Thread started 14 Jul 2015 (Tuesday) 09:14
7DII Incorrect meter reading
sirquack
Gallery: 66 photos
Joined Jan 2013
Jul 14, 2015 09:14 |  #1
I was wondering if anyone else might be experiencing this issue. I recently got a 7DII to have a second body for shoots. I used it this weekend for a wedding and for the most part it was pretty good. I did notice an issue with the meter in the VF. It does not seem to be able to show overexposed settings. If I shoot wide open at 1/40th into the sun, it shows the exposure at correct. If I start increasing the shutter speed to fast speeds, it eventually gets to 1/1000th or better before the meter starts to go to the left of the middle. When looking at the images, you can see that wide open at the slow shutter is completely blown out, and the one at 1/1000th is a lot closer to correct exposure. I am just looking to see if others have experience that issue. If not, I may just take the camera back to the shop and have them give it the once over.
Name is Ron.
Bodies - 6D/5D3/7D2-Gripped
Lenses - Canon 17-40 F4/24-70 F2.8 II/85 F1.8/Canon 70-200 F2.8 II/F4/Sigma 30 DC/Tamron 150-600
Website (external link)
ksbal
Gallery: 374 photos
Best ofs: 9
Jul 14, 2015 09:28 |  #2
is this with a half press? sometimes my meter doesn't change until I do a half press. It doesn't update the screen meter until half press maybe?
Godox/Flashpoint r2 system, plus some canon stuff.
SkipD
Joined Dec 2002
Jul 14, 2015 10:06 |  #3
Ron - what exposure mode were you using? (Manual, Tv, Av, etc.)
Skip Douglas
JWdlft
Joined Feb 2013
Jul 14, 2015 10:06 |  #4
You don't mention what mode you're using (Manual etc.) but you do mention that it takes a long time before the meter goes to "the left of the middle". Isn't the exposure meter of the 7DII vertical, to the right of the view screen, so it should go below and above the middle?
As far as I know, not being a 7DII owner, the bottom meter is for exposure compensation, flash exposure compensation and automatic bracketing range.
rrblint
Gallery: 84 photos
Joined May 2012
Jul 14, 2015 11:26 |  #5
JWdlft wrote in post #17631218 (external link)
^^^^THIS.
The meter is on the right side, not the bottom.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/07/2/LQ_737048.jpg
Image hosted by forum (737048) © rrblint [SHARE LINK]
Mark
Keyan
Joined Mar 2011
Jul 14, 2015 11:44 |  #6
Looks like you are using the exposure compensation indicator, and not the actual exposure meter, which is on the right side of the viewfinder.
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
wallstreetoneil
Gallery: 14 photos
Joined Nov 2014
Jul 14, 2015 12:30 |  #7
- Exposure Meter is vertical on Right side (correct)
- Bottom is for Exposure Comp and also indicates Auto Bracketing Range (correct)
However
- Flash Exposure Comp appears on the Vertical Right side
Additional Info
- Auto Bracketing Range also appears on Vertical Right side (as it moves around as you adjust Exposure)
Hockey and wedding photographer. Favourite camera / lens combos: a 1DX II with a Tamron 45 1.8 VC, an A7Rii with a Canon 24-70F2.8L II, and a 5DSR with a Tamron 85 1.8 VC. Every lens I own I strongly recommend [Canon (35Lii, 100L Macro, 24-70F2.8ii, 70-200F2.8ii, 100-400Lii), Tamron (45 1.8, 85 1.8), Sigma 24-105]. If there are better lenses out there let me know because I haven't found them.
sirquack
Gallery: 66 photos
Joined Jan 2013
Jul 15, 2015 08:47 |  #8
Well that's what I get for not reading the manual. I will be reading up on the metering section again and make sure I dont misunderstand that piece. Thanks to everyone for your input. I really do appreciate it, even if I make myself look pretty dumb.
Name is Ron.
bumpintheroad
Self-inflicted bait
Gallery: 21 photos
Joined Oct 2013
Jul 15, 2015 09:04 |  #9
Do you perhaps have auto-ISO enabled?
-- Mark | Gear | Flickr (external link) | Picasa (external link) | Youtube (external link) | Facebook (external link) | Image editing is okay
sirquack
Gallery: 66 photos
Joined Jan 2013
Jul 15, 2015 09:23 |  #10
I do, and it helps as I know that my exposure was getting closer when I saw the ISO start to climb. As others have pointed out, I was looking where I thought it would be, instead of reading the manual and figuring out where is actually is.
I am your typical man like that. "We don't need to stinking manuals!"
I have downloaded the manual and will be reading it later when I have some time at lunch.
Name is Ron.
rrblint
Gallery: 84 photos
Joined May 2012
Jul 15, 2015 09:26 |  #11
Look at it this way Ron: It was an easy and cheap fix to only have to download the manual. :p
Mark
mwsilver
Gallery: 54 photos
Joined Oct 2011
Post edited over 8 years ago by mwsilver. (3 edits in all)
Jul 17, 2015 22:16 |  #12
sirquack wrote in post #17632379 (external link)
When in manual mode and using auto ISO, the meter on the bottom only displays
exposure compensation. The same is true for the meter on the top LCD screen. The line is pegged in the center regardless of the aperture or shutter speed. The meter on the right side of the VF and the rear LCD screen shows the actual exposure.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
3,046 views & 1 like for this thread, 9 members have posted to it and it is followed by 5 members.
1449 guests, 127 members online
