Just noticed a spring loaded oval door (tiny) on my camera and checked the manual and it is listed as "System extension mounting hole". That is all that it says!
What can be mounted here?
Curiosity has the better of me
Thanks.
Aug 24, 2015 17:45 | #1 Just noticed a spring loaded oval door (tiny) on my camera and checked the manual and it is listed as "System extension mounting hole". That is all that it says! I'm Bob and I'm an L-coholic
davesrose Title Fairy still hasn't visited me! 4,568 posts Likes: 879 Joined Apr 2007 Location: Atlanta, GA More info Post edited over 8 years ago by davesrose. | Aug 24, 2015 18:05 | #2 It's aparently for a GPS/WiFi unit Canon 5D mk IV
Aug 24, 2015 19:51 | #3 I have a 1DX and it is NOT a spring loaded door, it is just a pull open door. Canon EOS R EF 70-200 L 2.8 L 24-70 2.8L II Canon Pixma PRO-1 3 Canon 600EX-RT Speedlites
really? GPS? I'm Bob and I'm an L-coholic
rdalrt Goldmember More info | I believe the GPS/WiFi units have a little support stub that slides in that little hole. Just Sports Photography
CyberDyneSystems Admin (type T-2000) More info Post edited over 8 years ago by CyberDyneSystems. (2 edits in all) | Aug 24, 2015 22:31 | #6 It's on the 1D4 as well. (in a slightly different place) GEAR LIST
Thanks. You might be right. Here's a great picture of this little port: I'm Bob and I'm an L-coholic
panicatnabisco Senior Member More info Post edited over 8 years ago by panicatnabisco. (2 edits in all) | Aug 25, 2015 00:01 | #8 That's where the pin of the GPS/wifi unit goes in to, so it springs out when you take it off Canon 1DX III | 1DX | 6D II | 6D | 16-35/2.8 II | 24-70/2.8 II | 35/1.4 II | 50/1.8 | 70-200/2.8 IS II | 85/1.4 IS | 100/2.8 IS macro | 200mm f/2 | 400/2.8 IS II | 2xIII
apersson850 Obviously it's a good thing More info | Aug 25, 2015 02:02 | #9 Precisely. Prevents torque inadvertently applied to the GP-E1/WFT-E6 to be transferred to the fragile connector. The pin absorbs the force instead. Anders
davesrose Title Fairy still hasn't visited me! 4,568 posts Likes: 879 Joined Apr 2007 Location: Atlanta, GA More info Post edited over 8 years ago by davesrose. (2 edits in all) | Wait, how would this hole not be both the mechanical and electronic connection for the GPS/WiFi unit? The 1D (and 5D) series cameras don't have GPS/WiFi internally because their bodies are metal all the way around (and are completely shielded from EM waves). You have to buy a GPS/WiFi unit seperately (which going by the picture, you see those tiny little holes for connection pins). Canon 5D mk IV
apersson850 Obviously it's a good thing More info | Aug 26, 2015 06:00 | #11 In this case the question was about the "hole only", above the connector. Anders
davesrose Title Fairy still hasn't visited me! 4,568 posts Likes: 879 Joined Apr 2007 Location: Atlanta, GA More info | Aug 26, 2015 06:20 | #12 But Canon still does it with the 7D2. I don't think the "system extension" adapter would be able to draw that much power to be able to have much greater range then an internal WiFi (without comprimising battery life). Wonder if there have been any studies on that? I'm assuming Canon does that for the sealing. Canon 5D mk IV
apersson850 Obviously it's a good thing More info | Aug 28, 2015 07:58 | #13 It's not about the power, but about the antenna. Anders
| Latest registered member is semonsters 1503 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
