Thread started 14 Aug 2015 (Friday) 06:34
60d and long exposures
Frodge
Joined Nov 2012
Aug 14, 2015 06:34 |  #1
Speak to me about these red dots I see in some photos. Are these dead pixels? I've actually seen this on both bodies I own. Is it from using too low an iso and no in camera noise reduction? Seems common but I'd like to eliminate it in post.
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
John ­ from ­ PA
Joined May 2003
Post edited over 8 years ago by John from PA.
Aug 14, 2015 06:48 |  #2
Are you only getting these on a long exposure? I see in another thread you were shooting some long stuff using the bulb function because you didn't have a remote release. Anyway, you likely should have had long exposure noise reduction enabled to minimize the issue, But beyond that it sounds like a dead or stuck pixel. See https://photography-on-the.net/forum/showthre​ad.php?t=980057 for a discussion. It will often clear and procedures are mentioned in that thread. There are also some YouTube videos floating around.
The downside is once there, only post processing will get rid of them.
Frodge
Joined Nov 2012
Aug 14, 2015 07:43 |  #3
It's odd because I've just recently experimented with long exposure. There are a couple red dots that I can see, and this is with both of my bodies. I'm assuming that because of these spots a sensor replacement is the only thing to totally eliminate this. This has to be some sort of defect with canon sensors? My tow bodies have 10000 exposures between the two of them and very few long exposures. So I'm not sure how I burned my sensor up already. I would say that between the two, I have shot 30 thirty second exposures and maybe 3 or four one minute exposures. These sensors are not durable?
GeoKras1989
Joined Jun 2014
Aug 14, 2015 08:17 |  #4
Those red spots are 'hot pixels'. They are normal and nothing is wrong with your camera. You can map them out by doing a manual sensor cleaning. You will want to verify the procedure, but it is something like this:
Remove lens.
Dive through menus to find MANUAL SENSOR CLEANING (NOW?) or something like that. Activate it. The mirror will flip up allowing you access to the sensor. DON'T DO ANYTHING INSIDE THE CAMERA!
Let it sit for about 30 seconds.
Turn off camera.
Remount lens.
Remove battery for a few minutes.
I believe this process detects and 'maps out' the hot pixels. I did this on my 500D years ago and it worked like a charm. I never needed it on my 60D and it was over 20,000 shots when I sold it. I hope this helps.
WARNING: I often dispense advice in fields I know little about!
rrblint
Gallery: 84 photos
Joined May 2012
Aug 14, 2015 10:12 |  #5
GeoKras1989 wrote in post #17668437 (external link)
Remove lens.
Don't forget to attach the body cap here
Turn off camera.
Remove body cap here
Remount lens.
Mark
GeoKras1989
Joined Jun 2014
Aug 14, 2015 10:16 as a reply to  @ rrblint's post |  #6
Mark, of course your additions are correct. Thank you.
1,953 views & 1 like for this thread, 4 members have posted to it.
1294 guests, 135 members online
