Thread started 18 Aug 2015 (Tuesday) 10:39
Help Getting Lightroom 5 to Recognize External Drive
Larry ­ Johnson
Joined Sep 2011
Post edited over 8 years ago by Larry Johnson.
Aug 18, 2015 10:39 |  #1
How do I get Lightroom to recognize my external drive while in Library mode. I need to move a dozen raw files back to their original folders. I accidentially moved them (instead of copying them) during an import and they ended up in an existing gallery with 100+ other raw files on my hard drive. Lightroom recognizes my external drive when I select Import, but not otherwise. I'm using a Mac if that matters. Thanks.
Ain't Nature Grand!
Shooting 7D2 with Canon 400mm, f/5.6.
60D, canon 18-135 EFS, and 1.4 extender in the bag.
Bcaps
I was a little buzzed when I took this
Gallery: 90 photos
Best ofs: 16
Joined Jun 2003
Aug 18, 2015 10:47 |  #2
Did you actually import a file from the external drive, or cancel out of the import after seeing the drive showed up? If you import a photo from the external drive it should then show up in library mode.
- Dave | flickr (external link)
Nikon D810
14-24mm f/2.8 | 16-35mm F/4 | 24-70mm f/2.8 | 70-200mm f/4 | Sigma 150-600mm
Larry ­ Johnson
Joined Sep 2011
Post edited over 8 years ago by Larry Johnson. (2 edits in all)
Aug 18, 2015 11:08 |  #3
Bcaps wrote in post #17673544 (external link)
I didn't cancel out of anything.
I actually imported (moved, not copied) a dozen files from several different folders on my external drive into an existing gallery that's saved on my hard drive.
The only way that I can view my external drive in Lightroom is by selecting Import.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/08/3/LQ_742761.jpg
Image hosted by forum (742761) © Larry Johnson [SHARE LINK]
Ain't Nature Grand!
tzalman
Fatal attraction.
Aug 18, 2015 11:53 |  #4
As Dave said, import a photo that is on the external - any photo, you can remove it from the catalog later - using "Add". The external will then show up in Library/Folders.
Elie / אלי
Larry ­ Johnson
Joined Sep 2011
Aug 18, 2015 12:02 as a reply to  @ tzalman's post |  #5
I've figured it out. In order to see the folders on the external drive in Library mode, I had to click on the + sign in the folders list and add that folder to the "system". However, now another problem. I want to move files back to the original folder, but the check boxes aren't present under the individual photos when the "all photos" box is not checked. Will have to work on it later tonight. Have to run.
I guess I could just move the files using Finder and Copy/Paste on my mac, but that seems to be accepting defeat.
Ain't Nature Grand!
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Aug 18, 2015 19:04 |  #6
Larry Johnson wrote in post #17673667 (external link)
Generally not a good idea to move images outside LR as it knows nothing about the change and so the images show up as lost and need to be re-linked.
Much better to just select all the images and then drag/drop them to the new location within Lightroom.
Dan Marchant
tonylong
...winded
Gallery: 60 photos
Aug 18, 2015 19:11 |  #7
If you have a named sub-folder for a set of images you can move the folder (dragging and dropping or select the folder and then in the target "parent" folder choose the right-click Move option). If you don't have a target parent folder you can create one in Lightroom, and then do the above Move.
Tony
2,022 views & 0 likes for this thread, 5 members have posted to it and it is followed by 3 members.
1689 guests, 140 members online
