Thread started 28 Jul 2015 (Tuesday) 22:03
Meike battery grip and battery draining problem
kenwood33
Jul 28, 2015 22:03 |  #1
I have a Meike grip for the 6d. I put in some new batteries, keep the switch on the camera and the grip to the OFF position, and after a day or 2, the batteries are drained. I put the same battery into the 6d, did not turn the camera off (camera goes to sleep automatically), the battery is not drained after 2 days. So it looks like the grip is draining battery. Did a quick search, seems to be a common problem. Any work around? May be taping certain connection pins?
Gearlist
Swann1
Jul 28, 2015 23:04 |  #2
I assume you don't have WiFi or GPS on (GPS will drain the battery even with the camera off). Sell it and buy the Canon one. I have no such issues with my Canon grip.
Michael Swann
6D+EF 24-105 f/4L, EF 17-40 f/4L, EF 70-200mm f/4L, 580 EX II, 430 EX III, Sekonic L-358
Lowepro Mini Trekker, Flipside 300 & Nova 180 AW bags, Manfrotto tripod.
maverick75
Joined May 2012
Post edited over 8 years ago by maverick75.
Jul 28, 2015 23:31 |  #3
I had a Meike grip with no draining issues. But on a Non GPS body, I also had their lens adapter and it worked perfectly. Quality was on par with the Canon stuff for half the price.
GregDunn
Joined Mar 2013
Jul 29, 2015 10:27 |  #4
It depends on which camera the adapter is for, and which manufacturer makes the grip. All my 3rd party grips have been just as good as the Canon equivalent, and if there were any battery issues they were resolved before I bought mine; most manufacturers have quietly updated their product if there were issues. I have gone on record before as saying that my Vello 5D3 grip is superior to the Canon in terms of feel and mechanical quality.
The only 3rd party grip I've ever had problems with was the Opteka model for my 550D. It was a direct copy of the OEM grip - which had the same mechanical defect as the knockoffs, because there was a design issue that everyone copied. :-)
Canon 1Dx | 5D3 | 7D2 | 6D | 70-200L f/2.8IS | 70-200L f/4 | 24-70L f/2.8 | 24-105L f/4IS | 100-400L f/4.5-5.6IS | 17-55 f/2.8IS | 50 f/1.8 | 28-105 f/3.5-4.5 | 4x Godox AD360
scotchtape
Joined Aug 2013
Jul 29, 2015 10:42 |  #5
I disassembled mine when I thought I had the problem. Couldn't find anything wrong with it.
Put it back together and the problem "stopped".
If you can't get it stop then... guess you have to remove batteries everytime.
Phoenixkh
a mere speck
Gallery: 67 photos
Joined May 2011
Jul 29, 2015 11:10 |  #6
After a year, my Meike battery grip started draining both batteries overnight. I didn't get a 60D until fairly late in its production life so it isn't like the 3rd party battery grip was still under continued development.
I ended up buying a Canon grip and never had a problem again. For that reason, I bite the bullet and buy Canon grips if and when I buy a new body. I believe they are overpriced (like everyone else) but they do seem to be reliable.
Kim (the male variety) Canon 1DX2 | 1D IV | 16-35 f/4 IS | 24-105 f/4 IS | 100L IS macro | 70-200mm f/2.8L IS II | 100-400Lii | 50 f/1.8 STM | Canon 1.4X III
RRS tripod and monopod | 580EXII | Cinch 1 & Loop 3 Special Edition | Editing Encouraged
clb
Jul 30, 2015 14:57 as a reply to  @ scotchtape's post |  #7
How did you take it apart? Was it difficult ?
Chuck
Canon 7D 50D 40D(X-2) -Gripped, 600D T3I -Gripped, Tamron 17-50 2.8 VC, Sigma 100-400mm f/5-6.3 DG OS HSM Contemporary, Canon EF 50mm f/1.8 II, Tamron 18-270mm f/3.5-6.3 XR Di II LD, Tamron 90mm Macro, YN565EX Flash,YN-622C trigs
gqllc007
Joined Jan 2015
Jul 30, 2015 15:48 |  #8
Phoenixkh wrote in post #17648759 (external link)
My experience is exactly the same
Gungnir
Gallery: 37 photos
Post edited over 8 years ago by Gungnir.
