Thread started 11 Jul 2015 (Saturday) 12:29
Sigma 150-600 sport help
Nascar ­ Nut
Joined Feb 2004
Post edited over 8 years ago by Nascar Nut. (2 edits in all)
Jul 11, 2015 12:29 |  #1
My wife and I recently went to Yellowstone. I have been working through all my photos and I have a question. I will post an uncropped resized and a 100% crop for examples. This bear was between 100 and 150 yards away. I took several shots of him. I didn't have my tripod but had the camera was supported on a tree with the Os (IS) turned on. Shutter was 1600. As you can see in the crop, nothing is in focus. The focus point was on his shoulder. Every shot of this bear turned out like this. Is there something about this scene that my camera could not get a good focus? Maybe I shouldn't have had the OS on since I had it supported against a tree. Maybe I am expecting to much from a crop at this distance. My camera is a 7D Mark ll. I have hand held this setup at 600mm with great results with a lot slower shutter speeds but the subject was a lot closer. I am just trying to get a handle on what I can expect out of my setup. Maybe I am doing something wrong or I have an issue with my lens. I took some shots of other grizzlies with my tripod at similar distances but slower shutter speeds and it seems they turned out about the same.
IMAGE: http://the-outdoorsman.net/yellowstonephotos/sample100.jpg
IMAGE: http://the-outdoorsman.net/yellowstonephotos/sample101.jpg
Complete exif
ExifTool Version Number : 9.98
File Name : IMG_8241.CR2
Directory : F:/Photos/15 Photos/Yellowstone
File Size : 27 MB
File Modification Date/Time : 2015:07:04 11:26:11-05:00
File Access Date/Time : 2015:07:06 15:50:19-05:00
File Creation Date/Time : 2015:07:06 15:50:19-05:00
File Permissions : rw-rw-rw-
File Type : CR2
File Type Extension : cr2
MIME Type : image/x-canon-cr2
Exif Byte Order : Little-endian (Intel, II)
Image Width : 5472
Image Height : 3648
Bits Per Sample : 8 8 8
Compression : JPEG (old-style)
Make : Canon
Camera Model Name : Canon EOS 7D Mark II
Preview Image Start : 52888
Orientation : Horizontal (normal)
Preview Image Length : 4016726
X Resolution : 72
Y Resolution : 72
Resolution Unit : inches
Modify Date : 2015:07:04 11:26:10
Artist : The Outdoorsman
Rating : 0
Copyright : Photography By KC
Exposure Time : 1/1600
F Number : 6.3
Exposure Program : Aperture-priority AE
ISO : 400
Sensitivity Type : Recommended Exposure Index
Recommended Exposure Index : 400
Exif Version : 0230
Date/Time Original : 2015:07:04 11:26:10
Create Date : 2015:07:04 11:26:10
Components Configuration : Y, Cb, Cr, -
Shutter Speed Value : 1/1579
Aperture Value : 6.4
Flash : Off, Did not fire
Focal Length : 600.0 mm
Macro Mode : Normal
Self Timer : Off
Quality : RAW
Canon Flash Mode : Off
Continuous Drive : Single
Focus Mode : One-shot AF
Record Mode : CR2
Canon Image Size : n/a
Easy Mode : Manual
Digital Zoom : None
Contrast : Normal
Saturation : Normal
Metering Mode : Evaluative
Focus Range : Not Known
Canon Exposure Mode : Aperture-priority AE
Lens Type : Canon EF 100-400mm f/4.5-5.6L IS or Sigma Lens
Max Focal Length : 600 mm
Min Focal Length : 150 mm
Focal Units : 1/mm
Max Aperture : 6.2
Min Aperture : 29
Flash Activity : 0
