Thread started 26 Aug 2015 (Wednesday) 04:40
Canon DPP and Windows 10 Issue.
yogestee
Aug 26, 2015 04:40 |  #1
I upgraded to Windows 10 on my laptop yesterday. When I attempt to open DPP I get this message. I have my display set to maximum resolution 1366 x 768. Is this the end of Canon DPP for me?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/08/4/LQ_744361.jpg
Image hosted by forum (744361) © yogestee [SHARE LINK]
Jurgen
John ­ from ­ PA
Joined May 2003
Post edited over 8 years ago by John from PA.
Aug 26, 2015 05:27 |  #2
Make sure you are using DPP version 4.3.1 which was just released on 20 August. It specifically addresses some display issues so may take care of your issue.
One source to download the "updater" version is http://www.usa.canon.c​om …ns_kit#DriversA​ndSoftware (external link). In using "updater" versions some previously installed copy of DPP needs to be present on your PC.
-dave-m-
Gallery: 6 photos
Joined Sep 2011
Aug 26, 2015 07:53 |  #3
I would also check for updated drivers for whatever graphics card or onboard graphics your laptop is using.
5D MkII Gripped | 7D MkII Gripped | 200 f/2.8L | 17-40 f/4L | Σ 24-105 OS f/4 Art | Σ 50 f/1.4 Art | Σ 150-600 OS f/5-6.3 C | 430EX II
yogestee
Aug 26, 2015 10:44 |  #4
John from PA wrote in post #17683366 (external link)
Thanks John,,, installed version 4.3.1 but didn't solve the problem.
Jurgen
gjl711
Aug 26, 2015 11:05 |  #5
This error has been around for a long time. If I remember correctly, you should be able to click on the DPP icon, select properties and uncheck display scaling, or something like that. I don't have DPP in front of me so I cant check what it is actually called. I'm working from old memory. :)
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
John ­ from ­ PA
Joined May 2003
Aug 26, 2015 11:20 |  #6
Although Windows 8, same issue discussed at http://community.usa.c​anon.com …n-in-Windows-8/td-p/20925 (external link). It might be worth going through the various remedies that people have tried; many were successful in clearing up the issue.
yogestee
Aug 26, 2015 20:05 |  #7
Thanks everyone. I think it's time to move on. I only use DPP for tweaking and converting RAW images. All major JPG editing is done in Photoshop CS6. Light Room seems the go nowadays.
Jurgen
Moonshiner
Joined Jul 2013
Aug 31, 2015 10:35 |  #8
gjl711 wrote in post #17683690 (external link)
This is the answer...
Right-click on the DPP executable and choose properties...
Click the compatibility tab and under settings check if unchecked, or uncheck if checked the property in the settings section Disable display scaling on high DPI settings...
Click OK
Done...
yogestee
Aug 31, 2015 20:07 |  #9
Moonshiner wrote in post #17689933 (external link)
Click OK
Done...
Thanks,, I've already try this. No success.
Jurgen
Moonshiner
Joined Jul 2013
Post edited over 8 years ago by Moonshiner.
Aug 31, 2015 21:23 as a reply to  @ yogestee's post |  #10
Odd... Mine works just fine on Windows 10... I think if you put it on the link that launches DPP you might do better...
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/08/5/LQ_745372.jpg
Image hosted by forum (745372) © Moonshiner [SHARE LINK]
Mark0159
I say stupid things all the time
Gallery: 45 photos
Joined Mar 2003
Sep 02, 2015 16:37 |  #11
it might pay to reset the settings for DDP,
You can do this by going to C:\Users\xxxxxx\AppDat​a\Local\CANON_INC\Dpp4​Main.exe_Url_vcq5bfqto​2tiamirodhemakyhdd0nni​v (where xxxxxx is the name of your account on your PC)
there is a config file that you can delete. this will delete any custom settings that have been setup. this means you will have to do setup any settings again.
if this doens't work then I would recommend deleting the following directorys.
C:\Users\xxxxxx\AppDat​a\Roaming\Canon_Inc_IC
both of these directorys are created when you start using DDP and are safe to delete.
Once you reopen DDP it will recreate both of these folders.
If that doesn't work then I would recommend you download the latest (it's free so it it pays to keep it updated) delete the above folders and then reinstall.
Mark
https://www.flickr.com​/photos/52782633@N04 (external link)
Canon EOS 6D | Canon EF 24-105mm f/4L IS USM, EF 17-40mm f/4L USM, EF 50mm f/1.4 USM, EF 100mm f/2.8 Macro USM | Tamron SP 35mm F1.8 Di VC USD | Canon Speedlite 550EX -|- Film | Canon EOS 3 | Olympus OM2 | Zuiko 35mm f2
Luckless
Joined Mar 2012
Sep 07, 2015 10:38 |  #12
If you've upgraded to windows 10 through a previous version of Windows, then I would strongly suggest creating a Windows 10 install disk on a thumb drive, back up all your documents, and then format the drive and do a clean install.
They've almost gotten the upgrade process to a point where it is fully reliable, (and it has been very reliable all the way back from the old windows 1 or 2.x days, assuming you never really used any third party software.) but we still have too many third party developers 'being clever' with their software, and we're still prone various errors that crop up from different things.
Upgrading now, before you've spent months finding different little settings and such that you like on Windows 10, will save you time in the long run.
Good luck with your system.
Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
Flickr: Real-Luckless (external link)
yogestee
Sep 08, 2015 00:16 |  #13
Luckless wrote in post #17698104 (external link)
Thanks, but not worth the effort. Just couldn't be bothered with DPP any more.
Jurgen
Mark0159
Gallery: 45 photos
Joined Mar 2003
Sep 08, 2015 02:17 |  #14
have you tried my recommendation?
DPP does work with Win10. it's working on my machine with no issues. I also did an upgrade so it's not that would have broken it.
Mark
yogestee
Sep 08, 2015 05:49 |  #15
Mark0159 wrote in post #17699059 (external link)
Thanks Mark. Latest version downloaded and installed, uninstalled and reinstalled. No joy.
Jurgen
9,464 views & 0 likes for this thread, 8 members have posted to it and it is followed by 6 members.
1464 guests, 137 members online
