I bought a cheap USB 3.0 ( well allegedly 3.0 ) SATA HHD enclosure hoping to run the old SATA II 500GB 7200 disc connected to a USB 3.0 port.
I looked up the old disc's power consumption and for read and write its 5V and 2.1 Watts. So I think USB 3.0 port is capable of delivering 900 Ma x 5 volts = 4.5 watts So I assumed I was OK.
But looking at the old disc's spec at :-
http://icecat.co.uk …sy/MK5061GSY-7805881.html![]()
It says "Powered By" :
USB: has a "x" in red
Internal: has a "Tick" in green.
So I double checked with Wiki only to find there was a low power and and high power version of USB 3.0. ( thank you morons at the USB conglomorate! ) the power was 150 Ma and 900 Ma respectively.
Obviously the drive caddy is cheap so no specs available there and the Sony Laptop - well Sony loves its secrecy, and now they no longer sell Vaio laptops - less chance of finding that out , than a red Ferrari being delivered as a mid week present from the wife!
So The question is am I safe? i.e. I wont blow out the USB Port will I? , or is there such a thing as a cheap powered USB hub.
Frankly I would toss the drive away before risking the laptop ; except it would be nice to be able to connect the disc and get at some data if needed. Or being able to format it and sell it. Without reinstalling it back in the laptop once the install proves to be rock solid etc.
My other question is, I have another old ATA IDE 120 GB HDD from the previous Laptop , with some images I lost when that Laptop's screen died!
So I bought a really cheap £7 ATA IDE HDD caddy , which is only USB 2.0
I need to check out that discs specs, to see its power consumption. But my worry now is - if I plug that into a USB 3.0 port will the power draw be limited to USB 2.0 standard power , or will the port still deliver USB 3.0 power levels ?
I think USB 2.0 was 500 ma so that is only 2.5 Watts? Or did they have a dual power rating?
Any help appreciated. It would be nice if these worked but I do not want to risk the laptops USB ports.
