Thread started 30 Jun 2015 (Tuesday) 14:29
OK the last real decision - which Graphics card Nvidia K620 or K2200
Submariner
Joined May 2012
Jun 30, 2015 14:29 |  #1
Pretty much decided ( so long as the promised discount materialises ) everything but, which Graphics card should I go for.
Basic Specs :-
K2200.
RAM 4 GB GDDR5
Memory Bandwidth 80 GB/s
Cuda Cores 640
Memory Interface 128 - bit £399
K2200.
RAM 4 GB GDDR5
Cuda Cores 640
Memory Interface 128 - bit £396
K620
RAM 2 GB DDR3
Memory Bandwidth 29 GB/s
Cuda Cores 384
Memory Interface 128 - bit £142
Both do 3840 x 2160 ( 4K )
Main use Photoshop Elements 12, with Portraiture Plugin, Cannon DPP4.
5DIII and 5DS R Raw files.
Later maybe ad hoc. Premier Elements very basic video editing
The most likely system
HP640
E5 1650 Ver 3. 3.5GHz in Turbo Mode 3.8 GHz. 15MB Ram cache - 6 Core 12 Threads, max Memory Bandwith 68 GB.
16 - 2x 8 GB Ram
128GB SSD HP
400GB SSD Intel 750 series
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
Kolor-Pikker
Post edited over 8 years ago by Kolor-Pikker. (2 edits in all)
Jun 30, 2015 16:02 |  #2
Hmm toss a coin?
The 2200 has twice the cores, but Premiere is the only application that will potentially make use of them.
As programs make more use of GPU acceleration over time, you could start seeing the faster card making performance returns, but who knows, it could be obsolete by then as well.
If you go with the cheaper card, maybe you can put the funds to get Adobe Lightroom instead of having to suffer with Elements and DPP.
5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
I acquired an expensive camera so I can hang out in forums, annoy wedding photographers during formals and look down on P&S users... all the while telling people it's the photographer, not the camera.
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Jun 30, 2015 16:27 |  #3
None of the software listed, including Premier Elements, makes any use of the GPU, so get the one with the connections on it that work with the monitors you want.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
Post edited over 8 years ago by EverydayGetaway.
Jun 30, 2015 17:44 |  #4
As you were advised in numerous other threads, get the cheapest card you can that has Display Port out (just about any card on the market does and will run 4K for stills easily).
Fuji X-T3 // Fuji X-Pro2 (Full Spectrum) // Fuji X-H1 // Fuji X-T1
flickr (external link) // Instagram (external link)www.LucasGPhoto.com (external link)
Bleufire
Jun 30, 2015 18:18 |  #5
Get the most expensive one.
That seems to be your past decision making.
5D*Sigma 50/1.4*EF 17-40/4
New to Photography? ----> ENJOY! Canon DSLR! (external link)
Submariner
Joined May 2012
Jun 30, 2015 19:16 |  #6
Bleufire wrote in post #17616211 (external link)
The overkill is only due to the superb discount I can get through a past contact. It will work out to with a £100 of the cheapest i7 4790K system.mhence ai want a real quality chassis and processor. Buying the Ram built to order gets the big discount - whereas adding it later is at commercial rates. Hence that swung me.
Regarding the GPU card for still only I would absolutely go for the K620 but as one gets into video in the future I wonder if I will reget it.
Submariner
Joined May 2012
Jun 30, 2015 19:16 |  #7
EverydayGetaway wrote in post #17616191 (external link)
Does Premier elements not off load some of the processing when rendering?
-dave-m-
Gallery: 6 photos
Joined Sep 2011
Jun 30, 2015 19:42 |  #8
If you ever plan to use dual 4k monitors go with the K2200, If you will never need more than 1 display port go with the K620.
5D MkII Gripped | 7D MkII Gripped | 200 f/2.8L | 17-40 f/4L | Σ 24-105 OS f/4 Art | Σ 50 f/1.4 Art | Σ 150-600 OS f/5-6.3 C | 430EX II
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
Jun 30, 2015 19:59 |  #9
Submariner wrote in post #17616261 (external link)
I still think that's sort of rabbit hole logic... a top spec i7 is "only" $150 more than a top spec i5, a GTX 980 is "only" $150 more than a GTX 970, etc...
But it's your money, burn it how you want to, just don't expect us all to think you're doing it right or to stop giving you the advice we think is.
You say you do video or will in the future but don't specify what. Most GPU's (even low end ones) will have no problem playing back and doing basic cuts and edits of 4k video, it's not until you start really asking more out of it by doing rendering that it could become an issue, in which case... cross that bridge when you come to it. IMO you're building a 50ft bridge to cross a 10ft stream.
Submariner
Joined May 2012
Jul 01, 2015 06:53 as a reply to  @ -dave-m-'s post |  #10
Submariner
Joined May 2012
Jul 01, 2015 06:57 |  #11
EverydayGetaway wrote in post #17616310 (external link)
Appreciate your input. And see your point about the complexity of video and the impact on the selection of a graphics card.
3,090 views & 1 like for this thread, 6 members have posted to it and it is followed by 3 members.
1277 guests, 136 members online
