Thread started 30 Aug 2015 (Sunday) 10:57
Stupid question...
LisaBlue85
Gallery: 34 photos
Joined Aug 2012
Aug 30, 2015 10:57 |  #1
I feel like an idiot asking this, but have searched /googled & found nothing... I have a Canon 6d & last week also purchased a 7d mark ii, obviously the EOS Utility disc was downloaded & installed when I bought my 6d...my question is, do I need to do it again with the 7d? I'm thinking "No", but want to make sure...
pknight
Gallery: 39 photos
Joined Feb 2006
Aug 30, 2015 11:03 |  #2
Do the discs indicate the version of the software? If the 7DII software is a higher version number, I would install it. Or, go to the Canon site and get the latest version.
Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
Jon
Joined Jun 2004
Aug 30, 2015 11:05 |  #3
Yes, you should, since there are doubtless advances between the two. For instance, the later software will support the 7D2's RAW format (every new Canon seems to have a slightly different RAW format; before you run off screaming, this is also true for any other camera aside from those using .DNG as their standard). Actually, what you should do is go to the Canon site and get the updated versions of the software - it'll work for both cameras and it's probably even more recent than the software on the 7D2 disc (they just released new versions of EOS Utility and DPP, for instance, within the last 2 weeks).
Jon
Cocker Spaniels
LisaBlue85
Gallery: 34 photos
Joined Aug 2012
Aug 30, 2015 11:08 as a reply to  @ pknight's post |  #4
Thanks! Looks like the latest version. Just wasn't totally sure if the Utility was specific to each camera... Pretty sure it isn't.
EnglishBob
Joined Dec 2004
Aug 30, 2015 11:11 |  #5
LisaBlue85 wrote in post #17688660 (external link)
Your correct it isn't, 7D II version should be the newest.
Gallery (external link) MyGear (external link) About Me (external link)
LisaBlue85
Gallery: 34 photos
Joined Aug 2012
Aug 30, 2015 11:31 as a reply to  @ Jon's post |  #6
Thanks sooo much Jon! Going to install asap! Thanks again for all the help guys!!!
LisaBlue85
Gallery: 34 photos
Joined Aug 2012
Aug 30, 2015 11:33 as a reply to  @ EnglishBob's post |  #7
Thanks EnglishBob! That's what I thought, not "camera specific".
gjl711
Aug 30, 2015 11:35 |  #8
LisaBlue85 wrote in post #17688687 (external link)
Correct, not specifit to the camera. Just load up the latest version or grab the latest version from the Canon site. Doesn't matter for which camera, just the latest version.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
gjl711
Aug 30, 2015 11:37 |  #9
After I posted, I though of one caveat. This is true for DPP3.xxx but not for DPP 4.xxx. From what I understand DPP4.xxx just supports a small subset of bodies right now. I believe both the 6D and 7DII are in the set though. I know that the 5DII and 7D I are supported so I'm thinking the newer ones will be as well.
::Gear::
LisaBlue85
Gallery: 34 photos
Joined Aug 2012
Aug 30, 2015 11:55 as a reply to  @ gjl711's post |  #10
gjl711 wrote in post #17688690 (external link)
Great! Thanks so much!
1,767 views & 4 likes for this thread, 5 members have posted to it.
Stupid question...
1054 guests, 103 members online
