I have never ever used it. I will use a 5Dmk3 and a 7Dmk2. Is there any special settings in the menu's I should have selected? Is there different focusing modes for it? Better settings? The 5Dmk3 for portraits and the 7Dmk2 for nature
gqllc007 Senior Member 445 posts Likes: 133 Joined Jan 2015 More info | Jul 20, 2015 14:39 | #1 I have never ever used it. I will use a 5Dmk3 and a 7Dmk2. Is there any special settings in the menu's I should have selected? Is there different focusing modes for it? Better settings? The 5Dmk3 for portraits and the 7Dmk2 for nature
Jul 20, 2015 14:48 | #2 Live-view uses the same auto-focus control options in the camera menu as regular viewfinder auto-focus. However what changes is that when it uses live-view it uses a different set of internal sensors to detect the focusing point. Tools of the trade: Canon 400D, Canon 7D, Canon 70-200mm f2.8 IS L M2, Sigma 120-300mm f2.8 OS, Canon MPE 65mm f2.8 macro, Sigma 150mm f2.8 macro, Tamron 24-70mm f2.4, Sigma 70mm f2.8 macro, Sigma 8-16mm f4.5-5.6, Raynox DCR 250, loads of teleconverters and a flashy thingy too
Your 5D3 will use "contrast detection" for live-view AF, and as mentioned above it is generally slower than the phase detection AF you get through the viewfinder. The camera will "rock" the lens on either side of critical focus and find the point of highest contrast which is usually the point of focus. Cameras: 7D2, S100
gqllc007 THREAD STARTER Senior Member 445 posts Likes: 133 Joined Jan 2015 More info Post edited over 8 years ago by gqllc007. | Thank you for the explanation. I can see how for tripod it would work. Thanks again! So more for landscapes and static subjects then.
Jul 20, 2015 15:17 | #5 Keyan - thanks for the reminder - I forgot that the 7DM2 did some new fancy tricks! Tools of the trade: Canon 400D, Canon 7D, Canon 70-200mm f2.8 IS L M2, Sigma 120-300mm f2.8 OS, Canon MPE 65mm f2.8 macro, Sigma 150mm f2.8 macro, Tamron 24-70mm f2.4, Sigma 70mm f2.8 macro, Sigma 8-16mm f4.5-5.6, Raynox DCR 250, loads of teleconverters and a flashy thingy too
apersson850 Obviously it's a good thing More info | Jul 20, 2015 15:24 | #6 Overread wrote in post #17637981 Live-view uses the same auto-focus control options in the camera menu as regular viewfinder auto-focus. Usually not. However what changes is that when it uses live-view it uses a different set of internal sensors to detect the focusing point. True. Normal AF has a dedicated sensor. Live view AF uses the image sensor. In practice this means that because the light is not being reflected and split (one to the mirror box and viewfinder - and one to the AF sensors) the live-view AF sensor system gets more light. This is why you have cameras like the 7D which can auto-focus with a lens maximum aperture of down to f5.6; but can use a maximum aperture of down to f8 in liveview. That is not at all why standard AF is limited to f/5.6 for many cameras, or f/8 for some AF points in some cameras (the two mentioned here included). Live view AF sensors are typically not as fast as those through the viewfinder - as such for action you will typically find most still use the viewfinder. For hand-holding the viewfinder is also superior in most situations. Contrast detect AF is typically not as fast as the phase detect AF you utilize when shooting with the normal viewfinder. But now some cameras, like the 7D Mark II, have phase detect AF in live-view too. Live-view comes into its own when tripod mounted and also for situations where you want to do very fine focusing; especially manual focusing. This is because you can magnify the live-view image on the back of the camera - so you can "zoom in" on the critical area to ensure that the focus is really where you want it to be (your manual should detail the + and - buttons for magnification in live-view mode) Exactly! Anders
Jul 20, 2015 15:27 | #7 Permanent banI only use Live View when shooting from a tripod and manual focusing. I don't do much video, thought. WARNING: I often dispense advice in fields I know little about!
Jul 21, 2015 08:13 | #8 gqllc007 wrote in post #17638004 Thank you for the explanation. I can see how for tripod it would work. Thanks again! So more for landscapes and static subjects then. Can I use live view for action shots of dogs? With the 7Dmk2 that is? It will focus lock quickly. I find it great for video and/or off angle shooting. For action shots of dogs....the biggest issue is that the dual pixel AF system doesn't seem to be able to burst shoot or track shot to shot, and the 7D2's OVF AF system is built for high speed action shooting and subject tracking, so you will probably get better results using that. Cameras: 7D2, S100
ScottM Goldmember More info | Jul 21, 2015 08:56 | #9 GeoKras1989 wrote in post #17638026 I only use Live View when shooting from a tripod and manual focusing. I don't do much video, thought. Same here. It's quite helpful when you zoom in the LCD screen on the area you want in focus.
stevewf1 Senior Member 830 posts Likes: 247 Joined Sep 2010 Location: Indianapolis More info | Jul 29, 2015 05:49 | #10 Keyan wrote in post #17638831 It will focus lock quickly. I find it great for video and/or off angle shooting. For action shots of dogs....the biggest issue is that the dual pixel AF system doesn't seem to be able to burst shoot or track shot to shot, and the 7D2's OVF AF system is built for high speed action shooting and subject tracking, so you will probably get better results using that. I'll add that shooting action shots of anything using live view can be fairly clumsy. You'll be holding the camera and lens out in front of you and YOU may not be very accurate... Steve
| Latest registered member is semonsters 1507 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
