FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 13 Jul 2015 (Monday) 16:35
Looking for tripod for my height.
johnlo
Jul 13, 2015 16:35 |  #1
I'm looking to buy a new tripod. I'm 5'4". That's 64". I guess my eye level would be 60" about. I need a tripod that can give me around that eye level, without using the center column. I was looking at the Induro AT214. But after the ball and camera, either I need to borrow my wife's heels, or stand on something. Any suggestion? Or any 5'4" shooter?
johnlo photography :
website: www.john-lo.com (external link)
personal blog: http://www.jklimagery.​com (external link)
My Gear List
SkipD
Joined Dec 2002
Post edited over 8 years ago by SkipD.
Jul 13, 2015 18:04 |  #2
johnlo wrote in post #17630375 (external link)
Simply leave the legs a bit shorter than their maximum length.
I usually mark my tripod's legs with little scratches at about 3" intervals so that I can easily shorten all three to the same less-than-maximum length.
There will be times when you want one or two legs significantly longer than "normal" such as when working on a hill, etc.
Skip Douglas
Reservoir ­ Dog
A Band Apart
Gallery: 487 photos
Best ofs: 9
Joined Jan 2013
Jul 13, 2015 18:08 |  #3
SkipD wrote in post #17630475 (external link)
Exactly, if the tripod is to high i don't understand why you don't setup the legs shorter -?
Patrice
150 Free online photos editing application (external link) / 100 Free Desktop Photo Editor Software (external link) / Free Photography eBooks (external link) / My photography blog (external link)
JonKline
Joined Sep 2013
Jul 13, 2015 18:09 |  #4
Why limit yourself to shots at your height or smaller? Part of being a photographer is finding the perfect perspective, especially if it's one that other people might not usually see!
Cinematographer Chicago (external link) | Milwaukee camera, lighting & grip rental (external link)
Instagram (external link) | Cameras (external link) | My Dealer (external link)
johnlo
Jul 13, 2015 18:13 as a reply to  @ SkipD's post |  #5
Thanks. I didn't even think of that. I like that idea a lot. Thanks
John
My Gear List
ThreeHounds
Gallery: 128 photos
Joined Mar 2014
Jul 13, 2015 19:44 |  #6
You could always haul around a step stool.
5D MkIII | 7D | Bronica ETRS
EF 24-105 f/4 L | EF 85mm f/1.8 USM | EF 17-40 f/4 L | EF 70-300 f/4 L | Sigma 35 f/1.4 Art | Zenzanon 105 f/3.5 | Tamron SP90 f/2.8 Di Macro VC USM
Blanton James Photography (external link)
PineBomb
I have many notable flaws
Gallery: 234 photos
Joined Apr 2014
Jul 13, 2015 20:08 |  #7
ThreeHounds wrote in post #17630565 (external link)
I'm 5'2", and that sh-i-t ain't funny. ;-)a
OP, it's all relative. There's consideration for perspective on the one hand, and when you do set it up for your height, you have the added advantage of greater stability, because you have to nest the legs in an extra length. People will do bizarro stuff with tripods on slopes too, so even the lanky sort might need a lift from time to time. As a matter of fact, I think I hear more complaints about tripod height from the taller folk.
Bottom line is, I'm shorter than you, and the problem never crossed my mind.
-Matt
Website (external link) | flickr (external link) | instagram (external link)
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Jul 13, 2015 20:15 |  #8
This has always bugged me, eye height is the most boring angle you can choose for most shots.
absplastic
Gallery: 40 photos
Jul 13, 2015 20:22 |  #9
If the goal is to have the viewfinder at your eye level with the legs fully extended, but center column not extended, measure from your viewfinder to the bottom of your ball head of choice, and then go to B&H and look at the specs for tripods with maximum heights around 60-65". The detailed SPECS tab will show you the "Maximum Height w/o Column Extended". You want that number plus your measurement to come up to your eye level height.
It's impossible to make an exact recommendation without knowing what you want to use for a tripod head, what camera you have, and whether or not you have a battery grip on it.
5DSR, 6D, 16-35/4L IS, 85L II, 100L macro, Sigma 150-600C
SL1, 10-18 STM, 18-55 STM, 40 STM, 50 STM
My (mostly) Fashion and Portraiture Instagram (external link)
flickr (external link) (NSFW)
PineBomb
Gallery: 234 photos
Joined Apr 2014
Post edited over 8 years ago by PineBomb.
Jul 13, 2015 20:26 |  #10
gonzogolf wrote in post #17630593 (external link)
That's right.
-Matt
johnlo
Post edited over 8 years ago by johnlo.
Jul 13, 2015 20:32 |  #11
I just purchased the at213
My Gear List
chantu
Jul 17, 2015 17:56 |  #12
Forget the stool. Use a chair -- there everywhere. Also consider using Liveview - the camera may be over your head, but that's OK.
Whortleberry
Joined Dec 2011
Jul 18, 2015 04:47 |  #13
My problem is the reverse of this. I have tripods which go up (sans ballhead, camera or grip) to roughly 8½ft. Obviously I don't go up that far; well not without assistance anyway. Similarly, some of them go down to about 3 to 4 inches above ground level (again, sans accoutrements). No artificial aids needed to get me down there of course but advancing years, replacement joints, et al make it all rather painful and dreadfully slow - if I'd known that old age was like this, I'd perhaps not have joined that club (good job the fees are so low for pensioners :twisted: ).
Simple solution though:-
Full control of the camera no matter what height it's at; all tremendously arthritis-friendly! Little bonus is that it's great for focus-stacking too.
Optional extras to make life even easier:-This gives the extra freedom to not be personally attached to the camera in any way at all - I can have the camera way up in the air or down at ground level while sitting in an armchair.
NOTE: You do have to make sure that the cable(s) are OTG (on the go) - ordinary ones don't work. If going for the wireless option, you also need to do a bit of research about various models and compatibility but there's a very comprehensive list of who/what/where/when/wh​y/how on the DSLR Controller site http://dslrcontroller.​com/ (external link)
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
ThreeHounds
Gallery: 128 photos
Joined Mar 2014
Jul 18, 2015 07:41 as a reply to  @ Whortleberry's post |  #14
Of course my step stool comment was in jest... I'm 6'5" and have the low down issue myself. I always use my iPad with CamRanger wifi whenever I'm tripod mounted.
I have a clip that attaches the iPad to the leg when I'm at normal (or higher) positions. When I'm shooting from low angles, I mount my ball head to a low light stand and hand hold the iPad. My back is very happy.
farmer1957
Gallery: 6 photos
Joined Jul 2012
Jul 24, 2015 19:00 as a reply to  @ johnlo's post |  #15
Induro is good equipment,
Read the instuctions , you will not have problems.
6,002 views & 10 likes for this thread, 12 members have posted to it and it is followed by 4 members.
1233 guests, 123 members online