Flash Bits : (none)
Zoom Source Width : 0
Zoom Target Width : 0
Manual Flash Output : n/a
Color Tone : Normal
SRAW Quality : n/a
Auto ISO : 100
Base ISO : 400
Measured EV : 13.50
Target Aperture : 6.3
Target Exposure Time : 1/1625
Exposure Compensation : -1/3
White Balance : Daylight
Slow Shutter : None
Shot Number In Continuous Burst : 0
Optical Zoom Code : n/a
Camera Temperature : 32 C
Flash Guide Number : 0
Flash Exposure Compensation : 0
Auto Exposure Bracketing : Off
AEB Bracket Value : 0
Control Mode : Camera Local Control
Measured EV 2 : 13.375
Bulb Duration : 0
Camera Type : EOS High-end
ND Filter : n/a
Canon Image Type : Canon EOS 7D Mark II
Canon Firmware Version : Firmware Version 1.0.2
Canon Model ID : EOS 7D Mark II
Thumbnail Image Valid Area : 0 159 7 112
AF Area Mode : Single-point AF
Num AF Points : 65
Valid AF Points : 65
Canon Image Width : 5472
Canon Image Height : 3648
AF Image Width : 5472
AF Image Height : 3648
AF Area Widths : 243 243 243 243 243 243 243 243 243 243 243 24
3 243 243 243 243 243 243 243 243 243 243 243 243 243 243 243 243 243 243 243 24
AF Area Heights : 243 243 243 243 243 243 243 243 243 243 243 24
AF Area X Positions : 279 0 -279 -559 -1093 -1397 -1700 -2004 -1397
-1700 -2004 2004 1700 1397 1093 559 1397 1093 559 279 0 -279 -559 -1093 -279 -55
9 -1093 -1397 -1700 -2004 2004 1700 -2004 2004 1700 1397 1093 559 279 0 559 279
0 -279 -559 -1093 -1397 -1700 -1093 -1397 -1700 -2004 2004 1700 1397 1093 1700 1
397 1093 559 279 0 -279 -559 2004
AF Area Y Positions : 776 776 776 776 631 631 631 631 315 315 315 63
1 631 631 631 776 315 315 388 388 388 388 388 315 0 0 0 0 0 0 315 315 -315 0 0 0
0 0 0 0 -388 -388 -388 -388 -388 -315 -315 -315 -631 -631 -631 -631 -315 -315 -
315 -315 -631 -631 -631 -776 -776 -776 -776 -776 -631
AF Points In Focus : 39
AF Points Selected : 39
Time Zone : -05:00
Time Zone City : Chicago
Daylight Savings : On
Bracket Mode : Off
Bracket Value : 0
Bracket Shot Number : 0
Raw Jpg Size : Large
WB Bracket Mode : Off
WB Bracket Value AB : 0
WB Bracket Value GM : 0
Live View Shooting : Off
Focus Distance Upper : 195.88 m
Focus Distance Lower : 81.91 m
Flash Exposure Lock : Off
Internal Serial Number : LA0096864
Dust Removal Data : (Binary data 1024 bytes, use -b option to extr
act)
Crop Left Margin : 0
Crop Right Margin : 0
Crop Top Margin : 0
Crop Bottom Margin : 0
Exposure Level Increments : 1/3 Stop
ISO Speed Increments : 1/3 Stop
AEB Auto Cancel : On
AEB Sequence : +,0,-
AEB Shot Count : 3 shots
Safety Shift : Disable
Shutter Speed Range : Disable; Hi 1/8192; Lo 32
Aperture Range : Disable; Closed 91; Open 1
Focusing Screen : Ec-CIV
Viewfinder Warnings : Monochrome, WB corrected, One-touch image qual
ity, [6]
Continuous Shooting Speed : Disable; Hi 10; Lo 3; 4
Custom Controls : 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 254 255 0 3 112 48 0 0 0 0 0 0 0 0 0 0 0 20 80 0 0 0 7 3 0 2 1 3 0
0 0 0
Dial Direction Tv Av : Normal
Multi Function Lock : Off; Quick control dial
Add Aspect Ratio Info : Off
Default Erase Option : Cancel selected
Aspect Ratio : 3:2
Cropped Image Width : 5472
Cropped Image Height : 3648
Cropped Image Left : 0
Cropped Image Top : 0
Tone Curve : Standard
Sharpness : 3
Sharpness Frequency : n/a
