I am searching for a solution, I use black rapid straps and I am also buying a mefoto roadtrip and I decided to make the switch to acra swiss style ballheads, I purchased sirui k30x ballhead to go ontop of my everyday tripod.
I don't trust the standard screw type clamps to hold my camera on the strap, I do like the lever clamps they have a 2 step process to release the camera which seems much more secure, but my question is there really a diference between a lever clamp and a standad screw clamp? lever clamps have a screw on the opposite side of the plate that the lever is on, will that screw back out far enough to let the quick release plate fall to the ground, completely negating the benefit of the 2 step process of the lever clamp?
Here is an example.
https://youtu.be/jENbecEtKQg![]()
Are there lever clamps that don't use a separate screw adjustment?
