Thread started 28 Jul 2015 (Tuesday) 15:06
5DSR 24-70II 2.8 vs 24-105 F4 resolution test at 50 and 70mm
wallstreetoneil
Gallery: 14 photos
Joined Nov 2014
Jul 28, 2015 15:06 |  #1
- similar test as before with the longer lenses but much closer distance - 14.5feet away from target
- target on wall that you see blown up is 4 inches by 3 inches
- the crop used is basically equivalent to what a 3:1 crop is in LR (the files are just over 100k)
This is what it looks like at 50mm
IMAGE: https://farm1.staticflickr.com/541/19473503713_5f9998307e_c.jpg
IMAGE LINK: https://flic.kr/p/vENN​d2  (external link) 5dsr test-12 (external link) by Paul O'Neil (external link), on Flickr
24-70 II F2.8
- 24-70 II @ 50mm @ F2.8
IMAGE: https://farm1.staticflickr.com/410/20094182945_3055e59017_o.jpg
IMAGE LINK: https://flic.kr/p/wBDW​w6  (external link) 5dsr test (external link) by Paul O'Neil (external link), on Flickr
24-70 II @ 50mm @ F4
IMAGE: https://farm1.staticflickr.com/513/20094183795_b34d9cf4c4_o.jpg
IMAGE LINK: https://flic.kr/p/wBDW​LK  (external link) 5dsr test-2 (external link) by Paul O'Neil (external link), on Flickr
24-70 II @ 50mm @ F5.6
IMAGE: https://farm4.staticflickr.com/3801/19473183723_72f537ca62_o.jpg
IMAGE LINK: https://flic.kr/p/vEMa​5X  (external link) 5dsr test-3 (external link) by Paul O'Neil (external link), on Flickr
24-105 F4 IS
- 24-105 @ 50mm @ F4
IMAGE: https://farm4.staticflickr.com/3741/20086221732_74e3cb5b1f_o.jpg
IMAGE LINK: https://flic.kr/p/wAX8​VN  (external link) 5dsr test-7 (external link) by Paul O'Neil (external link), on Flickr
- 24-105 @ 50mm @ F5.6
IMAGE: https://farm1.staticflickr.com/547/19906167010_4f766fdbe2_o.jpg
IMAGE LINK: https://flic.kr/p/wk3i​W3  (external link) 5dsr test-8 (external link) by Paul O'Neil (external link), on Flickr
Hockey and wedding photographer. Favourite camera / lens combos: a 1DX II with a Tamron 45 1.8 VC, an A7Rii with a Canon 24-70F2.8L II, and a 5DSR with a Tamron 85 1.8 VC. Every lens I own I strongly recommend [Canon (35Lii, 100L Macro, 24-70F2.8ii, 70-200F2.8ii, 100-400Lii), Tamron (45 1.8, 85 1.8), Sigma 24-105]. If there are better lenses out there let me know because I haven't found them.
wallstreetoneil
Gallery: 14 photos
Joined Nov 2014
Jul 28, 2015 15:18 |  #2
continued at 70mm
24-70 F2.8 II
- 24-70 @ F2.8 @70mm
IMAGE: https://farm1.staticflickr.com/435/19907457239_4bcce4a5d0_z.jpg
IMAGE LINK: https://flic.kr/p/wk9V​tn  (external link) 5dsr test-4 (external link) by Paul O'Neil (external link), on Flickr
- 24-70 @ F4 @70mm
IMAGE: https://farm1.staticflickr.com/260/20094183635_b052161ef5_z.jpg
IMAGE LINK: https://flic.kr/p/wBDW​HZ  (external link) 5dsr test-5 (external link) by Paul O'Neil (external link), on Flickr
- 24-70 @ F5.6 @70mm
IMAGE: https://farm1.staticflickr.com/330/19906073198_157e15bbcf_z.jpg
IMAGE LINK: https://flic.kr/p/wk2Q​3A  (external link) 5dsr test-6 (external link) by Paul O'Neil (external link), on Flickr
24-105 F4 IS @70mm
- 24-105 @ F4
IMAGE: https://farm4.staticflickr.com/3703/20067891566_875bd33f4d_z.jpg
IMAGE LINK: https://flic.kr/p/wzkc​1s  (external link) 5dsr test-9 (external link) by Paul O'Neil (external link), on Flickr
- 24-105 @ F5.6 @70mm
IMAGE: https://farm1.staticflickr.com/305/20094182975_af00592bfe_z.jpg
IMAGE LINK: https://flic.kr/p/wBDW​wB  (external link) 5dsr test-10 (external link) by Paul O'Neil (external link), on Flickr
wallstreetoneil
Gallery: 14 photos
Joined Nov 2014
Jul 28, 2015 15:30 |  #3
I was a bit surprised that the F5.6 70mm of the 24-105 seems to be worse than the F4 picture - the exif data shows it was at 1/20 versus 1/40 - all shots were tripod with 10 second delay so I think this shot highlights how sensitive a 'perfect shot' at this pixel density is hard to get if any vibration happens.
