Thread started 20 Jul 2015 (Monday) 14:36
need tether cable
kaitanium
Post edited over 8 years ago by kaitanium.
Jul 20, 2015 14:36 |  #1
Got a monoprice 20ft usb cable with repeater and it doesnt seem to be working reliably transferring photos from camera to lightroom/computer even when transferring medium jpegs from my 5Dmkiii
anyone have reliable luck from another brand of cable or type? Thanks.
lesz42
Jul 20, 2015 17:03 |  #2
off a pc? laptop? mains powered?
docholliday_sc001
My hypocrisy goes only so far.
Joined Jul 2011
Jul 20, 2015 20:39 |  #3
I routinely tether with a 40' USB repeater and/or 200' Cat6 cable from my 1Ds3 and 1Dx bodies to desktops and laptops, directly into Lightroom. Never have an issue. However, cheap USB repeaters (which are actually single port powered hubs) are known to be absolute junk and cause all kinds of unreliability issues.
Go for a better quality cable and you shouldn't have an issue. I also use a 90deg custom 1' cable to connect to the repeater as a breakaway (and to get the pokey cable pointing down instead of sideways into my hand). You can get these from usbfirewire.com. They also have the high powered repeater with enhanced shielding (great for noisy factory environments).
Don't spend the money for the overpriced tethertools junk...get the stuff designed for the IT world...
kaitanium
Jul 21, 2015 11:25 |  #4
thanks! which exact product are you using at usbfirewire.com?
docholliday_sc001
Joined Jul 2011
Jul 22, 2015 03:20 as a reply to  @ kaitanium's post |  #5
Look at the items on this page:
http://www.usbfirewire​.com …repeaters_compa​rison.html (external link)
This specifically is the cable I'm using for USB: http://www.usbfirewire​.com …ht.html#RR-USB2-EXT-40FTE (external link)
with one of these for the breakaway: http://www.usbfirewire​.com …-72gl.html#RR-2MBL01-12GL (external link). That is a left angle cable. There are also right angle cables (as well as down and up angle!). Check the port on the side of the camera to be sure the mini-USB is oriented correctly to make the cable go down towards the baseplate of the camera.
I also added one of these to relieve the pressure off the port and keep it from getting pulled out when I'm shooting handheld: http://www.usbfirewire​.com …pport.html#RR-PORTSUPPORT (external link)
Hope that helps...
blanex1
Joined Nov 2012
Jul 29, 2015 12:28 |  #6
tether pro cables,the orange one,all my problems went away when i got this cable .:-D
canon 7d bg-e7 5d-mk3 1d-mk3 24-105-L 17-40 L 35/1.4 85/1.8 yougnuo 565 ex 580 ex and lots of other canon stuff.canon 70-200 2.8 L
4,220 views & 0 likes for this thread, 4 members have posted to it.
need tether cable
1504 guests, 136 members online
