Can this be moved off of the photograph?
I'm referring to the box that suggests getting more hits and also the smaller box that suggests adding to gallery. I find it very annoying.
Thanks.
Jul 25, 2015 22:06 | #1 Can this be moved off of the photograph?
OhLook insufferably pedantic. I can live with that. 24,910 posts Gallery: 105 photos Best ofs: 2 Likes: 16339 Joined Dec 2012 Location: California: SF Bay Area More info | Jul 26, 2015 01:27 | #2 The larger box vanishes if you reload the page. "Add to gallery" would be less obtrusive if it had a translucent background. I find them only slightly annoying. PRONOUN ADVISORY: OhLook is a she. | Comments welcome
I suppose everyone's level of annoyance is different. You make a good point about transparency.
Pekka El General Moderator More info Post edited over 8 years ago by Pekka. | Jul 26, 2015 16:59 | #4 Transparency makes a command hard to see depending on what kind of image it is on. The Forum Boss, El General Moderator
I understand that it needs to be "seen"
LVMoose Moose gets blamed for everything. More info | Jul 26, 2015 18:47 | #6 I find that concept annoying. Strontium wrote in post #17645331 It's just a tad annoying to not be able to view an unmolested image in the thread without clicking the eyeglasses. Dude. I think you're spoiled. What could be easier than that? Moose
Pekka El General Moderator More info | Jul 26, 2015 19:26 | #7 Strontium wrote in post #17645331 I understand that it needs to be "seen" So you're saying that moving it to, say, an extra line below the exif data is out of the question? Like move exif up one line and put reminder link just below it? That position is not good because it is too easy to click a metadata item (which is a link) or md editor command. With Android there is a very annoying "guess the click" feature which usually picks the wrong one. For that and general usability reasons commands should be separated a lot to avoid mistaken clicks. This is the reason like command will be moved in next version. I know that I can view my own photographs in flickr and on my own hard drive. It's just a tad annoying to not be able to view an unmolested image in the thread without clicking the eyeglasses. Others do not see any commands on top of your photos unless they hover it. I could put the add command behind a "hover" (even without a delay), but then it will get unnoticed by all who do not know it is there (and on mobile there is no hover, only "tap and wait"). I'm sure I'll get over it, either way. Just wondered if it couldn't be done differently. If a better way is found, it will be done. The Forum Boss, El General Moderator
I'm sure I am just not used to it and that is probably the source of my annoyance. Thanks for the replies.
| Latest registered member is semonsters 1040 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
