Thread started 23 Aug 2015 (Sunday) 09:53
Backyard Practice, Need Inputs
Jiggo0109
Gallery: 16 photos
Joined Sep 2013
Post edited over 4 years ago by Jiggo0109.
Aug 23, 2015 09:53 |  #1
Hi guys, I am looking for answers about ocf at bright sunlight. I have speculations of the solution to my problem but I need confirmations from you. I hope you can help me on this one because I really want to improve on this. I will post some photos on ow I did it and pardon me for the out of focus shots and uninteresting photos. Just the lighting I am concerned of in this thread.
Here is the situation: Took my son out (and he was very impatient of the hot weather outside) at about 2pm Manila time. The sun was about 120 degrees from our heads.
Took this shot at 2.8, 250th at 640 ISO. just to show you harsh the sun is.
IMAGE: https://farm6.staticflickr.com/5717/20822876601_77f5ea2b09_z.jpg
Exposed the BG. ND filter 6 stops, 2.8, 250th at 250 iso
IMAGE: https://farm6.staticflickr.com/5780/20806336242_cedfd026d9_z.jpg
Fired with 300 watts strobe camera left at about 5ft with the standard bowl at full power. This is where my questions are: Notice I have two sets of shadows, one from the sun and the other from the strobe. How would I get rid of the sun's shadow? Would a 600 watt strobe take care of this?
IMAGE: https://farm1.staticflickr.com/698/20627764500_4150d2d407_z.jpg
Tried to transfer the strobe behind me but I still have two sets of shadows... Should I consider The angle of the subject this time or is it really the strobe I should upgrade?
IMAGE: https://farm1.staticflickr.com/717/20789483206_66221be468_z.jpg
Lastly, We changed positions. sun behind him and bumped up my iso to 1000. Filter still on. Should I take the filter off the lens this time? But was successful in getting rid of the sun's shadow in this photo (I think).
IMAGE: https://farm6.staticflickr.com/5820/20628983489_e356c98fe8_z.jpg
Hope you can help me on this. I am planning to purchase a 600 watt strobe and currently I am already equipped with a 6ft parabolic umbrella. Thanks.
tandemhearts
Joined Mar 2014
Aug 23, 2015 10:09 |  #2
Don't use the ND filter and ISO 1000 at the same time. They are doing opposite things.
Beyond that, the "right" answer spends on the look you want.
I'd put the sun behind him, get the exposure set so that the highlights on this shoulders do not blow out. Put umbrella off axis 30 degrees, high and see what I got. In other words, your last shot is pretty close to what I'd do.
clipper_from_oz
Gallery: 26 photos
Post edited over 4 years ago by clipper_from_oz. (4 edits in all)
Aug 23, 2015 10:15 |  #3
Last image looks way better...Got some sun highlights on hair and front flash filled in ..
Also having sunlight either above or behind is better than front on because sun front on will make people squint........Thats the best way of doing shots in strong direct sunlight
..Also no need for ND ...Just lower ISO
Last shot looks fine
Clipper
5DSR,5DMkII,Fuji XPRO1,X-T1&X-T20,Fotoman 6x17cm Large Format Panorama Camera,Mamiya Universal 6x9
Canon EF 16-35mm f4 L, 17mm TSE f4 L,50mm f1.4, 24-70 f2.8 L, 70-200mm F4 L, 85mm f1.8, 100-400mm II L,
EF 400mm f2.8 IS II L, Fujinon XF18mmf2, XF35mmf1.4, XF60mm f2, XF18-55f2.8-4.5, XF55-200f4
Rodenstock, Sinar& Nikkor LF lens for Pano (75,95,150+210mm)
Jiggo0109
Gallery: 16 photos
Joined Sep 2013
Aug 23, 2015 10:26 |  #4
Thank you guys, let me guess... So i'll use nds if the bg is still very bright with the aperture I want and already at lowest iso, right? Since the subject would be back lighted by the sun, stronger strobes should come in?
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Aug 23, 2015 10:29 |  #5
put the strobe in a large softbox and keep it on or near camera axis, this will minimize the cross shadow (two shadows) problem.
otherwise, as you discovered, you can keep the sun behind the subject and light with the strobe on, or off, axis. Rather than right behind the subject you might try putting the sun to one side.
Gallery: 15 photos
Joined Jun 2011
Aug 23, 2015 10:31 |  #6
Jiggo0109 wrote in post #17679723 (external link)
yes.
i understand that sometimes you have no choice but to shoot in full sun in the middle of the day, but as you get closer to sunset or sunrise the problem of sun position and brightness becomes increasingly easier to deal with.
Jiggo0109
Gallery: 16 photos
Joined Sep 2013
Post edited over 4 years ago by Jiggo0109. (3 edits in all)
Aug 23, 2015 10:52 |  #7
Thanks again... Now it's getting clearer in my mind... Correct me if I'm wrong... In a situation where the sn is behind and the exposure setting of the bg is 2.8, iso 100, nd needed for example. Strobe is needed to light the subject. With this scenario, the power of the strobe will depend on the distance of the subject from the light (strobe). If I need to place my strobe 10ft away from the subject, powerful strobe is needed and if I only need to take a close up head shot, a 300 watt strobe would do because I can place it at nearest point as possible to the subject. Am I getting it right? Powerful strobes for long distance and low strobes for close ups, or better to have them both. :-)
EDIT: If also I wanted a darker background, more power from the light is needed, right?