Sensor Red Level : 0
Sensor Blue Level : 0
White Balance Red : 0
White Balance Blue : 0
Color Temperature : 5200
Picture Style : Standard
Digital Gain : 0
WB Shift AB : 0
WB Shift GM : 0
Measured RGGB : 745 1024 1024 481
VRD Offset : 0
Sensor Width : 5568
Sensor Height : 3708
Sensor Left Border : 84
Sensor Top Border : 50
Sensor Right Border : 5555
Sensor Bottom Border : 3697
Black Mask Left Border : 0
Black Mask Top Border : 0
Black Mask Right Border : 0
Black Mask Bottom Border : 0
Color Data Version : 11 (7DmkII/750D/760D)
WB RGGB Levels As Shot : 1949 1024 1024 1683
Color Temp As Shot : 5188
WB RGGB Levels Auto : 1942 1024 1024 1843
Color Temp Auto : 4799
WB RGGB Levels Measured : 1942 1024 1024 1843
Color Temp Measured : 4799
WB RGGB Levels Daylight : 1949 1024 1024 1683
Color Temp Daylight : 5200
WB RGGB Levels Shade : 2241 1024 1024 1446
Color Temp Shade : 7000
WB RGGB Levels Cloudy : 2097 1024 1024 1558
Color Temp Cloudy : 6000
WB RGGB Levels Tungsten : 1376 1024 1024 2411
Color Temp Tungsten : 3200
WB RGGB Levels Fluorescent : 1725 1024 1024 2325
Color Temp Fluorescent : 3736
WB RGGB Levels Kelvin : 1949 1024 1024 1683
Color Temp Kelvin : 5188
WB RGGB Levels Flash : 2162 1024 1024 1529
Color Temp Flash : 6345
Average Black Level : 2047 2047 2047 2047
Raw Measured RGGB : 155605 213123 209410 97362
Per Channel Black Level : 2047 2047 2047 2047
Normal White Level : 14580
Specular White Level : 15092
Linearity Upper Margin : 10000
Custom Picture Style File Name :
AF Micro Adj Mode : Adjust by lens
AF Micro Adj Value : 0
Vignetting Corr Version : 16
Peripheral Lighting Setting : Off
Chromatic Aberration Setting : Off
Peripheral Illumination Corr : Off
Auto Lighting Optimizer : Standard
Highlight Tone Priority : Off
Long Exposure Noise Reduction : Off
High ISO Noise Reduction : Standard
Multi Exposure : Off
Multi Exposure Control : Additive
Multi Exposure Shots : 0
HDR : Off
HDR Effect : Natural
AF Config Tool : Case 1
AF Tracking Sensitivity : 0
AF Accel/Decel Tracking : 0
AF Point Switching : 0
User Comment :
Sub Sec Time : 23
Sub Sec Time Original : 23
Sub Sec Time Digitized : 23
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 5472
Exif Image Height : 3648
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
Focal Plane X Resolution : 6086.76307
Focal Plane Y Resolution : 6090.15025
Focal Plane Resolution Unit : inches
Custom Rendered : Normal
Exposure Mode : Auto
Scene Capture Type : Standard
Owner Name :
Serial Number : 042021000752
Lens Info : 150-600mm f/0
Lens Model : 150-600mm
Lens Serial Number : 0000000000
GPS Version ID : 2.3.0.0
Thumbnail Offset : 37532
Thumbnail Length : 15355
Photometric Interpretation : RGB
Samples Per Pixel : 3
Rows Per Strip : 309
Planar Configuration : Chunky
Strip Offsets : 4929872
Strip Byte Counts : 23363803
Raw Image Segmentation : 1 2784 2784
SRaw Type : 1
Aperture : 6.3
Drive Mode : Single-frame Shooting
Image Size : 5472x3648
Lens : 150.0 - 600.0 mm
Lens ID : Sigma 150-600mm f/5-6.3 DG OS HSM | C
Megapixels : 20.0
Preview Image : (Binary data 4016726 bytes, use -b option to e
xtract)
Scale Factor To 35 mm Equivalent: 1.6
Shooting Mode : Aperture-priority AE
Shutter Speed : 1/1600
