Hi,
I have a Canon 7D MK2 and use it with a 300mm F4 EF L lens, if the lens is set at the macro setting in AF and you try to focus on a subject that is further away should the lens immediately focus on that subject without me having to turn the manual focus ring to a further distance before it focuses?
Hope I have explained that correctly the focusing limiter is set at 1.5 I am also using it with a 1.4 converter.
Ian.