Gallery: 15 photos
Joined Jun 2011
Post edited over 4 years ago by Left Handed Brisket.
Aug 23, 2015 11:00 |  #8
I use a single CL-360 (otherwise known as Godox AD360) in a 43 inch octa with only the inner diffuser while lighting subject from 8-10 feet away and have little problem over powering the sun. I generally use HSS to darken the sky and background with a faster shutter speed.
edit: i shoot an hour or so before sunset.
PhilF
Aug 23, 2015 11:07 as a reply to  @ Jiggo0109's post |  #9
if you want darker background you use hypersync or high speed sync
http://philfernandezph​otography.com (external link)
http://www.philfashion​photography.com (external link)
https://www.instagram.​com/philfernimagery/ (external link)
https://www.facebook.c​om/philfphotography (external link)
Wilt
Aug 23, 2015 11:27 |  #10
Jiggo0109 wrote in post #17679748 (external link)
If you set a light closer to subject, it is relatively larger in apparent size (compared to farther away), and therefore 'softer' than farther away
If you set a light closer to the subject, falloff due to distance is more rapid than if light is farther away
  • Light at 2' falls off by -1EV with only 0.8' more distance
  • Light at 8' hardly falls off (just over -0.25EV) at all with only 0.8' more distance
Doubling flash power only give you +1EV brighter light
Gallery: 15 photos
Joined Jun 2011
Aug 23, 2015 12:43 |  #11
PhilF wrote in post #17679763 (external link)
Obviously there are two schools of thought here
Use a faster shutter speed and HSS/hypersync
or
Use a ND filter and stay at sync speed
Just as obvious is that one could use some combination of the two, but most would agree that doing so just complicates things.
Both options result in less light reaching the sensor, preference in choosing one or the other is largely related to one's current equipment. Neither is the wrong or right unless the situation (equipment imitations, subject movement, etc) call for one over the other.
PhilF
Aug 23, 2015 14:53 as a reply to  @ Left Handed Brisket's post |  #12
In addition about using ND filters, if color is crucial to you, it's not advisable to use it
clipper_from_oz
Gallery: 26 photos
Post edited over 4 years ago by clipper_from_oz. (8 edits in all)
Aug 24, 2015 01:55 |  #13
clipper_from_oz wrote in post #17679710 (external link)
I forgot to mention that there is one other way to avoid these problems.....and that is be like some landscape photographers out there including myself that make it a rule never to shoot outdoors between 10.00 am and 2.00pm when there is harsh direct sunlight light unless is absolutely critical :) ..Just remember when wedding groups are hoping for a nice sunny day on the day of the wedding the wedding photographer is hoping for exactly the opposite :)
The other thing to be cognisant of is over use of fill flash outdoors which if used with a heavy hand results in shots look terrible unnatural....basically give it a false look ...Just go and have a look at some of the glamour shots posted up that are done outside a studio at places like beaches etc etc and many of them dont look natural because of this heavy handed use of a strobe. Ofcourse many ad agencies shoot outdoor ads successfully with a natural look however most of them have very very sophisticated lighting with a lot of after PP work included to get the shot looking right. .......My personal opinion is strobe doesnt add much value on anything outdoors except some nice subtle fill flash to smooth things out when shadows get bad.........exactly like you used in your last pic. That looks 100% natural and if outdoor people shots are what you mainly do then stay with that effect you acheived in the last image and you cant go wrong
Clipper
Clipper
Jiggo0109
Gallery: 16 photos
Joined Sep 2013
Aug 24, 2015 05:03 |  #14
Thank you guys... Really helped me a lot... So here is my recap...
1. Shoot during golden hours.
2. Use hss to preserve colors.
3. No need for stronger strobes to make a decent lighting against the sun, but powerful strobes are beneficial, if dialed down to match a
full powered 300 watt strobe, when recycling time is in concern.
4. Use the sun as fill or rim light of the subject.
If there is something I missed, please feel free to add a note. :-)
Thanks.
windpig
Chopped liver
Gallery: 6 photos
Aug 24, 2015 06:33 |  #15
Jiggo0109 wrote in post #17680742 (external link)
Thanks.
1. Nonsense, learn to shoot in full sun, just like the last image.
2. Hss does not preserve colors
3. More power gives you more modifier and flash to subject options, but for now I'd learn to use an unmodifed speedlight as fill in full sun to get a natural look. Learning this will make shooting in other lighting situations a piece of cake.
4. Sun never for fill, only for rim (I'm talking full sun).
Go ahead, spin the wheel.
1,921 views & 0 likes for this thread
Latest registered member is Snap Dragon
548 guests, 258 members online
