Thread started 26 Aug 2015 (Wednesday) 14:57
7D2 - Settings - My focus point, not the camera
complete
Joined Jul 2012
Aug 26, 2015 14:57 |  #1
Hi. I cannot, for the life of me, figure out how to change the focus settings on my 7D2 to use the focus point I want, not what the camera thinks I want. It overrides my selection! Grr. It is probably really easy (and I had it set that way before I reset the settings two months ago (for other reasons), but I give up. Any ideas?
Colin ­ Glover
Gallery: 17 photos
Joined Aug 2012
Post edited over 8 years ago by Colin Glover. (2 edits in all)
Aug 26, 2015 17:58 |  #2
If it's like my 70D, there's a button to the left of the shutter with four dots in a T shape.This is used to cycle through the 3 options, all points, expanded area, and single point focus. You'll know when it's in single point as only the centre point will be visible. Use the D pad to select the one that want.
Canon EOS 70D, Canon EOS 600D, EF-S 18-55 ii, EF 55-200 USM ii, EF-S 75-300 iii, Tamron 28-80, Sigma 70-210. Pentax 50mm, Pentax 135mm, EF-S 55-250, Raynox Macro adapter, Neewer filters (CPL, UV, FLD & ND4), Fuji HS20 EXR (30X zoom ) & cable release, Yongnuo 560 iii & Luxon 9800A manual flashguns for the Fuji, Hama Star 63 tripod, Hongdek RC-6 remote control, Velbon DF 40 www.point-n-shoot.co.uk website.
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Aug 26, 2015 18:06 |  #3
Or in the custom menus you can assign the multi controller button to do this.
Image Editing OK
Archibald
You must be quackers!
Gallery: 789 photos
Post edited over 8 years ago by Archibald.
Aug 26, 2015 18:29 |  #4
Manual, page 92.
When you arrive at a single point, use the joystick to select the point you want.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/08/4/LQ_744470.jpg
Image hosted by forum (744470) © Archibald [SHARE LINK]
Lbsimon
...never exercised in my life
Gallery: 19 photos
Aug 26, 2015 19:59 |  #5
I have a problem of setting the focus point when in Live View.
I select a center point for normal viewfinder shooting. Everything works as it should. Then I switch to Live View, and the camera switches to a zone focus, and automatically selects the points for me! Where do I look for the solution? I could not find it in the manual.
Archibald
Gallery: 789 photos
Aug 26, 2015 20:07 |  #6
Lbsimon wrote in post #17684248 (external link)
In Live View, use the joy stick to move the focus area around.
Lbsimon
Gallery: 19 photos
Aug 26, 2015 22:03 as a reply to  @ Archibald's post |  #7
Thanks. I will try when I am back home from the trip.
complete
Joined Jul 2012
Aug 28, 2015 12:30 |  #8
I think my question needs re-stated. I know how to choose the focus options; the camera does not care what point I want, it supercedes my selection. What is causing that?
Archibald
Gallery: 789 photos
Aug 28, 2015 12:57 |  #9
complete wrote in post #17686506 (external link)
Sorry, I have no idea what you mean.
Luckless
Joined Mar 2012
Aug 28, 2015 13:54 |  #10
Which focus mode and settings are you using? You're not using one that allows the focus point to track focus beyond its starting point by any chance?
Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
Flickr: Real-Luckless (external link)
digital ­ paradise
Gallery: 157 photos
Post edited over 8 years ago by digital paradise.
Aug 28, 2015 17:31 |  #11
In single, spot and expanded modes the centre point is the primary. In expanded the surrounding points assist. You can move center point to wherever you want to.
In zone the system picks the closest object locks on and tracks it. Or you can specify an AF point and aim that point on your subject. When the system locks using that point the other points begin to track. The specificied point becomes part of that grouping. You will see it activate and deactivate as required to track your subject. Not like expanded where the center point is always active.
Image Editing OK
digital ­ paradise
Gallery: 157 photos
Aug 28, 2015 19:37 |  #12
Sorry I had to drop this for a bit. So in zone it is just a computer is trying to figure out what you want. It does a good job but can pick up other targets. You can adjust the tracking sensitivity to -1 or -2 for any case number for both single point and zone so the system ignores other things in the viefinder. Case 2 is set to -1.
Image Editing OK
gqllc007
Joined Jan 2015
Aug 29, 2015 06:20 |  #13
I think he is setting the focus point in large zone selection. If you do this it will first focus on the point you selected but the camera will adjust accordingly for what it thinks should be in focus. You have to get into the small zone. look at the bottom of the viewfinder when you are changing AF points and you will see ( ) or ( ) if you are in ( ) you are in large zone focus and I think go to page 450 of manual and see what settings you have for initial tracking I think it is call AF Start position
digital ­ paradise
Gallery: 157 photos
Aug 29, 2015 11:02 |  #14
That is possible. On another site I suggested to use large zone and focus on a table lamp or something outdoors then move the camera left to right and see how it works.
Also I believe ITR is set to "ON" from the factory. In zone it activates and in one shot it looks for faces and in AI Servo it looks for colours to track. If the faces are small or not lit well it can struggle.
If someone wants precise focus zone is not the best option. Technically you can select the AF start point and aim it on an eye but single point is the best option IMO for that application.
Image Editing OK
Varago
Aug 29, 2015 11:20 |  #15
I think both questions are answered in the manual plus about 966.4 more :) My question is why spend the money on a VERY good body and not take the time to read the manual. Over 60% of the things the 7DII can do you will NEVER know, what a waste:-(
EOS R
Canon RF 24-105 f4 IS L, RF 24-240, RF 35 1.8 macro, EF 70-200 f4 IS L, EF 16-35 F4 IS L, 50 1.8 stm, 270EX II, 320EX, 430EX II
Sigma 1.4x tc1401
Tamron 100-400
11,077 views & 3 likes for this thread, 17 members have posted to it and it is followed by 13 members.
1465 guests, 133 members online
