hi all, i bought an canon 700d to replace my sony a390, im strugging to find a remote triggering device to use with studio flash guns
andy100102 Hatchling 4 posts Joined Aug 2015 More info Post edited over 8 years ago by andy100102. | Aug 26, 2015 06:01 | #1 hi all, i bought an canon 700d to replace my sony a390, im strugging to find a remote triggering device to use with studio flash guns
GeoKras1989 Goldmember More info Post edited over 8 years ago by GeoKras1989. | Aug 26, 2015 06:06 | #2 Permanent banandy100102 wrote in post #17683391 hi all, i bought an canon 700d to replace my sony a390, im strugging to find a remote triggering device to use with the new camera They are available online for $10 or so. Wired and IR: WARNING: I often dispense advice in fields I know little about!
andy100102 THREAD STARTER Hatchling 4 posts Joined Aug 2015 More info Post edited over 8 years ago by andy100102. | Aug 26, 2015 06:08 | #3 i need a trigger to set off studio flash
GeoKras1989 Goldmember More info Post edited over 8 years ago by GeoKras1989. | Aug 26, 2015 06:28 | #4 Permanent banSeveral options. If you are using Canon flashes, the 700D should (may) be able to master them by itself. If the camera is not capable of mastering, you can use a Canon 550EX, 580EX or 580EX II. Yongnuo also makes several units that work with Canon's master/slave system. I don't know model numbers. WARNING: I often dispense advice in fields I know little about!
OceanRipple* Senior Member 842 posts Likes: 175 Joined Dec 2014 More info Post edited over 8 years ago by OceanRipple*. (2 edits in all) | To avoid buying more than once, there are some extra questions (nearly any radio flash trigger can be made to do what you are requesting).
| Latest registered member is Thunderstream 1819 guests, 101 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
