Okay, this may be long, but I'll be interested in the responses. When I got my 7d2, I used a very fast Samsung microSD 64gb card in an adapter with no problem. I later added a good CF card for rollover if I filled the SD. I never had an issue and had good write performance. Fast forward to a trip in June. I wasn't going to have a laptop along so I changed my on camera tactics. I bought 2 Lexar microSD 633x 32gb cards and one Lexar Pro CF card, also 32gb. That gave me two microSD/CF card pairs for writing to at the same time. When I got home from the trip, I found that both microSD cards has some partially corrupt images on them. The CF cards were fine. I'd be very surprised if I got two bad cards from Lexar. I experimented with only using the microSD and on CF to see if the redundant writes were the issue. Nope, still had about 1 out of a hundred partially corrupt images on both. Two different brands of SD adapters were used. Now I'm going to try another, newer adapter and see if that is the issue.
So, my original thinking was that using an adapter was going to be a good idea since on a SD card, it is the little plastic fingers on the back that get damaged for me usually. So this way that would be on the disposable part. Now I'm re-thinking that idea.
So, like you, I'd like to hear others issues or thoughts on microSD with adapter or full sized SD cards.
