Thread started 06 Aug 2015 (Thursday) 19:06
Hot shoe fail...
tbsguy18
Joined May 2012
Aug 06, 2015 19:06 |  #1
Having an issue with my 60d and the hot shoe...
My flash won't fire, the triggers won't fire, etc...Nothing is lose, it's free of dirt and whatnot, and everything works on my 7D so I know it's a camera issue. Just wondering if anyone on the interwebs had any thoughts before I take it in to be looked at.
Gripped Canon 60D 50 f/1.8---17-50 f/2.8---70-200 f/4 L
EnglishBob
Joined Dec 2004
Aug 06, 2015 19:44 |  #2
First thought, if your flash is not E/TTL, make sure you don't have the camera set for ETTL.
Gallery (external link) MyGear (external link) About Me (external link)
Luckless
Joined Mar 2012
Aug 07, 2015 09:01 |  #3
Check the hotshoe itself and make sure that the side tabs aren't slightly bent or anything. Make sure that the flash is able to be fully seated forward so that the pins can lineup. If that still doesn't work, carefully pull back on the flash just a little and make sure it isn't somehow letting the flash move too far forward.
Do you have an electronics multimeter by any chance? Try manually testing the contacts and see if you can confirm that circuit is closing when you snap a photo.
It could be that the internal contact below the hotshoe has failed and a solder joint has let go.
Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
Flickr: Real-Luckless (external link)
mike_311
Checking squirrels nuts
Gallery: 18 photos
Joined Mar 2011
Aug 07, 2015 11:09 |  #4
does the pop up flash work?
Canon 5d mkii | Canon 17-40/4L | Tamron 24-70/2.8 | Canon 85/1.8 | Canon 135/2L
www.michaelalestraphot​ography.com (external link)
Flickr (external link) | 500px (external link) | About me
tbsguy18
Joined May 2012
Post edited over 8 years ago by tbsguy18.
Aug 07, 2015 12:31 |  #5
Well, I bought brand new batteries for both the flashes and they started working again. Probably should have done that from the get go, but since they both worked on my 7d, I didn't think to. Thanks for the replies!
839 views & 0 likes for this thread, 4 members have posted to it and it is followed by 4 members.
Hot shoe fail...
1081 guests, 157 members online
