Thread started 12 Jul 2015 (Sunday) 18:03
Just getting started in Astrophotography question.
frayne
Gallery: 54 photos
Joined Sep 2013
Post edited over 8 years ago by frayne.
Jul 12, 2015 18:03 |  #1
I am intrigued and have a $1000-1500 to spend. I have a 70D and a 6D and want to get some good shots of the moon, planets and deep space. What would be cost effective ? Appreciate and any and all responses in advance. I assume that most, if not all astrophotography is taken with the aid of a decent telescope ?
The only thing a golfer and photographer needs is more light.
Canon G9/5D/6D/70D Lenses 100-400L IS/17-40L/24-105L IS/100L IS/85 USM
cgmds73
Joined Aug 2012
Post edited over 8 years ago by cgmds73. (2 edits in all)
Jul 14, 2015 11:30 |  #2
I'm not sure because i'm a begginer, but i think moon, planets and deep space requires different hardware.
I started i few months ago with the same questions you ask.
For the moon, maybe this telescope will be fine:
http://www.amazon.com …liid=I1XZ2NRKVK​Q879&psc=1 (external link)
For deep space, what i guess you want is take photos/images of stars, nebulae, ..., very faint objects. I think you need a equatorial mount to track objects and take long exposure images.
I bought a sky-watcher star adventurer equatorial mount; is a little equatorial mount, $350 in USA. I want to try without a big budget. If i like astrophotography, then i will invest more money with bigger equatorial mount, and bigger telescope (or better quality optics).
With this sky-watcher star adventurer i think i can take images of orion nebulae. I think this mount will be capable of using a Sigma 50-150 f2.8 and Sigma 150-500.
Hope this helps.
Edit: also this telescope should work on sky-watcher star adventurer:
http://www.amazon.com …3SW&coliid=I3IS​N6BKPFTELB (external link)
And this too but is not APO ED optics (but look the images on the review!!):
http://www.amazon.com …9H1O/ref=cm_cd_​al_qh_dp_i (external link)
In my case, there's a lot to learn about optics, differents types of telescope (reflector, refractor, etc.), accesories (eye pices, barlow, etc.). Differents telescope may work better for some type of photography (moon, planetary, deep sky).
I learned a lot with this videos:
https://www.youtube.co​m/watch?v=9d0292TBMHo (external link)
https://www.youtube.co​m/watch?v=zQB6UnrTEEM (external link)
https://www.youtube.co​m/watch?v=sW8NyT3r2LU (external link)
https://www.flickr.com​/photos/elojotorpe/ (external link)
calypsob
Joined Jan 2012
Aug 03, 2015 21:44 |  #3
Astrophotography can be wide field or narrow, like normal photography you need different focal lengths to frame different objects. Also like terrestrial photography, aperture is king. Planets need a long focal length and require video stacking to generate good resolutions. You are better off with a small ccd for planetary imaging than a dslr. For nebula, a scope or lens can be used. I have a 8" 1,624mm f8 Ritchie Chreitien and a 480mm f5.6 refractor. The rc frames m 101 pretty well, m51 is still kinda small, and f8 requires long exposures and good guiding. I'm going to go towards all wide field in the future. My refractor is very good quality but at f5.6 it is a tad slow. I want shorter exposures so I'm going for F4 or F 5. Honestly all of the old FD lenses, 500mm f4.5, 600mm f4, and 800mm f5.6 with Ed mika adapters would make superb telescopes. For me, I think 500mm is going to be as long as I'm going to go. I'm going to sell my cge and keep the zeq25. I will add a 300mm f4, a 135mm f2, and probably a 500mm f4.5. I'm considering selling my t2i and astro filters to get a 5dsr.
The mount you use is crucial, star adventurer is nice but will not take you far into serious imaging. If you want 300s+ subs then Get a good eq mount like the skywatcher azeq5, celestron Ava, or zeq25. Step up payload with an atlas or ieq45. Much more and you'll surpass your budget on mounts. Also, you need an autoguider package like the Orion ssag plus guide scope, and a way to mount the camera/lens/guide scope combo. Then you are gold. Image away.
Wes
Gear: Many gears Yes.
Luxx
Joined Jan 2013
Aug 03, 2015 22:38 |  #4
Wow I have a 6d and a 70d and was thinking about trying to get into astro with a similar budget. I did some research and had a tough time. I was thinking t4i converted to full spectrum astronomik filters and a tracking polar mount thing to take longer than 20 sec shots. I thought this would cost about 1000 plus filters. It seemed that I mig.ht be able to take photos of nebula and the Milky Way and have some fun with IR. however I wasn't sure if this were true so I gave up for now.
Figured I could use 300 2.8 for nebula and 14 2.8 for wide field.