Because of the size of the crops, this test is only comparing the dead center of each lens - I thought a bigger difference would show up at this amount of magnification but when you look at the slrgear.com blur chart of the 24-105 it is a very sharp F5.6 lens in the lower half of it's zoom range - the results here show it to the very similar (in the center!!) as the $2k 24-70 at F4 / F5.6
That's what I see
Patman99
Joined Jul 2011
Jul 30, 2015 13:25 |  #4
Did you remember to turn off the IS if the camera was on a tripod?
sploo
premature adulation
Joined Nov 2011
Jul 30, 2015 16:46 |  #5
It's always easy to sit on the sidelines and complain, but... the 24-105 @ F5.6 @70mm shot looks to have some motion blur, and most of the shots are down at a shutter speed that at least has a risk of some potential movement (even vibration in the tripod from someone moving in the room etc.)
When I do these sorts of tests I:
1. Use Liveview or mirror lock up to prevent mirror slap
2. Use a remote cable + 2s delay to try to prevent any of my movement affecting the camera
3. Use a flash (on which I change the power as I change the aperture)
The last point allows shooting at the flash sync speed (e.g. 1/200) and ensures a pretty constant (and consistent) light level for each shot. It also allows shooting at the lowest possible ISO so that sensor noise doesn't affect the results.
One of the things that also makes me slightly suspicious is that your 24-105 @ 50mm @ F4 shot looks if anything sharper than your 24-70 II @ 50mm @ F4 image. Any test I've ever done (or MTF chart I've seen) would put the 24-70 quite a bit ahead at those settings. In the centre at least it even tends to be sharper at f/2.8 than the 24-105 at f/4.
Camera, some lenses, too little time, too little talent
Mark0159
I say stupid things all the time
Gallery: 45 photos
Joined Mar 2003
Jul 30, 2015 23:04 |  #6
at such a low shutter speed make sure you use mirror lockup as well. Just to make sure that anything that could effect image is disabled.
Mark
https://www.flickr.com​/photos/52782633@N04 (external link)
Canon EOS 6D | Canon EF 24-105mm f/4L IS USM, EF 17-40mm f/4L USM, EF 50mm f/1.4 USM, EF 100mm f/2.8 Macro USM | Tamron SP 35mm F1.8 Di VC USD | Canon Speedlite 550EX -|- Film | Canon EOS 3 | Olympus OM2 | Zuiko 35mm f2
wallstreetoneil
Gallery: 14 photos
Joined Nov 2014
Jul 31, 2015 06:54 |  #7
Patman99 wrote in post #17650197 (external link)
The 24-70 2.8 has no IS and no left it on which possible could have helped the 24-105 as I have seen it do with my longer lenses.
wallstreetoneil
Gallery: 14 photos
Joined Nov 2014
Jul 31, 2015 06:58 |  #8
sploo wrote in post #17650446 (external link)
I appreciate all your comments. I not exactly happy with these particular results myself so I think k I may redo them. But the results themselves do show that when you are searching for the final 10% of details that the 5dsr can give you it is not easy.
I did use live view with 10 second delay.
Thanks for the suggestions.
sploo
premature adulation
Joined Nov 2011
Jul 31, 2015 07:52 |  #9
wallstreetoneil wrote in post #17651125 (external link)
Absolutely - it does show how unforgiving the 5DS can be. I've seen a few posts from people saying that they've had to up their shutter speeds for handheld work.
Don't overlook the flash option though - you can get really consistent conditions that makes it much easier to compare shots at different apertures, or even different lenses.
Patman99
Joined Jul 2011
Jul 31, 2015 10:43 |  #10
wallstreetoneil wrote in post #17651120 (external link)
Conventional wisdom is to disable IS when the camera is on a tripod, as IS is correcting for slight hand-held shaking, but when the camera is on a tripod, IS can cause some blur in photos when it is enabled. Go figure. :D
wallstreetoneil
Gallery: 14 photos
Joined Nov 2014
Jul 31, 2015 13:18 |  #11
Patman99 wrote in post #17651328 (external link)
with all my IS lens, i get the complete opposite (70-200, 100-400, 24-105)
i sort of came upon this while doing a dot tune of my lenses and realized that with the IS on, DOT tune method would be able to achieve critical focus further from the center marker by a few clicks so I kept it on as I view it as more accurate (i.e. eliminating movement)
7,105 views & 1 like for this thread, 4 members have posted to it and it is followed by 2 members.
1468 guests, 130 members online
