What is the smallest arca Swiss compatible screw clamp that also has the safety stop release?
Rstanford Member 201 posts Likes: 10 Joined Feb 2009 More info | Aug 31, 2015 00:13 | #1 What is the smallest arca Swiss compatible screw clamp that also has the safety stop release?
Sep 01, 2015 09:17 | #2 There are two styles of safety stop in use of which I am aware. One style has a pin on the clamp itself (see Acratech for an example), the other has screws on the plates, with channels on the clamp (see Really Right Stuff and Kirk). - John
Sep 02, 2015 01:58 | #3 I'm familiar with the pin in the clamp, you have to unscrew the knob then press the pin down to slide the plate out.
johnf3f Goldmember More info Post edited over 8 years ago by johnf3f. | Sep 02, 2015 16:10 | #4 Just unscrew the knob a bit further and tilt it to release. Life is for living, cameras are to capture it (one day I will learn how!).
CyberDyneSystems Admin (type T-2000) More info | Sep 02, 2015 16:40 | #5 This is the smallest one I have; GEAR LIST
Sep 02, 2015 23:02 | #6 I wish I would have done more research before I bought into this system, I bought a sirui k30x ball head and a few QR plates but the plates have screw stops which aren't compatible with the sirui mp-20 clamp on the ballot it uses a pin on the ballhead for a safety stop.
I have the K40X and no problems with the plates with screw type stops so long as they are a bit longer than the clamp. Some plates are hollow underneath (like Sirui) most will engage the safety stop on the clamp. Others are solid so they just depress the clamp safety stop and rely on the screw type safety stops on the plate - this is why they need to be longer than the clamp. Get plates of 70mm or longer if you are using the screw type stops or ones that are hollow underneath so that they engage the safety stop on the clamp - then you can just remove the screw stops. Life is for living, cameras are to capture it (one day I will learn how!).
Sep 03, 2015 14:13 | #8 Yes it does, but only because I experienced it first hand now, I bought a plate that fits my 5d3 but it had screw stops, I had to remove the acres for it to fit, I'm sure it would have worked fine, but I want the added safety of the retaining pin.
Didn't your K30X come with a QR plate? My K40X did - that is the plate I use on my camera. My longer plates (of various types) are mounted on lens feet where longer plates are an advantage and the screw stops don't interfere. Life is for living, cameras are to capture it (one day I will learn how!).
CyberDyneSystems Admin (type T-2000) More info | Sep 04, 2015 16:12 | #10 regarding the safety stop screws, I'm tepid on them. Some of my plates I've removed them, some I left on, they are a toss up between safety and speed/convenience, which for over a decade now and I still have not come down on one side or the other firmly enough that my plates are either with or without.. stil a mix. GEAR LIST
Sep 04, 2015 18:07 | #11 On the safety note... I had a Kirk BH-1 for 11 years. It is was an older design and the clamp didn't have any safety features. Once I saw how tightly it held the plates, I had no worries. And no accidents in that time. - John
Sep 05, 2015 15:30 | #12 Thnx john, but I live in the states, my k30 did come with a plate, but I use a strap actually a double strap and there are times I will run ahead and the force of a 5d3 with a 70-200 2.8 IS ii could create enough rotational force to loosen the screw that holds the qr plate, so I bought a 5d3 specific plate that conforms to the bottom and sides of the camera.
| Latest registered member is semonsters 1519 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