Luxx
Joined Jan 2013
Aug 05, 2015 18:38 |  #5
I'm going to bump this thread just a bit to see if anyone has ideas. With the refurbs going on sale I could buy a camera for conversion for less...though obviously the benefit of warranty is negated.
calypsob
Joined Jan 2012
Post edited over 4 years ago by calypsob. (2 edits in all)
Aug 05, 2015 20:40 |  #6
Luxx wrote in post #17655579 (external link)
the 300mm f2.8 is a killer astro imaging lens even wide open. This lens will allow you to really utilize some photons. You can start out with the 6D, Hisayoshi Kato uses an unmodded 6D and it is so sensitive that it picks up a good bit of hydrogen alpha without modification, though modded it would improve by about 45%. Here is my advice.
My guess is that you will not want to stop at shooting the milky way, the star adventurer can do milkyway just fine.
When you want to do 300s+ exposures, an autoguided equatorial mount is the way to go.
IMAGE: https://farm8.staticflickr.com/7489/16202824326_5d495ebb81_z.jpg
IMAGE LINK: https://flic.kr/p/qFMH​b7  (external link) The Lagoon and Trifid Nebula reprocess from summer 2014 (external link) by Wes Schwarz (external link), on Flickr
Wes
calypsob
Joined Jan 2012
Aug 05, 2015 20:52 as a reply to  @ Luxx's post |  #7
with that said, spend $15 for a membership to astromart.com
Get a used celestron avx with polarscope under $ 700 and an autoguide package http://www.telescope.c​om …uider-Package/p/99631.uts (external link)
then get a dual saddle vixen mount so you can mount the lens and autoguider side by side http://www.opticstar-ccd.com …opes.asp?p=0_10​_5_1_8_550 (external link)
with this setup you can do full on imaging, much longer exposures with perfectly round stars unobtainable with a simple tracker.
You could easily do this under $1,500. Actually if you could find a good used CG5-GT with polar scope you could do this for under $1,000.
Back when I started I pulled it off for under $1,000.. it can be done easily if you buy everything used. When using astromart just look at ratings, if they are reputable, sell alot, and have a perfect score you can get some great deals.
Wes
Van ­ Gogh
Gallery: 118 photos
Best ofs: 5
Joined Jun 2013
Aug 05, 2015 22:24 |  #8
calypsob wrote in post #17658062 (external link)
the 300mm f2.8 is a killer astro imaging lens even wide open. This lens will allow you to really utilize some photons. You can start out with the 6D, jon rista uses an unmodded 6D and it is so sensitive that it picks up a good bit of hydrogen alpha without modification, though modded it would improve by about 45%. Here is my advice.
Stunning!
One day I will get into astro-photography I know it, it's inevitable :-D
Camera - 2x5Dmk3, C100 mkii, 70D, 60D
Lenses - 24-70mm f2.8L II, 70-200mm f2.8L IS ii, 85mm f1.2L II, 35mm f1.4 ART, 100mm f/2.8L Macro IS
Lighting - 3 x 600EX RT's, Printer - Epson 3880
calypsob
Joined Jan 2012
Aug 06, 2015 21:08 |  #9
Van Gogh wrote in post #17658147 (external link)
Stunning!
Thank you very much. It really is a rewarding hobby with many challenges.
Wes
ebusinesstutor
Joined Apr 2011
Aug 07, 2015 23:11 |  #10
I strongly suggest you check out the Cloudy Nights forum. It is dedicated to astronomy and has a dedicated forum just for astro photography.
Best place to ask questions like this and you will be amazed at how much information you will receive.
Van ­ Gogh
Gallery: 118 photos
Best ofs: 5
Joined Jun 2013
Aug 08, 2015 07:25 |  #11
Hey guys one question, sorry for hijacking this thread frayne.
Is there a good recommended website to check sky conditions for shooting at specific locations? (like light pollution levels, visibility, clouds, etc ...).
I found an app called "Stellarium" that shows sky objects movement/location but it doesn't really show sky conditions ...
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Aug 08, 2015 08:13 |  #12
Down here the NWS (national weather service) predicts sky cover, humidity and a few other things that they put on a graph looking out 48 hours or so. I just plug in my location and find the forecast for that area, from there I can link to the graph.
In addition to stellarium, I use an iOS app called Photo Pills that does a great job predicting sun, moon and Milky Way position.
Gallery: 15 photos
Joined Jun 2011
Aug 08, 2015 08:17 |  #13
NWS graph example.
http://forecast.weathe​r.gov …nglish&FcstType​=graphical (external link)
Van ­ Gogh
Gallery: 118 photos
Best ofs: 5
Joined Jun 2013
Aug 08, 2015 08:21 |  #14
Thanks for the link!
Gallery: 15 photos
Joined Jun 2011
Aug 08, 2015 08:26 |  #15
Van Gogh wrote in post #17660802 (external link)
Sure thing. I use it all the time, and it works just fine on my phone. Hopefully you Canucks have a similar service.
6,293 views & 2 likes for this thread, 7 members have posted to it and it is followed by 5 members.
1426 guests, 146 members online
