Thread started 28 Aug 2015 (Friday) 08:29
Facial skins tones and reds
Frodge
Joined Nov 2012
Post edited over 8 years ago by Frodge.
Aug 28, 2015 08:29 |  #1
When I take pictures in my living room, I at many times get a reddish skin tone and also some reddish tones in the general frame. I'm trying to figure out how to eliminate this.
PS. This isn't the sharpest picture, but it illustrates what I'm talking about. Is this a white balance issue?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/08/4/LQ_744742.jpg
Image hosted by forum (744742) © Frodge [SHARE LINK]
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
sploo
premature adulation
Joined Nov 2011
Aug 28, 2015 08:50 |  #2
Frodge wrote in post #17686212 (external link)
Hosted photo: posted by Frodge in
./showthread.php?p=176​86212&i=i169088889
forum: Canon Digital Cameras
Most likely white balance, but in the shot you've posted there will be some diffuse reflection from the pink top that will affect the face.
The easiest thing to do would be to get an 18% grey card (something you know is neutral) then use Lightroom's eye dropper tool on it to set white balance. That way you'll know the overall white balance for the shot is neutral, and as long as the subject is in the same lighting then it should be correct.
If not (and if you're just shooting JPEG) then might it be an inappropriate colour profile? I don't use them, but a vivid profile may do something like what you're seeing.
Camera, some lenses, too little time, too little talent
Frodge
Joined Nov 2012
Aug 28, 2015 09:00 |  #3
This is sooc jpeg
sploo
premature adulation
Joined Nov 2011
Aug 28, 2015 09:11 |  #4
Frodge wrote in post #17686234 (external link)
This is sooc jpeg
OK. I'm going with white balance. I won't repost, but I just loaded the image into Photoshop and neutralised the colour balance based on (what I assume is) white detail on the heart on her t-shirt; the skin tones then looked much better.
Frodge
Joined Nov 2012
Aug 28, 2015 09:14 |  #5
I appreciate the feedback. How would I do this in ligjtroom? Just with the dropper? To set wb from the shirt?
rrblint
Gallery: 84 photos
Joined May 2012
Aug 28, 2015 09:28 |  #6
Yes, that will work. Next time try setting your in-camera WB to tungsten.:-)
Mark
Wilt
Post edited over 8 years ago by Wilt.
Aug 28, 2015 09:29 |  #7
Frodge wrote in post #17686253 (external link)
As the photographer witnessing the scene, you can often adjust WB with the foreknowledge...
  • Incandescent light typically somewhere in the 3000K-3200K
  • Modern fluorescent CFL, about 2950K and Tint +9 to take out the excess green
  • or you can shoot a picture of a white piece of photographic inkjet paper in one shot, to use the LR eyedropper on
Frodge
Joined Nov 2012
Aug 28, 2015 09:35 |  #8
Thanks folks. Very helpful. While I'm at it, what do you typically do in lr for shots of people? I do certain things for landscapes and such that I'm happy, but not quite sure what others do for photos of people....
rrblint
Gallery: 84 photos
Joined May 2012
Aug 28, 2015 09:41 |  #9
I just eyeball it while tweaking until it looks right. Then the rest of that set should all be very similar, if not identical.
Mark
itsallart
Gallery: 1095 photos
Joined Jan 2015
Aug 28, 2015 09:43 |  #10
the T-shirt also reflects a lot of pink onto the child's face, particularly her bottom cheek...which is quite normal :)
Renata
Seeing lights and shadows is an art :)
My Vinyl Source (external link)Tanami Muse (external link)
500px (external link)
Face Masks on Etsy (external link)
artyH
Aug 28, 2015 09:46 |  #11
What is the dominant light source? If you use auto white balance, and have incandescent lighting, you get reddish tones. If the dominant a light source is natural light, you may be able to avoid this. Late in the day, artificial light will provide more of your lighting, and all of it at night.
Try a shot near the window and check to see what happens. An alternative is to use a custom white balance setting on the camera, if it supports this. Fluorescent light is much harder to deal with.
If your lighting is entirely incandescent, try that setting on the camera.
sploo
premature adulation
Joined Nov 2011
Aug 28, 2015 09:46 |  #12
Frodge wrote in post #17686296 (external link)
Generally just getting the tones looking right, maybe paint over the face with a positive shadows value if it's a bit dark. Also I use the Iris Enhance preset to paint over the eyes.
Sometimes I'll use a little bit of negative clarity, as that can smooth skin and take the harshness out of a shadow (e.g. a chin line). I don't tend to do much in the way of dodging and burning to adjust specific shadows and highlights; partly because it's overkill for most of my people shots, partly because I don't think I'm that skilled at doing it.
sploo
premature adulation
Joined Nov 2011
Aug 28, 2015 09:48 |  #13
Yep. Just the dropper on what looks like a white/grey area. You've got to be careful to not get something that's coloured due to reflections/closeness from something vivid as that can throw things off.
Often I'll just go through some of the presents (tungsten, fluorescent etc as appropriate); one is often good enough.
Wilt
Aug 28, 2015 10:01 |  #14
rrblint wrote in post #17686305 (external link)
...keeping in mind that in a mixed light setting (e.g. some daylight coming thru a window plus some incandescent from inside) the ambient color temperature is a varying mix depending upon location...think of a pond fed by a thermal spring, near the spring is warm but at the other end it can be much colder.
What artyH says is appropriate.
Frodge
Joined Nov 2012
Aug 28, 2015 10:14 |  #15
That's her first camera BTW. This was mine:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/08/4/LQ_744750.jpg
Image hosted by forum (744750) © Frodge [SHARE LINK]
5,387 views & 3 likes for this thread, 11 members have posted to it and it is followed by 5 members.
1294 guests, 136 members online
