Thread started 18 Jul 2015 (Saturday) 14:40
Canon 10-18mm f/ 4.5-5.6 VS. Tokina AT-X 116 PRO DX-II 11-16mm f/2.8
mlanyi
Joined Jul 2015
Jul 18, 2015 14:40 |  #1
I am deciding between the two lenses and would like to hear other people's opinions, pros/cons of each, and anything else you have to add. I have been looking to buy an Ultra wide angle lens for awhile now because my widest lens at the moment is my kit 18-55m. I will most likely be using it for landscapes, city photography, and maybe other things. Thanks!
jimewall
Jul 18, 2015 15:01 |  #2
Never tried the Tokina II, the one was sharp and more prone to flair. You get this because you need f/2.8, IMO the two things you listed you want to do don't need f/2.8.
The 10-18 wasn't out when I was buying, and I have what I want. It is cheaper and has IS, IMO it will do what you want.
I personally went with the Sigma 10-20 & 8-16 for crop and 17-40L for my ff.
Here is a current uwa thread with more information that may help https://photography-on-the.net …/showthread.php​?t=1430628
Thanks for Reading & Good Luck - Jim
GEAR
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Post edited over 8 years ago by MalVeauX.
Jul 18, 2015 19:01 |  #3
mlanyi wrote in post #17635731 (external link)
Heya,
I had the Tokina 11-16 F2.8 II. Extremely sharp lens, even wide open. Wicked sharp stopped down even a little bit. Amazing lens really. Built like a tank, heavy, sharp, wonderful contrast & color. It takes normal filters. And it focused lovely at infinity, so I always left it literally at infinity and never worried, it was always in focus (even astro stuff, I never had to use live view or anything, I just turned it to infinity and it was in sharp focus, which was just such a wonderful thing). The reason I *had* this lens is because I eventually got sick and tired of the flaring. It flares horribly. Even a street light can give you a big ugly blob of flare. Some times flare can be ok. But too much just destroys an image. And Tokinas tend to just have the most flare I've ever experienced.
I moved to an EF-S 10-22 for my APS-C based ultrawide needs. It's not as sharp as the Tokina. But the color & contrast is good, it's reasonably sharp, takes normal filters, and the MOST important thing, is that it handles flare very well, and I can barely get flare out of it even with direct light sources.
Ultimately I still stick with the 10-22 (which has better flare handling than the 10-18 STM by the way). For me, an ultrawide has the following importances: 1) corner sharpness when stopped down (f8 as a standard for me), 2) normal filter use (threaded, non-bulbous front elements), 3) flare handling. So I gave up the sharpness for the flare performance when I moved from the Tokina to the Canon 10-22. I don't regret it either, because frankly, it's not enough of a sharpness loss to matter to me.
Examples:
No-flare (if you're careful about where the light source is, and if it's masked or direct, you can avoid flare):
IMAGE: https://farm4.staticflickr.com/3886/14843283553_095b274fa2_z.jpg
IMAGE LINK: https://flic.kr/p/oBDH​4X  (external link) DPP_0526_7_8_tonemappe​d_marked (external link) by Martin Wise (external link), on Flickr
IMAGE: https://farm6.staticflickr.com/5564/14700393550_4cd8e89a0f_z.jpg
IMAGE LINK: https://flic.kr/p/op2m​Rd  (external link) DPP_0778_tonemapped_ma​rked (external link) by Martin Wise (external link), on Flickr
IMAGE: https://farm8.staticflickr.com/7570/15528496197_dd882d2991_z.jpg
IMAGE LINK: https://flic.kr/p/pEcA​V4  (external link) DPP_1957_proc_mark (external link) by Martin Wise (external link), on Flickr
Astro sharpness at F2.8 (wide open), focused to infinity without using viewfinder nor live view, just turned the lens to infinity:
IMAGE: https://farm3.staticflickr.com/2905/14350747435_65229471e9_z.jpg
IMAGE LINK: https://flic.kr/p/nS8k​eV  (external link) IMG_5174 (external link) by Martin Wise (external link), on Flickr
Flare (worst example I have of flare that I got with the Tokina; this occurs at specific angles of bright direct light sources):
IMAGE: https://farm4.staticflickr.com/3939/15596804965_34f1ca139b_z.jpg
IMAGE LINK: https://flic.kr/p/pLeG​Jr  (external link) DPP_1645_proc_mark (external link) by Martin Wise (external link), on Flickr
Flare (minor example, but still shows all the elements involved, it's still an odd, mechanical looking flare):
IMAGE: https://farm9.staticflickr.com/8673/15957758885_df995413b5_z.jpg
IMAGE LINK: https://flic.kr/p/qj8F​KT  (external link) DPP_2146_proc_marked (external link) by Martin Wise (external link), on Flickr
Canon 10-22 flare handling (same direct light, handles flare without all the bad stuff):
IMAGE: https://farm8.staticflickr.com/7533/16125996908_cc13902d8d_z.jpg
IMAGE LINK: https://flic.kr/p/qyZX​4s  (external link) DPP_2310_proc_mark (external link) by Martin Wise (external link), on Flickr
IMAGE: https://farm1.staticflickr.com/298/17979040583_0f5817895f_z.jpg
IMAGE LINK: https://flic.kr/p/toKh​ok  (external link) DPP_2649_proc_mark (external link) by Martin Wise (external link), on Flickr
So it really depends on you.