Create Date : 2015:07:04 11:26:10.23
Date/Time Original : 2015:07:04 11:26:10.23
Modify Date : 2015:07:04 11:26:10.23
Thumbnail Image : (Binary data 15355 bytes, use -b option to ext
ract)
WB RGGB Levels : 1949 1024 1024 1683
Blue Balance : 1.643555
Circle Of Confusion : 0.019 mm
Depth Of Field : 12.84 m (132.77 - 145.61 m)
Field Of View : 2.2 deg
Focal Length : 600.0 mm (35 mm equivalent: 946.1 mm)
Hyperfocal Distance : 2998.85 m
Lens : 150.0 - 600.0 mm (35 mm equivalent: 236.5 - 94
6.1 mm)
Light Value : 14.0
Red Balance : 1.90332
-- press any key --
Philihase
Gallery: 52 photos
Joined Dec 2013
Jul 12, 2015 05:30 |  #2
I´d guess heat haze. It looks like the shot I get on hot days and there is a visible heat haze in the air.
https://www.facebook.c​om …e-Photos-852961268075109/ (external link)
BigAl007
Gallery: 556 photos
Jul 12, 2015 07:54 |  #3
Philihase wrote in post #17628654 (external link)
Especially as its over a nice thick luxuriant layer of grass. You get an area that is generally a bit damp, and then the sun shines on it and you have to add the defraction caused by the varying amounts of water vapour, to the varying amounts of diffraction caused by the changes in temprature. This can become an issue over even quite small distances with a lens such as a 600mm, I would expect to start seeing effects at distances between about 30 to 50 yards/meters. The only good news is, if a breeze gets up, the worst of the effects vanish at wind speeds above about 12 miles per hour.
Annoying as it is for photography, I find this much more annoying as a competetive rifle shooter. As the diffraction moves the apparent visual location of the target, in relation to it's position in space. The mirage effect, as it is known, can double the amount of windage allowance you need for any wind speed. So it is good that above 12 mph it cannot effectivly form.
Alan
DAA
Joined May 2011
Jul 12, 2015 11:29 |  #4
Yes nothing worse than a "boil".
- DAA
Nascar ­ Nut
Joined Feb 2004
Jul 12, 2015 17:50 |  #5
Thanks guys for your responses. Well that does make sense as it was pretty warm. I shot some pics of grizzlies that were on the other side of a small lake and I could see the heat haze coming off the water so I knew those shots wouldn't turn out and they didn't. I couldn't see the heat haze when taking these shots so it got me wondering what I could doing wrong. Looks like on those hotter sunny days with no wind I need to get closer. I wonder if the grizzlies will play nice. lol
Calhoun213
Jul 14, 2015 10:13 |  #6
I had the same situation in Yellowstone last month. I was taking photos of a coyote feeding on a buffalo carcass about 140 yards away. Using a 7DII with a Tamron 150-600 mounted on a tripod. I was expecting some good shots but unfortunately almost all the photos showed distortion from the heat waves.
RMyers
Gallery: 30 photos
Jul 14, 2015 15:01 |  #7
Plus you were at f6.3 600mm with is max zoom and wide open. Probably not the sharpest part of the lens. I have the previous 150-500 Sigma and a 7dm2 and it is soft wide open. Much better results stopped down to f8-11. Try some test shots at home throughout the zoom range, wide open to smaller f-stops. You'll find what works best for your combo.
