Thread started 22 Aug 2015 (Saturday) 23:17
shooting with lens detach? posible?
ph2003
Aug 22, 2015 23:17 |  #1
Hi guys.
Is it possible to shoot with no lens?
The camera just say no lens everytime I removed the lens. It wont let me shoot :(
I am trying to shoot some light leaks effects.
Thanks!
ph2003
Aug 22, 2015 23:26 |  #2
Ah nvm it can work s in video mode.
Just cant shoot still.
urbanfreestyle
I am a squirrel who loves rubbing bottles and I have Nuts in my drawers, too!
Joined Dec 2013
Aug 22, 2015 23:30 as a reply to  @ ph2003's post |  #3
can you help us out with what camera you are using?
Have you tried in manual mode?
Facebook (external link)
Canon 1D Mk IV | Canon 50mm 1.8 Mk1 | Sigma 'Bigma' 50-500 | Fuji XE1 | Helios 44/m | 50mm 1.4 | Manfrotto 055CX PRO3 | 3LT Mohawk ballhead | Lubitel 2 med format camera |
splashdad
Joined Feb 2015
Aug 22, 2015 23:59 |  #4
Depends on the model. I can do pinhole shots with no lens with my 400D but a Sony DSLR wouldn't let me.
Petie53
Joined Jan 2014
Post edited over 8 years ago by Petie53.
Aug 23, 2015 08:10 |  #5
Would think there is a way. Have not used it yet but have an adapter to hook my Canon to my telescope and it is nothing more than a metal ring with the proper mount connections on each side but no electronic connections so would think the camera would not identify anything was installed.
Do you have a 1.4X or 2.0X extender or a macro ring that you could try without a lens attached?
Pete
Pete
6D, 60D, EOS-M, EOS-M3, 22M, 11-22M, 18-55M, 55-200M, 15L 2.8 fisheye, 10-22 EFS, 35 F/2 IS USM, 18-135 STM, 24-70L 2.8 II, 70-300L, 100-400L II
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Aug 23, 2015 08:51 |  #6
As others have mentioned make sure you are in manual mode. That reduces the required feedback from the lens. It can be done as there are users out there who freelens, taking shots with the lens detached from the body slightly to alter the focal plane.
BigAl007
Gallery: 556 photos
Aug 23, 2015 08:57 |  #7
For Canon EOS DSLRs you can actually set the camera to Aperture priority, and the camera's metering system will set the necessary shutter speed. This applies to both Free lensing, and using a un chipped mount converter. The only difference to using a normally attached EF mount lens is that you cannot then change the aperture value. The aperture recorded in the EXIF data will normally be f/0.0.
Alan
Wilt
Post edited over 8 years ago by Wilt. (2 edits in all)
Aug 23, 2015 09:37 |  #8
Shooting without a lens...what would focus light onto the sensor?! You need something with optics in it, whether a microscope or telescope or even a tiny pinhole in aluminum foil which serves as virtual optics to project an image onto the sensor...or else you are shining small beams of light directly onto the sensor (careful shining a laser!)
One thing you can do to fool the camera is to merely mount an adapter ring with AF confirmation chip, even with no lens in front of the adapter! But in M mode you do not even really need that.
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Aug 23, 2015 10:22 |  #9
assuming you have the 6D that we were discussing in another thread, my 6d will release the shutter (take a picture) in every mode, including automatic.
but the following is true, you will get nothing but a blurred blob.
Wilt wrote in post #17679663 (external link)
BigAl007
Gallery: 556 photos
Aug 23, 2015 10:49 |  #10
Freelensing, for those that have not come across it, is done by (usually) hand holding an unmounted lens in front of the camera. The added extension will generally make for quite close focusing distances, so you are unlikely to see infinity focus. Also the fact that you are not necessarily going to keep the lens perfectly aligned, you are likely to see both shift and tilt effects, at least within the available lens projection circle. Doing freelensing with lenses designed for larger formats can help with all of those things though. A lens with manual aperture control is also useful.
Alan
Gallery: 15 photos
Joined Jun 2011
Post edited over 8 years ago by Left Handed Brisket.
Aug 23, 2015 10:54 |  #11
BigAl007 wrote in post #17679743 (external link)
Alan
that sounds interesting. I have some medium format lenses i might mess around with using that technique.
but, :D the OP did say "Is it possible to shoot with no lens?" so, I at least, was just going on that bit of information.
GeoKras1989
Joined Jun 2014
Aug 23, 2015 11:30 |  #12
My 6D will trip the shutter in any mode with no lens attached. I'd try my film body, but it has film in it.
WARNING: I often dispense advice in fields I know little about!
BigAl007
Gallery: 556 photos
Post edited over 8 years ago by BigAl007.
Aug 23, 2015 11:58 |  #13
GeoKras1989 wrote in post #17679797 (external link)
Yes Canon EOS cameras are quite good in that respect, and will function fully apropriatly in any exposure mode. Some other makes are different. As I understand it for example Nikon cameras in this situation will only work in Manual Exposure mode. Other makes may have other restrictions.
Alan
davesrose
Title Fairy still hasn't visited me!
Aug 23, 2015 13:46 |  #14
Well if the question is if it's possible to take a picture without a lens attached, the answer is yes. On my Canon, there's a setting in the menu for disabling or enabling picture taking with the lens off.
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
John ­ from ­ PA
Joined May 2003
Aug 23, 2015 14:34 |  #15
My Elan IIe would work with close to no lens. I would often turn a normal lens around and just hold it against the body. This was good for pseudo "macro" and I used this technique regularly for close ups of machinery failures. I later discovered a reverse mount adapter which gave me improved IQ since the lens was properly centered relative to the film plane.
I'll have to see if the reverse mount adapter still work with my DSLR.
3,823 views & 1 like for this thread, 12 members have posted to it and it is followed by 3 members.
1099 guests, 174 members online
