Thread started 17 Aug 2015 (Monday) 23:09
Canon 7d mkii file numbering keeps resetting
squires
Aug 17, 2015 23:09 |  #1
File numbering on my 7dii is set to continuous and I have had no issues with it up to this point. I also had it set up to write RAW files to the CF card and a jpg to the SD card. This past weekend I reached 9999 for the first time. It rolled over back to 0001 and incremented from there. However, the next memory card I put in(and formatted) it reset back to 0001. I ended up with 3 memory cards of identical file names because it reset back to 0001 on each card.
After experimenting a little more recently, it is resetting to 0001 each time I format the CF card. Then I remembered the SD card. I removed that, shot with CF card only and no issues. I put in a different SD card, formatted both the CF and SD card and no issues.
The SD card I removed was the one that was in the camera when the numbering rolled over from 9999 to 0001. The camera created a new folder and started from 0001 on the SD card. Each time I put in a new CF card and formatted, it created a new folder on the SD card and started at 0001.
Is there a way to keep this numbering reset from happening the next time it rolls over from 9999 to 0001?
CameraMan
Gallery: 26 photos
Aug 17, 2015 23:15 |  #2
There's a number setting in the menu somewhere. I had the same problem with my 350D years ago. Google it. You should be able to find the answer.
Photographer (external link) | The Toys! | Facebook (external link) | Video (external link) | Flickr (external link)
Shampoo sounds like an unfortunate name for a hair product.
You're a ghost driving a meat-coated skeleton made from stardust, riding a rock, hurtling through space. Fear Nothing!
BigAl007
Gallery: 542 photos
Aug 18, 2015 04:27 |  #3
Avoid having cards with different numbering on them in the camera. The problem is that even with contiuos numbering, if you insert a card with a higer number it will reset the numbering to that when you insert and format a new card. As you have a card with 9999 in the camera already, it is resetting the count to that value, so when you format the new card the next sequential number is 0001.
Alan
My Flickr (external link)
970 views & 0 likes for this thread
Latest registered member is dayuan99
661 guests, 303 members online
