I believe Canon started adding the ability to upgrade the firmware on it's lenses starting sometime in 2012. Cameras produced after that date have two categories for firmware updates: Camera or lens. The 1D X, 5D Mark III, and 650D/T4i were the first cameras to have this option.
If you have an older camera, or older lens, you won't see the option for lens firmware upgrade.
Image hosted by forum (
735232)
© msowsun [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Here is a link to Canon's firmware update page:
http://www.usa.canon.com …upport-_-Firmware+Updates
The EF 40mm 2.8 STM had a firmware update to deal with a problem where it would go dead if you pushed in the front element.
Firmware Version 1.2.0 addresses the following phenomenon.
1. If pressure is applied to the lens barrel while the lens is mounted to the camera (pressure can be applied even while attaching
the lens cap while carrying the camera with the lens attached in a bag), the autofocusing function of the lens may stop working.
Firmware Version 1.2.0 is for lenses with Firmware Version 1.1.0. If the lens’ firmware is already Version 1.2.0, it is not necessary to update the firmware.
The lenses with the following serial numbers are equipped with Firmware Version 1.1.0:
The third digit in the serial number is either 0, 1, or 2 (xx0xxxxxxx, xx1xxxxxxx, or xx2xxxxxxx).
Lenses with serial numbers other than those listed above are equipped with Firmware Version 1.2.0.
● If an extension tube, or cables, such as USB cables, are attached to the camera, the firmware may not be successfully updated,
so make sure that you detach the extension tube, and/or cables before updating the firmware.
● A supported camera* is required for the firmware update.
