Thread started 07 Aug 2015 (Friday) 10:47
Some advice on taking better images
Chrizz
Aug 07, 2015 10:47 |  #1
Hi guys,
I am certain that my gear is just fine and somehow i mess up ..so,
here is an example image i took. This is straight from the camera, sized down and saved for web to keep the size down.
I have always have trouble hitting the sweet spot when it comes to sharpening.
My images look soft vmadvmad
Gear used for this is a canon 500d with the EF 18-55 lens.
Focal length 18mm
exposure 1/160 f/8 iso 100
evaluative metering
All advices are welcomed.
Thanks for reading guys.
**I use photoshop cs6 for processing.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/08/1/LQ_740731.jpg
Image hosted by forum (740731) © Chrizz [SHARE LINK]
Canon 500d | EFS 18-55 IS | Tamron 70-300 SP Di VC USD XLD
bpalermini
Gallery: 197 photos
Joined Mar 2011
Aug 07, 2015 11:02 |  #2
Do you mind if I take a try at processing it and post it here? I don't think sharpness is the issue. I would take the blacks down and the whites up a bit. I think the black adjustment would make a big difference. I would also crop out some of the foreground to get the focus off of the light rocks.
Bob
R6II, R6, EF 16-35L II 2.8, EF 24-70L II 2.8, RF 50 1.8, EF 100L Macro 2.8, RF 70-200L 2.8, EF 100-400L II, EF 200-400L 4, EF 1.4xIII, EF 2xIII, 580EXII, YN560IV, RRS TVC23 + BH55, Fuji X-E2, Fuji X30, LRCC, PSCC
My Web Site (external link) | My Sports Portfolio (external link) | Instagram @bobpal
frayne
Gallery: 54 photos
Joined Sep 2013
Post edited over 8 years ago by frayne. (3 edits in all)
Aug 07, 2015 11:05 |  #3
Just my two cents and I am far from a pro. I think most pictures that are perfectly centered are a bit boring to the human eye where something off center make it much more interesting. Also remember and use the rule of thirds.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/08/1/LQ_740736.jpg
Image hosted by forum (740736) © frayne [SHARE LINK]
The only thing a golfer and photographer needs is more light.
Canon G9/5D/6D/70D Lenses 100-400L IS/17-40L/24-105L IS/100L IS/85 USM
GeoKras1989
Joined Jun 2014
Aug 07, 2015 11:11 |  #4
Noon is just about a guarantee of boring lighting.
WARNING: I often dispense advice in fields I know little about!
Tedder
Aug 07, 2015 12:00 |  #5
Chrizz wrote in post #17659855 (external link)
...I have always have trouble hitting the sweet spot when it comes to sharpening.
My images look soft vmadvmad...
It would be difficult to diagnose the problem from the posted image. It'd probably help, though, if you mentioned which method(s) of sharpening (and noise reduction) you use and what settings you generally select. The sweet spot will vary from image to image.
Tedder Stephenson's Flickr (external link)
Various Items (external link) Mineral Matters (external link) The Bench (external link) Tracks (external link) Cars and Stripes (external link) Behind the Wheel (external link)
Classical Beam Theory Revisited (external link)
Circles of Confusion (external link) Waterous Disturbulations (external link)
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
Aug 07, 2015 12:09 |  #6
GeoKras1989 wrote in post #17659882 (external link)
This.
You won't get "sharp" looking photos without sharp looking light. Also, as noted above, your composition leaves a bit to be desired. Try revisiting the location in the morning or evening and play around with some different angles and zoom levels on your lens.
Fuji X-T3 // Fuji X-Pro2 (Full Spectrum) // Fuji X-H1 // Fuji X-T1
flickr (external link) // Instagram (external link)www.LucasGPhoto.com (external link)
Luckless
Joined Mar 2012
Aug 07, 2015 12:42 |  #7
Better photos are interesting photos, and interesting photos are interesting because there is some reason to look at them.
Ask yourself the question of "Why would someone want to look at this again" can go a long way in producing better photos. What is the point to the photo? Why should someone care about it?
When doing sports photography I have that somewhat easy. People care about my sports photos because usually the people looking at them are in the photo, or are friends of the person in the photo, and they enjoy the action, emotion, or general memory of the moment, and there is 'something happening' in the photo.
However landscapes are, to me at least, a far different thing and much harder to answer the question of 'why should I or anyone want to look at this again?'.
Good luck, and keep questioning things. Answers come through asking questions, and better answers come through learning to ask yourself better questions.
Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
Flickr: Real-Luckless (external link)
Chrizz
Post edited over 8 years ago by Chrizz.
Aug 07, 2015 12:50 as a reply to  @ bpalermini's post |  #8
Bob Palermini,
No problem at all.
Chrizz
Aug 07, 2015 12:52 as a reply to  @ Tedder's post |  #9
Thank you Tedder,
I do all sharpening and noise reduction in camera raw. I am not a pro, just looking to get better at this.
Chrizz
Aug 07, 2015 12:58 as a reply to  @ frayne's post |  #10
frayne,
Very good! thank you!
Chrizz
Aug 07, 2015 12:59 as a reply to  @ EverydayGetaway's post |  #11
Thank you guys!
What are the best times of the day,regarding light, to visit a location for landscape photography??
Chrizz
Aug 07, 2015 13:01 as a reply to  @ Luckless's post |  #12
thank you Luckless!
GeoKras1989
Joined Jun 2014
Aug 07, 2015 13:04 |  #13
Chrizz wrote in post #17659963 (external link)
Thank you Tedder,
Admittedly, I know nothing of your photographic skills. However, this statement may be indicative of your starting a few steps too late in the quest to get better images. You have to get lighting, composition, subject, timing, and framing right first. Then you release the shutter. After all that is done, it becomes time to finagle with contrast, sharpening, and noise reduction. Start at the beginning. Getting it right is a lot easier than fixing it later. I know, I've been struggling to get it right most of my life. :)
Chrizz
Aug 07, 2015 13:06 |  #14
What happens when you dont have the luxury of visiting a place at a different time??
I find myself, during vacations, having the same problem: Images looking TO ME boring.
Will a change of Len help?
Luckless
Joined Mar 2012
Aug 07, 2015 13:09 |  #15
With regards to the best time to visit somewhere for the best light, the honest answer is "It depends". Around sunset/rise is often a favoured time, but it isn't always the best of times. Sometimes you are going to what the shadow and light effect that is only available with a noon sun on a slightly cloudy day, and other times you might want something different from the light. Sometimes you may even want to show up in the middle of the night on a moonless overcast day, and carry around a large high powered flash unit during a massively long multiple exposure shot.
Study light in existing photos that you like, and try to understand what the light is doing, how it is created, and why the photographer would have wanted it like that.
10,628 views & 19 likes for this thread, 24 members have posted to it and it is followed by 10 members.
1084 guests, 161 members online