Jul 31, 2015 00:52 |  #9
Have a Meike grip on a 5D3. It will occasionally not power the camera unless removed and re-inserted.
Doesn't feel as well made compared to Meike grips on my older cameras. More flex and poorer fit to contours of camera body. The joystick is far too sensitive also.
Steve
'Be the person your dog thinks you are'
#freetommy
Coral
Joined Dec 2012
Aug 03, 2015 08:26 |  #10
I had a Meike grip on a 5D3, I also had problems with battery drain. I ended up getting a Vello I have had zero problems. Plus the quality appears to be better than the Meike grip
Living the Dream
Gear: Camera 5D3, Glass: EF 50mm f1.4, EF 100mm f2.8, EF 70-200mm f4, EF 500mm f4 II, Tamron 24-70mm f2.8
stevewf1
Aug 04, 2015 05:14 |  #11
Same here.
Steve
mwsilver
Gallery: 54 photos
Joined Oct 2011
Aug 08, 2015 08:39 |  #12
GregDunn wrote in post #17648704 (external link)
What mechanical defect does the OEM grip for the 550D have? We've used the Canon grip on our t2i (550D) extensively for years, mostly used by my wife these days. My son often also uses the same copy on his t3i (600D) since it will work on both models. He too has had no issues.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
mwsilver
Gallery: 54 photos
Joined Oct 2011
Post edited over 8 years ago by mwsilver.
Aug 08, 2015 08:43 |  #13
Gungnir wrote in post #17650928 (external link)
So why would you spend all that money on a professional quality 5D3 body and then use an inexpensive and apparently subpar grip on it? If you are having electrical issues with it, I would be concerned that it could short out your camera. For me a bargain is not a bargain unless you can get the same quality and performance for less.
Mark
mikeinctown
Joined May 2012
Post edited over 8 years ago by mikeinctown.
Aug 10, 2015 12:20 |  #14
mwsilver wrote in post #17660829 (external link)
Just from a third party perspective, the person said he has used those grips on other cameras without any issue and that the build quality and finish was higher than the newest one he has. So to answer your question, up until now he apparently did get the same quality at a lower cost.
I do agree that I would probably stop using the grip until a new one is purchased though. Nothing worse than grabbing the camera to get a shot and having it not work for you.
BTW, I've either got a meike or Vello grip on my 5D2 and had one or the other on my T3i before that. Both work(d) flawlessly and even after sitting for several months, the batteries still had a decent charge. based on past experience, I'd have no issues getting an off brand again.
scotchtape
Joined Aug 2013
Post edited over 8 years ago by scotchtape. (4 edits in all)
Aug 10, 2015 12:55 |  #15
clb wrote in post #17650321 (external link)
Very easy. Just undo the screws, not that many of them.
If you don't do this for money, then saving $300 per grip is a pretty good deal, even considering all the "issues".
Some grips are better than others. Even if you pay $100 for 3 grips to find one that works, still better than $300, especially for hobby use.
For multi-cameras, you save even more :)
I have owned like 10 or more 3rd party grips and one or two had the battery draining issue.
This is for 10 or more cameras :) and one of them magically went away.
For 5D3 I also had three of these at one point and three aftermarket grips - no problems. Maybe have been Meiki or Neewer, don't remember now.
I also had a random no name with rear battery access (the one where you can pop the batteries out the back, no tray required).
Worked great :D The quality wasn't the best, but for $30 can't complain and it worked fine for my purposes - holding an extra battery.
I never really used any of the controls but of course they didn't feel that great.
For the 6D grip, I thought I was having a drain problem. I did a tear down on the grip and I didn't see any solder blobs etc., and there didn't seem to be that much that could go wrong. When I put it back together, I didn't notice any more issues. This was like 2 years ago so I don't remember the details anymore.
If it's that bad, just take the tray out when you are at home... or try a different brand / new grip :)
That being said, it's your money and you can do whatever you want with it :)
I would rather spend $100 for 3 grips than $900 if I owned three cameras... at one point I had like 4 or 5 full frames (for a job).
Spend $200 or spend $1,200+... (In case you are wondering, I sold most of the cameras after the job - almost free rentals!)
8,657 views & 0 likes for this thread, 13 members have posted to it and it is followed by 3 members.
1677 guests, 137 members online
