2015 17:22 | #10 Hi, I shoot with the Canon 6D. I wanted a flash to fill on some of my back lite subjects. I decided on the Canon Speed Lite 270 EX. It states in the booklet it works with ETTL and ETTL II, and all the flash control is performed on the camera side in the same manner as a built in flash. Since this is exactly what I wanted I bought it. This flash is small, and easily fits in your pocket, and only uses 2 batteries. Best of all, I bought it new from B&H for $139.00 New Canon EOS 5D Mark IV, Canon EOS 7D Mark II, Canon EOS 50D, Canon 7D Classic, Canon 6D, Canon EF 70-200 f4L USM with IS, Canon 40mm pancake, Canon EF 50mm 1.8, Canon EF-S 10-22mm wide angle, Canon EF-S 18-135 IS STM, Canon EF 100mm 2.8L USM Macro, Tamron 18-270mm Dii VC, Tamron SP 150-600mm VC, Tamron SP 24-70mm f2.8 VC USM, Canon EF 16-35 f2.8L II USM, Tamron 2X Tele-Extender, 1.4 Tele-extender
Jun 29, 2015 19:26 | #11 Permanent banBill Emmett wrote in post #17614850 Hi, I shoot with the Canon 6D. I wanted a flash to fill on some of my back lite subjects. I decided on the Canon Speed Lite 270 EX. It states in the booklet it works with ETTL and ETTL II, and all the flash control is performed on the camera side in the same manner as a built in flash. Since this is exactly what I wanted I bought it. This flash is small, and easily fits in your pocket, and only uses 2 batteries. Best of all, I bought it new from B&H for $139.00 Yes. I bought a 270EX II for use on my G15. It is wonderful on the 60D and 6D, also. I use it often. WARNING: I often dispense advice in fields I know little about!
gonzogolf dumb remark memorialized More info | Jun 29, 2015 19:39 | #12 zoom_zoom wrote in post #17610766 You may find that the high ISO capabilities of the 6D are good enough that you don't need a flash ![]() Good use of a flash has less to do with quantity of light and more to do with the quality and direction of light.
I have considered the 270 EX, as it sounds like it would fit my needs. However, I'll go ahead and get used to the camera and try it with my 380 EX. Thanks to everyone for their help and advice.
gonzogolf dumb remark memorialized More info | Jul 02, 2015 07:15 | #14 If you decide to buy a flash, go ahead and get the 430exIi. A full sized flash is easier to use with bounce cards, or other modifiers.
MakisM1 Cream of the Crop More info Post edited over 8 years ago by MakisM1. | Jul 02, 2015 08:32 | #15 I have 2 Canon 430 EXIIs. I recently bought from a friend a Yongnuo YN568II. It offers all the features of the 430 EXII (the ones I use, anyway) and it can also serve as a Master. You don't have an onboard flash on the 6D, so having a flash with Master capability may be important to you. Gerry
| Latest registered member is Frankie Frankenberry 1833 guests, 144 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
