mpstan wrote in post #17660145
I want to jump to a Rovelight but cannot quite justify the expense. So I'm going to build on what I have:
Yn622C-TX and a couple YN622 triggers, one 550EX and one 580 I.
I cannot get the YN622C-TX to communicate with my older flashes, so I am considering getting a YN568 EX2 with a trigger.
If I pick a YN568 EX2 with a trigger, and gang all three flashes onto a triple bracket, and optically slave my 550 and 580 to it, will the YN568 EX2 properly communicate TTL or manual settings? Could I adjust settings on my transceiver and expect those setting to then adjust on my older flashes?
Any tips on softboxes that would work nicely with a triple bracket would be appreciated.
Heya,
Take the cost of the 568EXII, trigger, bracket for three speedlites, and all the batteries, plus whatever it takes to get your other older flashes to talk properly with the system you have and see what that adds up to. I'm thinking that $200 more, and you can get your Rovelight and have a simple setup with a powerful single strobe, no wires, already has a battery, and you already have the triggers and you can just pick a modifier and be good to go.
I may be wrong, but just to point out, I think when you go from 1 speedlite to 3 speedlites, the power output is 1.5 stops higher than one speedlite. Someone correct me if that's incorrect. So while it is a little more powerful, if you look at cost for the increase in stops of output (this is important if you consider the modifier you use will cut down on output too), you may find it's not actually worth it for your needs. So again, maybe this is where you can start to justify moving to a strobe for the cost you're willing to go.
But, if you do want to stick with speedlites, maybe consider some 560 III's. They're inexpensive and good. You can use a single TX controller (560TX) and control their power outputs, and you don't have to buy triggers for them as they have built in wifi receivers already. You can get three 560III's for $200 basically, and a single $45 controller (560TX). Portable, the only batteries are those in the flashes and one controller (instead of also needing 3 triggers each with batteries, etc).
I guess I bring that up because I'm curious about the TTL comment, as I don't think TTL in a softbox in general is a good idea. You'll blow through batteries fast, and it will be inconsistent likely in terms of output (as it will be based on a meter). I would just run flashes in manual regardless of which flashes you use.
Alternatively, you could look at some Alien Bee's AB800's if you want to spend $250 or so, and have a good strobe, but it's wired and not portable. The alternative would be a Godox AD360 that is portable with the features you'd want for $400. Or, for $480 or so, the Rovelight which does it all.
I ended up going from multi-speedlites to the Rovelight for a portable 600ws strobe, and while it was more expensive than a bunch of speedlites, it's more powerful and ultimately way more simple to use and less accessories to bother with, so it burned my wallet a little for a minute, but it only hurt once, and now I have the ability to do HSS and over power the sun, something my speedlites couldn't do. And portable to boot with no wires.
Here's an example to show size:
Speedlite + battery pack (to shoot full power 1/1 in sunlight)
IMAGE LINK: https://flic.kr/p/u9CEEN
IMG_7883
by
Martin Wise
, on Flickr
Rovelight + Yn622 trigger in the synch port for HSS and triggering in general (I've since put a velcro patch on there so it just sits on the side of the light, this was when I first got it and was testing it out)
IMAGE LINK: https://flic.kr/p/vFSMUa
IMG_4462
by
Martin Wise
, on Flickr
Obviously without the 48" octa attached or a smaller 43" umbrella like the speedlite has, or 60" umbrella. But I've become very much happy with umbrellas simply because of portability. So I actually favor the 60" umbrella for simple ease and lighter weight on my boom stand when I'm running around in the sun.
Anyhow, with the Rovelight, I can fill a subject that is backlit in the Florida sun from pretty far away. This is with the bare Rovelight with no modifier at 1/2 power at about 12~15 feet to a backlit subject, I used it for fill:
IMAGE LINK: https://flic.kr/p/vDcfx7
IMG_4461
by
Martin Wise
, on Flickr
Very best,
