Can some of you please take a look and let me know which of these few 27" IPS Monitors would be the better choice for photo editing?
http://www.bhphotovideo.com …19&Ntt=ips+27%22+monitors![]()
Kinda confused on what to look for.
Thanks.
Naturalist Adrift on a lonely vast sea 5,769 posts Likes: 1251 Joined May 2007 More info | Aug 15, 2015 20:42 | #1 Can some of you please take a look and let me know which of these few 27" IPS Monitors would be the better choice for photo editing?
Eyal Senior Member 569 posts Joined May 2011 More info | Aug 16, 2015 00:34 | #2 That questions is way too open. 5DMarkIII+Grip | Extender 1.4x III / 2x III
Aswald Goldmember 1,162 posts Likes: 106 Joined Oct 2013 Location: London, Paris, NY More info | Aug 16, 2015 00:59 | #3 For photo editing, these are what I'd recommend.
Bleufire Goldmember 1,203 posts Likes: 53 Joined Mar 2008 Location: California More info | Aug 16, 2015 01:09 | #4 Going to assume you know nothing of monitors so I'll just give what I know about em which is fairly brief.... 5D*Sigma 50/1.4*EF 17-40/4
Aug 16, 2015 09:55 | #5 Thanks for the replies thus far.
Luckless Goldmember 3,064 posts Likes: 189 Joined Mar 2012 Location: PEI, Canada More info | Aug 17, 2015 11:54 | #6 Setting a budget and keeping a workflow and workspace in mind will let you get the most for your money. Also of importance is the graphics output on your system. (There isn't much point in using up your budget on a monitor that your system can't output to with a decent signal. Not much of an issue if you're only going for a 1080P signal, but can be a problem with larger displays.) Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
Aug 18, 2015 12:44 | #7 Naturalist wrote in post #17670775 Thanks for the replies thus far. I know IPS is better than the TN types and I am not looking at 4K. I was thinking max 27" screen but of the ones in the link, do not know which would be the better monitor. I planned on paying up to around $900. Again, thanks for the education and thoughts and keep the replies coming. If you're ok with spending $900, just get a 4K monitor now: the increase in resolution is well worth the cost.
Aug 18, 2015 18:28 | #8 Thanks again. Good replies.
Aswald Goldmember 1,162 posts Likes: 106 Joined Oct 2013 Location: London, Paris, NY More info | Aug 19, 2015 03:58 | #9 adamo99 wrote in post #17673729 If you're ok with spending $900, just get a 4K monitor now: the increase in resolution is well worth the cost. As long as you have a recent graphics card, the extra resolution isn't taxing on any current system. I run a 4K display off my Toshiba laptop, and there's no lag. (photo editing isn't very demanding on graphics hardware). ViewSonic VP2780 (personal experience, phenomenal monitor) http://www.amazon.com …r-3840x2160/dp/B00SHZSXVI but also hear good things about the new Dell display: http://www.amazon.com …r=1-1&keywords=dell+p2715 4k 30hz or 60hz?
Aug 20, 2015 11:03 | #10 Aswald wrote in post #17674633 4k 30hz or 60hz? k4 60hz on a 27" (or on dual 4k or k4+2k monitors) isn't as straight forward sometimes compared to 4k on a laptop screen. What?
Luckless Goldmember 3,064 posts Likes: 189 Joined Mar 2012 Location: PEI, Canada More info | Aug 20, 2015 11:38 | #11 adamo99 wrote in post #17676378 What? ![]() I'm running an external 4K display off my Toshiba laptop, not on the internal screen. I've run both 30Hz and 60Hz, for image editing, there's no significant difference. Everyone making noise about how 30Hz sucks are gamers, where frame rates are more important. Entirely irrelevant for image editing applications. 30Hz is slow enough to make for less than smooth mouse movement, and can lead to noticeable rendering flicker even in some 2D applications. It can also be annoying to watch video feeds on. Is 30Hz usable? Sure. Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
I've never had an issue with mouse movement. Also, most video is either 24 or 30fps, so 30Hz is more than sufficient. With a good IPS panel, 30Hz will be perfectly fine for anything image editing related.
CyberDyneSystems Admin (type T-2000) More info | Aug 20, 2015 13:29 | #13 Since you have already narrowed it down to 27" IPS, which I agree is just about perfect choice, I will offer my opinion on those monitors you list. GEAR LIST
Aswald Goldmember 1,162 posts Likes: 106 Joined Oct 2013 Location: London, Paris, NY More info | Aug 20, 2015 22:19 | #14 adamo99 wrote in post #17676378 What? ![]() I'm running an external 4K display off my Toshiba laptop, not on the internal screen. I've run both 30Hz and 60Hz, for image editing, there's no significant difference. Everyone making noise about how 30Hz sucks are gamers, where frame rates are more important. Entirely irrelevant for image editing applications. If one is going 4K, I'd highly recommend a gpu which can do 4k 60Hz.
| Latest registered member is semonsters 1470 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
