FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 12 Aug 2015 (Wednesday) 19:04
CF vs. SD card image quality
Quack ­ Me ­ Up
Joined Nov 2011
Aug 12, 2015 19:04 |  #1
Sorry if this has been answered before but I was wondering if there has ever been any testing done to see if there any difference in image quality when an identical image is saved to and SD and a CF card? I'm not talking about saving the same image to both cards simultaneously in cameras that have that option but I'm just curious if there's any image difference between the two formats, all else being equal.
Thanks.
CanonCameraFan
Joined Sep 2011
Aug 12, 2015 19:48 |  #2
I can not imagine any reasonable reason for it to be so. It is all the same digital signal, no difference in interpreting it in any manner. Digital is not to lose any info unless there is an actual error. Resolution does not apply. Otherwise, digital checks (CRC Checksum whatever...) would not be possible.
EOS 7D w/BG-E7 (3), 550EX (3), 430EX II, Vivitar 285HV, Opteka 6.5mm/3.5, Canon EF-S 10-18/4.5-5.6 IS STM, Canon EF-S 24/2.8 STM, Canon EF 40/2.8 STM, Canon EF 100mm/2.0 USM, Canon EF 70-300mm/4-5.6 L IS USM, Canon 77mm 500D Macro, Tamrac 614 Bag & 787 Backpack, Crumpler 8 MDH, 7 MDH, 6 MDH
http://www.flickr.com/​photos/johnebersole/se​ts/ (external link)
wunhang
Aug 12, 2015 21:13 |  #3
The 1s and 0s of the digital file will be the same no matter it is saved to an SD, CF, or hard drive.
Canon 5D IV | Canon 5D II | XSI (Infrared modified) | SL1 | 16-35mm L f/4.0 IS | 24-70mm L f/2.8 II | 40mm f/2.8 | 85mm f/1.8 | 70-200mm L f/4.0 IS | Rokinon 14mm f/2.8 | C/Y 28mm f/2.8 | Tamron 35mm f/1.8 VC | C/Y 50mm f/1.7 | Zeiss 100mm MP
::SmugMug (external link)::
mike_d
Aug 13, 2015 01:39 |  #4
CanonCameraFan wrote in post #17666748 (external link)
You mean those $200 3' HDMI cables aren't any better than my $2 Monoprice ones?  :p
Canon ­ Amateur
Gallery: 50 photos
Aug 13, 2015 03:30 as a reply to  @ mike_d's post |  #5
AFAIK SD and CF store digital information and HDMI transports digital information.
And yes, if you try both cables on my television set I would not see the difference.
Canon EOS 1Dx / 5D4 / 5Dsr / Fujifilm X-T4 / Lytro illum
Jon
Joined Jun 2004
Aug 13, 2015 09:34 as a reply to  @ mike_d's post |  #6
Depends on how well made the cables are. You can experience differences between cables if one cable isn't well shielded against interference, if the contacts aren't reliable, or if the one cable's more vulnerable to bending than the other. Whether you'd see/hear this through an analog (eyes/ears) interface is another matter. But think about a new set of headphones vs. one that you've been banging around for a while.
Jon
Cocker Spaniels
Xyclopx
Gallery: 33 photos
Post edited over 8 years ago by Xyclopx.
Aug 13, 2015 13:00 |  #7
Quack Me Up wrote in post #17666687 (external link)
Thanks.
i think the answers above are going to be confusing, cause they're not talking about the same mechanism. as jon and others alluded, there are differences in quality among transport systems that can cause small variances, but again, that's not relevant here.
but for your purposes, in the case of your camera saving a picture, the whole advantage of digital is that every copy is identical (vs something analog like film.) so, there will be 0 difference.
Dean Chiang (external link) | Facebook (external link) | Blog (external link) | Gear (external link)
My Photos (external link)
Instagram @xyclopx (external link) @feetandeyes (external link) @gastramour (external link)
elrey2375
Thinks it's irresponsible
Joined Nov 2011
Aug 15, 2015 04:05 |  #8
The format is not different between CF and SD. The format is either RAW or JPEG. There's on difference.
http://emjfotografi.co​m/ (external link)
http://500px.com/EMJFo​tografi (external link)
Wilt
Post edited over 8 years ago by Wilt. (3 edits in all)
Aug 15, 2015 11:17 |  #9
If a photo in the camera, (let us assume a four pixel camera, yeah absurd but useful for illustration purposes) the acquired four pixels of data are these
  1. 11000011010101
  2. 11000011011101
  3. 11000011110101
  4. 11000111010101
CF vs. SD merely is a distinction of how 'bits' are grouped when going in/out of the memory card, that's all. Bits get sent to CF in groups of eight (parallel transfer), bits get sent to SD as a string of single bits (serial transfer).
(aside: Does that give you insight why a Canon is faster in storing a photo to CF than it can when storing the same photo in SD?!)
the camera sends that string of 'bits' of data, 8 bits at a time, to a CF card...
11000011 01010111 00001101 11011100 00111101 01110001 11010101
or the camera sends those same string of bits, ONE bit at a time, to an SD card...
1 1 0 0 0 0 1 1 0 1 0 1 0 1 1 1 0 0 0 0 1 1 0 1 1 1 0 1 1 1 0 0 0 0 1 1 1 1 0 1 0 1 1 1 0 0 0 1 1 1 0 1 0 1 0 1
Later, in your computer you can transfer data from a CF card to an SD card...
11000011 01010111 00001101 11011100 00111101 01110001 11010101,
or vice versa, but apart from how the bits are grouped (or not), it is the same string of bits.
Therefore there is ZERO implication on the 'image quality due to which device stores the photo within a camera, just as there is ZERO implication on the image quality caused by transferring the photos between SD and CF using the computer.
Quack ­ Me ­ Up
Joined Nov 2011
Aug 16, 2015 19:44 |  #10
Thanks to all for the input. Very informative.
eelnoraa
Aug 23, 2015 04:04 |  #11
absolutely no difference in image quality. because the file is in digital form, not analog.
As to SD, the IOs are NOT one bit at a time, but 4 bits at a time. There are total of 4 IOs in SD card form factor.
5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
appdroid
Joined Dec 2012
Aug 26, 2015 00:37 |  #12
Yeah i would agree it's just different methods of storage.
EOS R6 Gripped l EOS R Gripped l 24-70 2.8 L II l 70-200 2.8 L II l 16-28 2.8 l 35 1.4 Art l 85 1.8
http://www.Picturesque​byAP.com (external link) flickr (external link)
NinetyEight
"Banned for life"
Aug 27, 2015 05:16 |  #13
I think something must happen transferring between different media, because quite often an image looks great on my camera lcd display, but when I get back home and transfer it to my PC and look at it in Lightroom or whatever it's not sharp/out of focus and/or badly exposed - It must be the make of hard drive I have... :lol: :lol:
Kev
3,020 views & 2 likes for this thread, 12 members have posted to it and it is followed by 2 members.
1507 guests, 129 members online