If it were not for the flare handling, I would have kept the Tokina II. Amazing lens when it's not flaring out of control. But I am in Florida, sun is always present, and I just couldn't stand all the flare ups. So I stay with the 10-22 on APS-C for now for these uses.
Very best,
mlanyi
Joined Jul 2015
Jul 18, 2015 19:16 as a reply to  @ MalVeauX's post |  #4
Amazing pictures! And thank you so much for all the input! I want to start trying long exposure pictures with whatever lens I buy. I know from reading reviews that the Tokina is better at them, correct me if I'm wrong. But I was wondering with your experience with both lenses what is your opinion on long exposure with the lenses? Also, obviously the tokina has much better build quality with the focus window, metal mount, and just overall a better build lens, is that + the f/2.8 worth the extra $100 or so? I wish I would be able to try both lenses for a couple days but unfortunately no camera shops around my area rent lenses, and I don't feel like paying $50-75 to rent them online because my budget is already kind of tight (Not tight enough where I should worry about the price of the tokina, I just can't add another 75 dollars on top of that.)
Thanks!
MalVeauX
Joined Feb 2013
Jul 18, 2015 19:58 |  #5
mlanyi wrote in post #17635956 (external link)
Thanks!
Heya,
The Tokina is no better at long exposure than any other lens. There's no magical properties. I do a lot of long exposure, and everything is the same to me. The only detectable differences between these lenses are sharpness in corners if you pixel peep and flare performance/handling. Long exposure, short exposure makes zero difference and will behave the same on any lens. F2.8 is only useful if you are shooting at F2.8, which is only useful on an ultrawide when you're trying to gather a lot of light (like wide field astro). F2.8 is not worth worrying about on an ultrawide unless you need it strictly for light gathering in low light. Otherwise, for depth of field, F2.8 on an ultrawide has miles of depth of field, so you won't be isolating anything with unless you focus on something within a few inches. I don't miss the F2.8, I never shot the Tokina at F2.8 for anything other than astro (see above examples, they're all F8, F11, F16, F22). I shot F2.8 only when shooting long exposure wide field astro, where every stop of light matters.
Bottom line is, if you want a night lens for astro wide field, get the Tokina.
If you want a lens for everything else, ultrawide, don't get the Tokina, get the 10-18 or 10-22.
I say that after having them both.
Here's some long exposure examples:
Tokina (long exposures, in day light & moon light)
IMAGE: https://farm6.staticflickr.com/5591/14871853078_ca01539b33_z.jpg
IMAGE LINK: https://flic.kr/p/oEb8​MY  (external link) IMG_0455_tonemapped_ma​rked (external link) by Martin Wise (external link), on Flickr
IMAGE: https://farm4.staticflickr.com/3847/15058082392_5de1ecc7d2_z.jpg
IMAGE LINK: https://flic.kr/p/oWCB​hd  (external link) IMG_0422_tonemapped_ma​rked (external link) by Martin Wise (external link), on Flickr
IMAGE: https://farm4.staticflickr.com/3855/14884800024_20b0c0c382_z.jpg
IMAGE LINK: https://flic.kr/p/oFju​tb  (external link) IMG_0026 (external link) by Martin Wise (external link), on Flickr
IMAGE: https://farm6.staticflickr.com/5555/14700682098_6e78d2e7db_z.jpg
IMAGE LINK: https://flic.kr/p/op3Q​Cb  (external link) IMG_0025 (external link) by Martin Wise (external link), on Flickr
Canon 10-22 (long exposures, in day light)
IMAGE: https://farm9.staticflickr.com/8563/16530804518_f45b277ba7_z.jpg
IMAGE LINK: https://flic.kr/p/rbLG​g1  (external link) IMG_3270 (external link) by Martin Wise (external link), on Flickr
IMAGE: https://farm8.staticflickr.com/7597/16779008406_7f88b94533_z.jpg
IMAGE LINK: https://flic.kr/p/ryGN​Co  (external link) IMG_3381 (external link) by Martin Wise (external link), on Flickr
IMAGE: https://farm9.staticflickr.com/8622/16182540604_e89707db5e_z.jpg
IMAGE LINK: https://flic.kr/p/qDZK​wL  (external link) IMG_3377 (external link) by Martin Wise (external link), on Flickr
Very best,
mlanyi
Joined Jul 2015
Jul 19, 2015 00:13 as a reply to  @ MalVeauX's post |  #6
You have been extremely helpful! Thank you for all your input, and I think I have decided to go with the Canon 10-18mm. After looking at all my options, and with all the help from you I think that would be the best lens for me. I look forward to sharing with you the pictures I get with it.
mlanyi
Joined Jul 2015
Jul 19, 2015 17:48 as a reply to  @ MalVeauX's post |  #7
I have decided to order both lenses off amazon. I didn't think I could choose between the two without actually "trying" them out. I know renting was always an option but I didn't want to spend $100 on rentals before I bought one. And without a good camera shop around my area I wasn't able to go into a store to try them out. Being an Amazon Prime member, I will get them within 2 days, and their return policy is fantastic. Thank you again for all the help/opinions! I hope i end up with the right lens!
6,024 views & 0 likes for this thread, 3 members have posted to it.
1511 guests, 130 members online
