Thread started 24 Aug 2015 (Monday) 22:19
Printing vs image size
wysiwyg59
Gallery: 12 photos
Post edited over 8 years ago by wysiwyg59. (2 edits in all)
Aug 24, 2015 22:19 |  #1
Below image I tried to print 13x19 but it printed 12 5/8 x 16 1/4. it is 3456 x 5184 (17.9mp) what does this translate to printed size. This printed image the top is cut off and the bottom also.
Program I'm using to print is Aperture, printer is a Canon Pro9000
IMAGE: http://i305.photobucket.com/albums/nn207/wysiwyg77/IMG_5686_zpshi83mnbv.jpg
IMAGE LINK: http://s305.photobucke​t.com …5686_zpshi83mnb​v.jpg.html  (external link)
Rick
Canon A1,6D2 7D2, 40D, Canon G12, Sony NEX-5N
Canon 70-200 IS F2.8 L, Canon 35mm f1.4 L, Tamron 28-300, EF-S 18-200mm, EF-S 10-22mm
wysiwyg@hickorytech.ne​t (external link)
EnglishBob
Joined Dec 2004
Aug 24, 2015 22:24 |  #2
Print size is affected by DPI (dots per Inch), what is the DPI setting on the image?
Gallery (external link) MyGear (external link) About Me (external link)
wysiwyg59
Gallery: 12 photos
Aug 24, 2015 22:35 as a reply to  @ EnglishBob's post |  #3
300 dpi. I tried printing thru PS CS6 - set size @ 105% it stated image would be 12.095" x 18.1xx" is still printed the 12 5/8 x 16 1/4. I do not know what setting I changed. I was able before to print edge to edge using either program the this printer.
Rick
Wilt
Post edited over 8 years ago by Wilt. (4 edits in all)
Aug 24, 2015 23:33 |  #4
I suspect the software assumes a different paper size in the printer than what is loaded!
  1. Your original pixel count is 1.5:1 aspect ratio
  2. Your 12.1 x18.1" print size at 105% is also 1.5:1
  3. But your actual print area is 1.313:1
I don't normally use Aperture, but a bad DPI value should NOT affect aspect ratio of a print!
If your software uses the DPI setting to determine output size (many programs do not),
[3456 x 5184] / 300 = 11.52" x 17.28"
tzalman
Fatal attraction.
Post edited over 8 years ago by tzalman. (3 edits in all)
Aug 25, 2015 02:03 |  #5
EnglishBob wrote in post #17681836 (external link)
No, it is not! The native ppi (image dimensions/paper dimensions), in this case 267 ppi, is enlarged to 300 ppi (112% increase) in the printer driver because that is the ppi needed by Canon printers to create the dot matrix. For photo quality the printer will print at 1200, 2400 or 4800 dpi. Epson printers use 360 ppi as their base resolution and print at 1440, 2880 or 5760 dpi.
The DPI tag on the image is archaic and irrelevant unless you prefer the sending application to do the resampling instead of the driver; in this case, because of the small difference between 267 and 300, it is probably irrelevant which one does it. The file might be tagged 72 DPI by the camera, 240 or 300 DPI by editing software, or any other number; the resampling will always be the same - 3456 to 3871 pixels.
wysiwyg59 wrote in post #17681833 (external link)
To print borderless on 13x19 paper, which has a ratio of 1:1.46, the image must have the same ratio. You must crop it to 3456 x 5046 pixels. If left at 3456 x 5184, 136 pixels on the long side will be off the paper.
The fact that the image printed at 12 5/8 on the short side sounds as though either the driver interface or Aperture or both were not set to borderless. However, in that case the long side should have been around 18 1/4. Another possibility is as Wilt notes, that the driver was not set to the proper paper size.
Elie / אלי
Naturalist
Adrift on a lonely vast sea
Aug 25, 2015 05:37 |  #6
clipper_from_oz wrote in post #17682089 (external link)
yep key to it is ratio...if the ratio is wrong for paper you need to adjust in PS to print in the area of paper size and be prepared for a ink area that doesnt cover the whole page......Or zoom via PS to over 100% and fill the page but lose part of the image
Better way to go is crop paper before printing or use over size paper size and trim paper after printing to the image size
How does one calculate ratio to paper size? Never done this but interested in printing. For example, if I want to print the same image as 8x10, 13x19 and 16x20?
Thanks.
