Thread started 11 Aug 2015 (Tuesday) 08:42
Perseids Meteor Shower Aug 12-13
Celestron
Aug 11, 2015 08:42 |  #1
For those of you who still stay up and do night time photography , the Perseids meteor shower is coming as scheduled Aug 12-13 . This is a great photo opt for those that like shooting the night sky . Look forward to someone starting a thread and posting their pictures . This starts Wed night .
mtbdudex
Gallery: 35 photos
Aug 11, 2015 15:42 |  #2
Let's see, new moon, and clear skies / low humidity projected here in SE Michigan, yep I'll do some imaging Wednesday and Thursday
Mike R, P.E. ...iMac 27"(i7), iPad2, iPhone14Pro, AppleTV4K, MacBook
Canon: Body R5, lens RF 24-105mm L F4, RF 100-500mm f/4.5-7.1L, 1.4 TC, EF 70-200 L f2.8 IS II / TC 1.4x 2x
FEISOL tripod CT-3441S + CB-40D Ball Head
My top 10 in Astrophotography. . .DIY acoustic panels (external link) . . APOD Aug-5-2011 (external link)
JohnPh
I smell like a Shoulder Shrugging Seal
Gallery: 210 photos
Joined Oct 2011
Aug 11, 2015 16:29 |  #3
I'm keeping everything crossed for clear skies in my neck of the woods but it isn't looking good :(
ՕFlickr (external link)
Facebook (external link)
serial underexposer
Gear
Celestron
Aug 11, 2015 18:03 |  #4
JohnPh wrote in post #17665255 (external link)
See if there is a Clear Sky Clock close to you . Follow the link , click on your state and find the closest ClearSky Clock to your location . It's always right on !
http://www.cleardarksk​y.com/csk/ (external link)
RKSphoto
Aug 11, 2015 18:27 |  #5
Does anyone have any tips or advice on shooting a meteor shower?
Never done it before and would like to experiment.
RKS
Nashville, Tn.
Canon 70D - Canon T4I and Canon 40D / Canon 100-400 v2 / Canon 24-105 L / Canon 17-55 2.8 / Canon 85mm 1.8/ Canon 50mm 1.4 / Canon 100mm 2.8 Macro / Sigma 70-200 2.8 / Sigma 10-20 [COLOR=red]/ Sigma EF530DG Super Flash
Celestron
Aug 11, 2015 22:44 |  #6
RKSphoto wrote in post #17665403 (external link)
Then you need to practice tonight and as it gets' dark Wednesday night . Put the camera on a tripod and do long exposures If shooting with a 2.8 or faster lens then anywhere between 15-25 secs per exposure . If using a 4.5 or slower then 20-35 secs depending the lens . Use a wide angle lens . If your camera is a FF then don't use smaller than a 28mm lens . If using a crop camera you can use down to 16mm but me personally I wouldn't go lower than 18mm . Use a remote if you have one and set your mode to bulb and expose for the lengths you need . If you have a fast lens and you start exposure and a meteorite passes in the FOV I would still expose for 15-20 secs. If a slow then continue for 20-30 secs. Mainly it will be trial and error for you . When you focus you can use LIVE VIEW if your camera has one . if you have a bright enough object in the sky you can focus on that object then switch your camera over to manual focus but do nopt touch the lens or focusing ring any more . Shoot a couple and check your shots by zooming in . If your stars have a nice sharp round brightness then your probably good to go but if they need tweaking then do so very carefully . Good luck and be sure to post your pictures if you capture any meteorites !
sirquack
Gallery: 66 photos
Joined Jan 2013
Aug 12, 2015 12:06 as a reply to  @ Celestron's post |  #7
What is the reason for not going wider than 28mm on FF. I have a 24-70 2.8 that I plan to use this evening with my 6D. I will be trying incorporate a bit of the scenery and hope to do a little light painting to accomplish that. But I will be out from about midnight to close to 4 am in the plan at this point.
I just want to see if I can get usable shots this evening. I have a nice dark sky are picked out and if things work out, this will not be my last effort at this location. I also have hopes of eventually catching some Milky Way shots in this location when the conditions are right.
Thanks in advance for any input that can be provided.
Name is Ron.
Bodies - 6D/5D3/7D2-Gripped
Lenses - Canon 17-40 F4/24-70 F2.8 II/85 F1.8/Canon 70-200 F2.8 II/F4/Sigma 30 DC/Tamron 150-600
Website (external link)
DreDaze
Gallery: 49 photos
Aug 12, 2015 13:01 as a reply to  @ Celestron's post |  #8
why not go below 18mm on a crop also? i would think you would want to be able to get as long of an exposure as possible...going to 10mm will allow for nearly double the shutter time
Andre or Dre
gear list
Instagram (external link)
Celestron
Post edited over 8 years ago by Celestron.
Aug 12, 2015 17:13 |  #9
sirquack wrote in post #17666225 (external link)
DreDaze wrote in post #17666274 (external link)
Sorry I didn't get back sooner . Work for me is a factor :( . Reason for not going wider than a 28mm on a FF and 18mm on a crop camera is because the FOV . With either lens on those cameras will make a meteorite very small and if you try to enlarge the image they will start to look pixelated . Besides a 28mm on a FF camera will cover quite a bit of the skies FOV and same goes for 18mm on a crop camera . When shooting meteor showers you don't really need to worry about FG being in the image . A nice star BG will make a meteorite image look great ! Check out the images in this gallery at spaceweather.com and you can see what proper meteorite images look like and also many have info with EXIF info so that can help you choose settings and lens size .
http://spaceweathergal​lery.com/meteor_galler​y.html (external link)
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Aug 13, 2015 10:38 |  #10
My first astro last night for Perseids...
IMAGE: https://farm6.staticflickr.com/5756/20354131320_c7b33aab8e_b.jpg
IMAGE LINK: https://flic.kr/p/x1Cf​7C  (external link) Perseid 2015 (external link) by Scott Tice (external link), on Flickr
Getting better at this - Fuji X-t5 & X-t3 - 16 1.4 - 35/50/90 f2 - 50-140 - flickr (external link) - www.scottaticephoto.co​m (external link)
JohnPh
Gallery: 210 photos
Joined Oct 2011
Aug 13, 2015 10:50 |  #11
Saw some excellent Perseids as I was getting set up but cloud ruined the rest of the night :(
IMAGE: https://farm6.staticflickr.com/5651/20514026222_2293856425_b.jpg
IMAGE LINK: https://flic.kr/p/xfKK​ih  (external link) A single perseid (external link) by John Phelan (external link), on Flickr
serial underexposer
Gear
3,619 views & 6 likes for this thread, 7 members have posted to it and it is followed by 4 members.
1573 guests, 136 members online
