Requesting feedback on 2 version of this shot and if any on these 2 are keepers.
Thanks,
joy.pdx Junior Member More info Post edited over 8 years ago by joy.pdx. (2 edits in all) | Aug 04, 2015 00:24 | #1 Requesting feedback on 2 version of this shot and if any on these 2 are keepers. joy.pdx
Aug 05, 2015 10:33 | #2 I think I would try again when they aren't muddy .
AndyE Member 202 posts Likes: 35 Joined Jun 2011 Location: Rolla, MO More info | Aug 05, 2015 11:48 | #3 White balance in the 2nd one seems off. Too warm tones. Gear: 60D; EF-s 17-55mm; EF 16-35mm f/4 L IS; EF 50mm f/1.8; EF 28mm f/2.8; Tamron 70-300mm
Aug 06, 2015 23:15 | #4 Thanks for the feedback. They were very helpful. joy.pdx
Didereaux Senior Member More info Post edited over 8 years ago by Didereaux. | Aug 07, 2015 18:28 | #5 joy.pdx wrote in post #17655632 Requesting feedback on 2 version of this shot and if any on these 2 are keepers. Thanks, As hs been said the second shots WB is completely haywire. Now to the first: The it needs some judicious cropping. Notice that the leaning tree on the right intersects with the top of the waterfall making the waterfall look tilted. So crop off at least past the trunk of that tree. On the left you can crop most of the tree off od that as well. I think enough to make a square crop of the picture. Then go to work and lower the saturation a wee bit on your orange and yellow. This will reduce the muddiness of the water and have little effect on the rest of the picture. Then carefully search for a balance of contrast and whiteness. Your histogram shows you at about as far to the left as you dare go so put most of the emphasis on the highlights to the right. Just tweak. Step back and see if that helps, and gives you further hints on where to go, if necessary, from there. Couple of Canon bodies, a couple of Canon lens, few gadgets all stuffed in a bag...and a stick, and a tripod.
Thanks. Good suggestions. Here is another attempt. Histogram should be better now. Saturation has been tweeked . joy.pdx
Didereaux Senior Member More info | Aug 08, 2015 02:20 | #7 joy.pdx wrote in post #17660541 Thanks. Good suggestions. Here is another attempt. Histogram should be better now. Saturation has been tweeked .
Aug 08, 2015 09:48 | #8 Another view. joy.pdx
Didereaux Senior Member More info | Aug 08, 2015 15:18 | #9
joy.pdx THREAD STARTER Junior Member More info Post edited over 8 years ago by joy.pdx. (2 edits in all) | The shutter speed could have been higher also. The water details did not come out that well as the previous. joy.pdx
Didereaux Senior Member More info Post edited over 8 years ago by Didereaux. | hope you don't mind (didn't see a no edit) so here is my version. Needs a tad more, but you get the idea. Couple of Canon bodies, a couple of Canon lens, few gadgets all stuffed in a bag...and a stick, and a tripod.
Aug 09, 2015 13:26 | #12 Didereaux wrote in post #17661806 hope you don't mind (didn't see a no edit) so here is my version. Needs a tad more, but you get the idea. ![]()
joy.pdx
On similar lines another attempt. joy.pdx
Didereaux Senior Member More info | Joy, I was not attempting to do your work for you. I was merely doing enough to maybe give you an idea of what can be done. It's your picture, you fix it. Couple of Canon bodies, a couple of Canon lens, few gadgets all stuffed in a bag...and a stick, and a tripod.
Aug 09, 2015 15:30 | #15 Didereaux wrote in post #17661806 hope you don't mind (didn't see a no edit) so here is my version. Needs a tad more, but you get the idea.
This is terrible IMO, if you want to show what can be done, than show good work, not 1/2 quality and muted effects. Sony a7R3a/a6300/ 16-70/4 / 70-200/4 G / 12-24/4 G/ 24-105/4 G /Sony HVL-60M
| Latest registered member is johntmyers418 1110 guests, 191 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