5D Mk IV & 7D Mk II
EF 16-35 f/4L EF 50 f/1.8 (Original) EF 24-105 f/4L EF 100 f/2.8L Macro EF 100-400 f/4.5-5.6L[/FONT]
clipper_from_oz
Gallery: 29 photos
Aug 25, 2015 05:39 |  #7
Just dont print borderless and trim image after printing
Clipper
R5, 5DSR, Fotoman 6x17cm Large Format Panorama Camera,Mamiya Universal 6x9
Canon EF 16-35mm f4 L, 17mm TSE f4 L,50mm f1.4, 24-70 f2.8 L, 70-200mm F4 L, 85mm f1.8, 100-400mm II L,
EF 400mm f2.8 IS II L, RF 600mm f4 IS L
Rodenstock, Sinar& Nikkor LF lens for Pano (75,95,150+210mm)
Naturalist
Aug 25, 2015 05:40 |  #8
Ya, but if one wants borderless....
5D Mk IV & 7D Mk II
clipper_from_oz
Gallery: 29 photos
Post edited over 8 years ago by clipper_from_oz. (5 edits in all)
Aug 25, 2015 05:42 as a reply to  @ Naturalist's post |  #9
You were quick...I actually deleted this reply because I realised you printed to border.less......
Re printing to ratio.....You can see it in a print preview in PS....thats what I do....and if I have cropped to much and its not right ratio then to get a better fit to the std paper size ratio I go back and crop whatever is needed .....It can be calculated but for me its easier just to preview in print area of PS..........In Lightroom I know there is a setting to keep the crop the same ratio as the original RAW( which matches most normal printers paper size ratio's) but not sure in PS if there is a setting to maintain crop ratio...Probably is same also for Aperture
Clipper
BigAl007
Gallery: 556 photos
Aug 25, 2015 06:06 |  #10
Calculating the aspect ratio is simple, for prints or digital files. Simply divide the long edge by the short edge. For prints use the actual measurements in inches, cm, or any other measurement scale you wish to use (just make sure you use the same units for both edges). For digital just use pixels. One other note, because you are dividing by two identical sets of units the result is a value with no scale units.
Once you have the ratio, for example all the ISO A series paper sizes have a ratio of 1:1.414, it becomes quite easy to know that if your digital image is 3116 pixels on the short edge, you will need to crop it to 4407 pixels to fit the correct aspect ratio. The advantage for the ISO A Series paper sizes is that this aspect ratio is constant (and for each single digit reduction of paper size you end up with exactly half the area). The calculations will apply equally to any other paper sizes too. So 10×8= 1:1.25 (4:5), 16×12= 1:1.333 (4:3) 6×4= 1:1.5 (3:2), etc.
Alan
clipper_from_oz
Gallery: 29 photos
Post edited over 8 years ago by clipper_from_oz. (3 edits in all)
Aug 25, 2015 06:22 |  #11
Naturalist wrote in post #17682095 (external link)
Easy.....print the correct size image on the paper to fit and then trim the paper after printing....Then its borderless :)
On a serious not I actually do this all the time....90% of my finished printed images are not std ratio aNYWAY.........Infact I hate the old std FF and 35mm ratio's....I much prefer the medium format ratios of 1:1 ( 6x6) and the wider 3;1( 6x17) and 6x9 and newer format of 16:9...Infact anythings better than 3;2..And for me the wider the more it gets closer to how the human eye sees things and if Im framing those wider sizes are way better for landscapes....except for Ansels favorite of 6x6 which I use for some B&W prints......
So I invested in a $40.00 guillotine from Office works and I now trim to whatever size I like without having to compromise my cropping to fit a so called std size
Clipper
mikewinburn
Aug 25, 2015 07:04 |  #12
I print regularly from my files to 5x7 and 8x10.
After I've retouched the image, I save it, and put it to the side.
I then create a new file from scatch and create a canvas 8" x 10" (or whatever size).
I then move my image around till I like the result, and imbed.
(This allows me to create a print w a border of any size I'd like or no border)
Couple notes.
I always take portraits w a bit of additional space around the edges because my finished product will have a border.
The file is not inherently 8x10' so unless I want to print to its native ratio, I'll have to crop.
My printer software allows my to change print settings if needed...but I've not had to change it to anything other than landscape and portrait and margin parameters (in relation to size anyway.)
Hope that helps?
Gear: The Official Gear List / Market Feedback / Sig thread #2468
WinburnCreations (external link)
2,333 views & 1 like for this thread, 8 members have posted to it and it is followed by 6 members.
1076 guests, 114 members online