Rusty Myers
Austin, TX
http://www.SamMyersPho​tography.com (external link)
patrol50
Gallery: 11 photos
Joined Apr 2014
Jul 14, 2015 17:14 |  #8
RMyers wrote in post #17631530 (external link)
thatsan interesting comment - because have read in a couple of reviews where the sigma 150 - 600 is reputedly sharper wide open at f6.3 and 600 than the tamron 150 - 600 is and my tamron is certainly a bit soft at 6.3 & 600 imho
cheers rob
C:- 7D Mk11 ; 7Dc ; 600D & SX10 IS / L:- EFS 10-22 f3.5-4.5 USM ; 55-250 f4-5.6 IS 11; 18 -200 f3.5-5.6 IS ; & EF 16- 35 f4 L IS USM , 24-105 f4 L IS USM; 70-200 f4 L IS USM; 100-400 f4.5-5.6 L IS 1 USM (V1 and V11); + C 1.4 Ext Mk3 & Tam 150 - 600 f5-6.3 DI VC USD.
johnf3f
Jul 14, 2015 17:33 |  #9
Even without heat haze, dust in the air etc etc you will rarely get really detailed wildlife shots at that sort of range. The most detailed shots are nearly always the closest. Though I would advise caution with subjects that might eat you!
Here in the UK wildlife is not likely to harm you, though I have been chased by Deer in the Rut, so I get as close as sensible to my subjects. I rarely shoot beyond 50 yards and often shoot closer than the 6 meter minimum focus distance of my Canon 800 F5.6 L IS (by using extension tubes) on small birds.
Life is for living, cameras are to capture it (one day I will learn how!).
basketballfreak6
Jul 14, 2015 19:18 |  #10
hey nascar have you had a chance to test the lens in a more controlled setting? hope it really is just haze, i know the lens is capable of very sharp images wide open at 600mm, i was lucky with my copy AF stellar out of box and images having good sharpness
here is one wide open 600mm at ISO 2500 just to show what the lens is capable of
IMAGE: https://farm9.staticflickr.com/8839/18155584542_c279b8bf62_b.jpg
IMAGE LINK: https://flic.kr/p/tEm7​KG  (external link) Grey Fantail (external link) by Tony (external link), on Flickr
https://www.tonyliupho​tography.com.au/ (external link)
https://www.instagram.​com/tonyliuphotography​/ (external link)
R6, M6II, modified 77D, 16-35L f/4 IS, 24-70L II f/2.8, 70-200L IS II f/2.8, S150-600 f/5-6.3 C, S14 f/1.8 ART, S50 f/1.4 ART, S135 f/1.8 ART, 100L IS Macro f/2.8
Nascar ­ Nut
Joined Feb 2004
Jul 15, 2015 16:36 |  #11
Thanks all for your comments. I have gotten plenty of sharp photos at closer distances so I am going with the heat haze as the problem. Here is a shot hand held shutter speed 320 and wide open.
IMAGE: http://www.the-outdoorsman.net/temp/150-600/IMG_3006042615.jpg
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Jul 16, 2015 01:02 |  #12
Heya,
I shoot with 600mm, and even wide open, that lens would have been sharper by far than what you captured.
What you grabbed was heat distortion. I shoot over water and foliage a lot, and it does matter. Even if it's relatively cool outside, strong reflecting sun will produce heat haze and shooting through it is very troublesome (never getting focus, ever, even manually in Live View), and longer focal lengths just exacerbate the effect. There's literally nothing you can do, other than get closer, or move to another location and wait for another shot.
Very best,
ed ­ rader
"I am not the final word"
Jul 17, 2015 00:00 |  #13
heat distortion :lol:
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
colintf
Joined Apr 2012
Jul 17, 2015 00:49 as a reply to  @ ed rader's post |  #14
You had the camera / lens supported by a tree and the IS switched on?
I would of switched it off as it sounds similar as being mounted on a tripod
Just a thought :-)
DreDaze
Gallery: 49 photos
Jul 17, 2015 02:17 |  #15
ed rader wrote in post #17634201 (external link)
no canon lenses ever suffer heat distortion...
Andre or Dre
gear list
Instagram (external link)
10,355 views & 2 likes for this thread, 15 members have posted to it and it is followed by 4 members.
1039 guests, 107 members online
