Had a few minutes on my hand.
The following test is not perfect but I wanted to do it quickly to see if anything jumped out.
I have been testing out the 100-400 II a lot on both the 5DSR and the 7D2 - it is now my favourite lens.
I have also brought back out my Canon 24-105 F4 IS to test it a bit on the 5DSR - just because and to test it because of its IS on the 5DSR to see what I can do in terms of SS.
The other idea I had was to pick the ISO that my own experience with 5D3 and the 7D2 seems to be the boundary ISO where serious degradation happens afterwards - that is 3200iso.
So, from about 15 feet, I handheld the four combinations of 5DSR, 7D2, 24-105 and 100-400. The exposure was 1/100, F4.5, 3200 iso @ 100mm.
I took a picture of some Bounty labeled paper towel
- I used center focus on the Block Of Writing in the now Bottom Right Hand Corner (see Questions? Comments?)
- it was upside down so it was rotated to be bottom right
- the paper towel is on an angle (my bad) so the rest of the lettering is progressively OOF as is is nearer to the camera
The crop for the 7D2 is very, very close to what a 1:1 LR crop would be - this required obviously a much larger 5DSR crop to get the same framing but basically the same number of pixels (and the file size confirms this) should be on the images of the both the 7D2 and the 5DSR - so, we can potentially now compare both the lenses at 100mm, F4.5 and the pixels of the 7D2 compared to similarly sized but different design 5DSR pixels.
In terms of PP, the pictures were imported into LR, they were cropped, the lens profile correction was applied and then exported - i.e. no PP was done other than LR default jpg sharpening.
What I see is:
- very very slightly sharper / more contrasty 5DSR vs 7D2
- slightly sharper at center (center focus pt was placed on writing block in bottom right hand corner) 100-400 vs 24-105 @ 100mm and more than slightly sharper in the corners of the 100-400 vs 24-105
I think what you are seeing, since the pixels are basically the same size, is the cancelling AA filter at work and comparing the lenses - that's 15 years of development and modern coatings. If I had to guess, if the 5DS (not 5DSR) was compared to the 7D2, comparing similar pixels, I would think it should be more similar.
Pictures below
7D2 with 100-400 II @ 100mm @ F4.5
5DSR with 100-400 II @ 100mmIMAGE LINK: https://flic.kr/p/vJ6ykq
7D2 with 24-105 @100mm @ F4.5IMAGE LINK: https://flic.kr/p/vJdLRz
5DSR with 24-105 @100mm @ F4.5IMAGE LINK: https://flic.kr/p/vJ6yDS
